Old 02-17-2012, 07:55 AM   #151
dpkid101
dpkid101's Avatar
dpkid101 is an unknown quantity at this point
Originally Posted by bullfrogg0 View Post
It's only like 6 or 8 wires that need power, really hard to mess that up
which pinout did you use? ive seen a few thrown out around the internet and have a couple saved to my other computer but i dont have it with me
dpkid101 is offline   Reply With Quote
Old 02-17-2012, 08:04 AM   #152
dpkid101
dpkid101's Avatar
Heres one diagram ive seen pop up a few times. Have any of you used it before? Pulled this off of supramania.com btw
I have been trying trying to find a solution for a few of my electrical issues, and thought perhaps someone knowledgeable might come across this and be able to help...
I have put together a very easy to read, custom Wiring Diagram for how I wired up my 2JZ s13 240sx (ECU)
Here is a quick explanation:
Ok, to start off, both fuses and the 4-pin Relay were reallocated from the existing passenger side engine bay fuse-box.
I will explain what I used for each item:
30A Fuse - I poked around and found that the factory Nissan 30A "Cond. Fan/Anti Skid" fuse was hot at all times. I have no need for it, so I re-pinned the side which originally powered the fan, with 16 gauge wire, to match the gauge of the 2JZ ECU E10's BATT (pin 33) wire, which would splice into it. I was sure to include wire gauges in my diagram.
4 Pin Relay - I fitted a spare Nissan-Style 4 Pin Relay into an open slot, and re-pinned it with wire gauges to match that of it's corresponding ECU pins. (shown in diagram)
7.5A Fuse - I used the factory Nissan 10A "Eng. Cont" Fuse slot, but changed the Fuse to a 7.5A. (to match supra FSM)
2JZ IK1 Plug has 2 pins required for general start-up and run. Those 2 pins power the IACV ( pin E3 ), and Injectors / Coils / Etc. ( pin F6 ). My understanding is that all they need is a switched 12V source, so I spliced them between my 7.5A fuse, and the Ignition Switch.
Old 02-18-2012, 03:24 PM   #153
Flipnirish
Flipnirish is an unknown quantity at this point
Freed Engineering
Ben @ Freed engineering has mad skills at wiring and engine mount brackets. His prices are pretty reasonable as well.
Check them out!
Flipnirish is offline   Reply With Quote
Old 02-18-2012, 08:43 PM   #154
dpkid101
dpkid101's Avatar
just found your diagrams and write ups, going to try it in the next couple of weeks
Old 02-20-2012, 08:51 PM   #155
1jzs14
1jzs14 is an unknown quantity at this point
can you use a 2jz lower radiator hose?
1jzs14 is offline   Reply With Quote
Old 02-20-2012, 09:13 PM   #156
bullfrogg0
bullfrogg0's Avatar
bullfrogg0 is an unknown quantity at this point
Yeah, I used a 2jz upper and lower in mine. Just have to trim them to fit.
bullfrogg0 is offline   Reply With Quote
Old 02-21-2012, 10:48 AM   #157
h815 240sx
h815 240sx is an unknown quantity at this point
Anyone know of a front strut tower bar that will clear 1jz/2jz the intake piping? My Greddy isn't even close.
Said example:
h815 240sx is offline   Reply With Quote
Old 02-21-2012, 12:55 PM   #158
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Said example:
i had a cheap ass ebay one on mine...
OLD PIC
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 02-22-2012, 01:10 AM   #159
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
Hoping my Wiring comes out smooth...anyone running a Ford Inertia Cut Off Switch BTW?
jdm2191 is offline   Reply With Quote
Old 02-22-2012, 01:18 AM   #160
1jzs14
OLD PIC
so clean
Old 02-22-2012, 09:43 AM   #161
1jzs14
so i was changing out my oil pan to a front sump one and two of the bolts on the lower pan snapped at the head of the bolt!
so what would be the best bet the holes should not be stripped and the bolts are not cross threaded. i have been told to drill them out but i know of easy outs which would be best to do easy out first see if it works?
Old 02-22-2012, 09:46 AM   #162
1jzs14
also will the 240sx powersteering resavior work on the 1j?
Old 02-22-2012, 09:50 AM   #163
1jzs14
so what would be the best bet the wholes should not be stripped and the bolts are not cross threaded. i have been told to drill them out but i know of easy outs which would be best to do easy out first see if it works?
