09-02-2011, 11:53 AM | #1 |
Rear diff debate
Im looking to get rid of my boring one way diff soon and i know that there are plenty to chose from. There are aftermarket ones but i heard they are noisy and are really expensive. I could weld it also or use them from a j30 or r200v. I know that there are more but im not sure what they are. This is just a simple thread to hopefully get some insight on which one you guys have used and which is they best and most reliable without having to do any other mods to make them fit.
09-02-2011, 11:54 AM | #2 |
Trader Rating: (58)
Feedback Score: 58 reviews
146 posts in, you can search this stuff. Look up VLSD, as it seems you're looking for cheap cheap cheap
09-02-2011, 11:57 AM | #3 |
i know that they are out there but every time i look its based on one and not a couple at a time. and not really cheap i dont mind spending extra if i have to
09-02-2011, 12:01 PM | #5 | |
Trader Rating: (38)
Feedback Score: 38 reviews
Go with a 1,5 way, the lock isn't as bad as a 2 way. If that's too much for you, a nice VLSD would do fine. Just make sure that thing still works, it'll be just as bad as an open diff if it doesn't work. |
09-02-2011, 12:08 PM | #7 | |
Trader Rating: (25)
Feedback Score: 25 reviews
I love my Tomei 2 way. It's a 240, if you complain about the noise, this isn't the car for you.
09-02-2011, 12:23 PM | #9 |
From my experience, most people in SoCal used to choose between
Nismo KAAZ Cusco and Tomei Nismo had some diffs that were pretty mild without clunks, I think it was called Nismo Street or something like that. I bought a used 2-way that was like this once from a shop called G-Speed, and supposedly that was what was inside. They've also got some pretty aggressive ones that are adjustable. I know some people on here had/have it; I believe it was called the Nismo SSS Differential. And then there was Nismo GT, which was supposedly really aggressive. Depending on your connections, you could get a Nismo diff in the sub $1000 range, or you can get lucky and find a used diff and work with that. I bought my used Nismo diff for $600 at the time. Just make sure it's not VERY used, or else it'll function poorly. Also, I think certain Nissan dealerships that carry Nismo diffs may also be able to get service parts for you if you ever need them. Check with your dealer on that one... KAAZ was straight-up super aggressive and super clunky. I remember seeing everyone at Drift Day events rolling around the parking lot with KAAZ diffs clunking SUPER hard, and it looked like some shat was about to break. A friend of mine has a 1.5-way KAAZ diff in his FC, and it's worked just fine for him at some events. $1000+ but the good thing is that you can get service parts here in the USA, like new clutch plates when you eventually wear them out. Tomei was good. I drove a friend's car with a 2-way Tomei once. All I can say is that it didin't clunk as loud as the KAAZ diffs I've seen, and the locking was pretty aggressive/immediate. You used to be able to find a hookup for these brand new for about $700 or $800 if you knew the right guy, but I doubt anything like that exists anymore. Either that or I've just been out of the loop for too long. Right now, I'm using a Cusco RS differential, and the locking is a lot more gradual (depending on throttle input) compared to the Tomei one I tried. I like it the best so far, and when it wears out, I will be most saddened. Price is ... I dunno... I bought this one used as well and has worked great for years. The only real thing to look at if you want to be picky are the designs of the differential for things like initial torque. Every clutch-type diff has some sort of spring design on the inside that will set them apart from each other, from a cone-spring like the Cusco MZ (and i think Nismo) to a set of small coil springs like the Cusco RS. In the end, get what you can get at a price that is acceptable. Everything I listed is WAY better than VLSD and WAY better than welded, both of which I've also ran on. Anyways, my 2cents. Take from it what you will.
Drifting is just a compromise between you and your car. |
09-02-2011, 01:01 PM | #10 |
I bought a Nismo street with about 2,000 miles on it and absolutely love the thing. It's pretty quiet in terms of street driving and locks pretty well when you want it to. My friend has the same diff but his has like 10k miles on it and that shit clunks like crazy but still locks well.
09-02-2011, 03:15 PM | #15 |
09-02-2011, 03:49 PM | #17 |
Trader Rating: (24)
Feedback Score: 24 reviews
You just use the center section and bolt the stock ring gear to it, thus retaining 4.08.
I've had two torsens, a nismo 1.5 GT and now have a 1.5 giken. Giken > all. |
09-02-2011, 04:11 PM | #18 | |
Why did you have two torsens? Did the first one break? And what do you like about the OS Giken that makes it > all? lol Sorry to interrogate, but am just curious about that brand, since I've never tried OS Giken before.
09-02-2011, 04:16 PM | #19 |
Trader Rating: (24)
Bought torsen, bought 1.5, thought 1.5 broke, bought another torsen, bought giken.
Giken = super smooth engagement --smoothest of any clutch type I've felt. Also doesn't require break-in and probably never need a rebuild. And I far prefer a clutch type at autox to a torsen. |
09-02-2011, 05:42 PM | #21 |
I'm not really sure but i took the ring gear off my stock open diff and used it on the S15 HLSD, although when you're doubling or even tripling the stock hp levels a taller gear might be pretty nice...
09-02-2011, 08:29 PM | #22 |
Just for the record, Kaaz and Tomei are the same thing. Tomei Diffs are made by Kaaz.
Clunking or not clunking depends a lot on the fluid and initial setting of the LSD (determined by the arrangement of the plates inside). Mine is set to 80% and only really clunks after driving hard or on really hot days. If I had set it to 60% it would probably almost never clunk, and on 100% it would probably clunk constantly. |
09-03-2011, 04:44 AM | #26 |
i didnt read any replys
but im just gonna say, welded diff is not as bad as alot of people make it seem. Its not like ZomGzzz its raining im g0ing to wr3ck!!11!!!1. its great for drifting but i will also say, ive been dailying a welded for 2 years and at this point, i am dead tired of it. it fucks EVERYTHING up. transmissions, bushings, bearings, pretty much everything in your drivetrain. doesnt happen fast, but it'll creep up. |
09-03-2011, 12:03 PM | #27 |
Thanks for all the insight!! Now i'm leaning towards the s15 hlsd. Did some research and seems pretty straight forward installation, good price and an awesome final drive! I'm using it as a daily that's why i was wondering about the clunking and such.
09-03-2011, 12:23 PM | #28 |
09-03-2011, 12:24 PM | #29 | |
U wont regret it bro!!!! Just remember to get s15 input shafts to. Ull need them if u get just the lsd unit and not the whole pumkin |
09-03-2011, 03:06 PM | #30 | |
