Old 11-03-2022, 12:06 PM   #1
adictd2b00st
adictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to beholdadictd2b00st is a splendid one to behold
Send a message via AIM to adictd2b00st
Harness/ECU combination
Hey all,
So I had started going through the wiring on my s14 (I did not personally do the swap on this one) years ago. It ran but was kinda hacked wiring wise, so I started with ripping out the old and brittle harness. I?d be lying if I said I didn?t forget all the details since then. It?s an S13 red top in an S14 zenki chassis.
Long story short, I want to make sure I get the right ECU for this car. From what I can tell the wiring at the ECU connector on the harness I put in (a second hand WS harness) matches a 62/63 pinout.
I know the wire colors won?t necessarily always match but pin location/function would be best indicator. I made a quick spreadsheet (I tried to snip/attach as a picture but not having any luck) does what I?m seeing seem right? I have empty locations for pins 5, 10/11/12, 24, 26, 28, 33, 42, 44, 45, 102, 105, 111, 114/115.
If you have a good way for me to confirm by, let me know and I?m up for checking it. Been far too long really want to get this thing running again!
adictd2b00st is offline   Reply With Quote
Old 11-04-2022, 05:15 AM   #2
OMFGeofffff
OMFGeofffff's Avatar
OMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really nice
https://www.wiringspecialties.com/ecu-pinouts/
Check for continuity on ignition wires from ecu connector to ignitor connector. I believe those are the main differences between 64-pin ecu's.
OMFGeofffff is offline   Reply With Quote