Old 02-22-2012, 10:39 AM   #164
Flicktitty
Flicktitty's Avatar
is there ANY bolt sticking up to get a pliers on or even a punch and a hammer and unscrew it that way?
Old 02-22-2012, 10:55 AM   #165
1jzs14
no cause the pan is covering it up so i talked to my friend that is a t10 tech that help me do my swap on my supra he told me to use a bolt extractor
Old 02-22-2012, 10:55 AM   #166
1jzs14
what would a punch do?
Old 02-25-2012, 01:18 PM   #167
CDD200
CDD200 is an unknown quantity at this point
hey got mine going, just went on 1st drive it is sweet, even with the s15 rear 3.69 it blew the tries away in 1-3rd, with just a 10lb spring in the wg more to come.....
93 s13 coupe 5 speed- Ls2 swap in the works
97 sc300-gte/v160
CDD200 is offline   Reply With Quote
Old 02-26-2012, 10:01 AM   #168
1jzs14
can the s14 powersteering resivior work with this swap my motor didnt come with one i would imagine it would all it is a bottle that hold fluid
Old 02-26-2012, 10:12 AM   #169
JDM SPUG
JDM SPUG is an unknown quantity at this point
Yes it will work. I'm using my s14 resivoir with my 2JZ swap.
JDM SPUG is offline   Reply With Quote
Old 02-26-2012, 10:12 AM   #170
bullfrogg0
bullfrogg0's Avatar
As long as u have the right fittings, Idk why it wouldn't work
Old 02-26-2012, 10:18 AM   #171
JDM SPUG
Are you running an R154? And if you are how many RPM are you cruising at in 5th gear at 65MPH?
Thanks
Old 02-26-2012, 10:35 AM   #172
bullfrogg0
bullfrogg0's Avatar
Depends on what the rear gear is. The 5th gear ratio in r154 is .75. W58 which is the trans in my car has a 5th gear ratio of .78 and with my 180sx vlsd's 4.36 gearing and 205/60/15 tires I turn 3,000 rpm at 70 mph.
Old 02-26-2012, 10:50 AM   #173
florante rea
florante rea's Avatar
Trader Rating: (43)
florante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of light
Feedback Score: 43 reviews
Send a message via AIM to florante rea Send a message via Yahoo to florante rea
Anyone running a vvti version 2jzgte here?Seems like most of the swaps r just regular. I'm looking for more info of the newer version just in case i go with the vvti.
fdrea
florante rea is offline   Reply With Quote
Old 02-26-2012, 10:56 AM   #174
JDM SPUG
I know that's why I quotes him be use he is running an HLSD. 3.69
Old 02-26-2012, 11:06 AM   #175
bullfrogg0
bullfrogg0's Avatar
Just use Google to find an rpm calculator.....
Old 02-26-2012, 03:11 PM   #176
CDD200
I am using the r154, my cluster is not hooked up yet, i am swapping to a jdm, it should be in this week, it does not sound like a lot of rpms ha ha, but my 245s are shot, will move up to a 285 or 315, it should help, but it was maybe half throttle, and this is with a t67, some vids are on u tube,
97 sc300-gte/v160
Old 02-26-2012, 04:21 PM   #177
bullfrogg0
bullfrogg0's Avatar
Why would a jdm cluster make a difference?
Old 02-26-2012, 07:21 PM   #178
CDD200
well it will be a white face, so i do not have to change them, 7k red line closer to what the 2j is, and has 180 on the speedo, just have to adj it to read in mph, i swapped the faces on my old one and it just did not work right again (tach would not stay with the motor) this way i do not have to change anything
97 sc300-gte/v160
Old 03-05-2012, 09:03 PM   #179
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
http://www.youtube.com/watch?v=GU09X2mcQZw
Not sure how to embed.
Going to the track to see what she'll do in 2 weeks woooo. Hoping to get redyno'd soon and get the numbers to prove it's well into the 600's lol
http://i98.photobucket.com/albums/l258/Deftec/signew-1.jpg
Deftec is offline   Reply With Quote
Old 03-05-2012, 09:48 PM   #180
bullfrogg0
bullfrogg0's Avatar
Try less burnouts on the dyno for more power lol.
