03-22-2013, 02:57 PM | #1 |
Kylin store - new hydraulic drift handbrake
NEW HYDRAULIC DRIFT HANDBRAKE
Material: aluminium&steel Size: 53*41*31 Certification: TSCar Make: universal color:RED,BLUE,PURPLE,BLACK,GOLD Hydraulic Drift Handbrake Kit is a high quality aftermarket handbrake that is essential for any drift or rally vehicle. This is a universal product that can be installed into any vehicle and is specifically designed for D1, Rally, or Track racing vehicles. You should not replace or remove your standard emergency brake. This hydraulic brake is used for drifting, not parking. The drift handbrake allows the rear tire to be fully locked and will make your vehicle slide to the side. The handbrake lever can either be installed in a vertical or horizontal position for easy access while driving. High Quality Product Constructed with CNC Aluminum 3/4" Master Cylinder Reservoir Universally Installed on Any Vehicle Specifically Designed for D1, Rally, or Track Racing Vehicles Will Fully Lock the Rear Tires Handbrake Lever can be Installed in either Vertical or Horizontal Position Available with either a 3/4'' reservoir Drifting and rally driving requires extensive use of the handbrake , and eliminates the weakness in standard cable type handbrekes. This hydraulic handbrake requires a lot less force to lock the rear brakes when desired. $70 shipped direct $90 shipped from me (cover extra costs) Please allow 4-5 days for processing the order and 10-12 business days for it to arrive at your house (TIMES MAY VARY BASED ON BEING IN STOCK OR DEALING WITH HOLIDAYS).. you will be supplied a fedex tracking number once one is available. you will have your item within 30 days or your money will be refunded.. I'm dealing with other countries on this guys so some times I need a day in advance on money we are 12 hours behind them. so I can place the order when I talk to them... thanks you can also reach me on aim : kylinperformance also please pm your paypal.com info and I'll send you invoices to make you feel a little more comfortable dealing with me.. also allows me to keep track a little better of who's getting wait.. and I can keep track of tracking numbers better... |
