04-29-2011, 12:23 PM | #1 |
Unanswered 5spd swap question
14) Install Mounting Plate Install the M/T mounting plate on the Bellhousing. Line it up with the dowels.
Mounting plate or sandwich plate or adaptor plate... i have heard it called all of these, yet when I look at the exploded view on nissan trans it does not show such a thing. Wondering if this is really needed or if its just a thin sheet of metal that can be discarded. Working on s14
Wanted: Good well mannered athletic woman with her own classic or sports car.... send photo of car |
04-29-2011, 12:25 PM | #2 |
If you have it, put it on.
Helps keep dust and shit out of the trans. especially if its a daily. You hear guys running without them once in awhile. But its about as smart as running without a filter on your intake. eventually, somethings gonna go bad,....real bad. lol |
04-29-2011, 12:36 PM | #3 | |
right on, thats waht I thought it was, just a dust shield... nope not a daily,,,,
Hey does anyone have a listing for each bolt size and thread pitch needed? I have most but just in case Quote:
04-29-2011, 01:08 PM | #4 |
Here is a list of all the bolts and parts numbers with them, just get them from nissan, along with other parts
Front Seal Paper Gasket # 32112-08U01 $4.50 Top Shifter Gasket 32516-03U11 $5.36 Rear Oil seal 32136-U0100 $8.74 Front Seal-oil 32114-Y4000 $3.71 Manual Transmission Flywheel Bolts - 12315-42L11/ 6 needed Manual Presure Plate Bolts 01121-00772 / 6 needed Engine / Bellhousing Bolts Bolts = 08131-0601A / 60mm length / 4 needed Washers = 08915-2401A / 4 needed Bolt = 08131-0701A / 70mm length / 1 needed Washer = 08915-2401A Bolts = 08124-0301F / 35mm / 2 needed Nuts = 08911-2401A / 2 needed Bolt = 08124-0601F / 65mm / 1 needed Nut = 08911-2401A / 1 needed Bolt = 08071-0251A / 25mm / 1 needed Starter Bolts = 01121-03751 / 95mm / 2 needed Mitsubishi shift knob MR263906 16.95 Lower SHift boot 32862-V5001 shift boot 96935-40F10 |
