Old 09-14-2012, 04:52 PM   #1
kiriyama
kiriyama's Avatar
kiriyama is an unknown quantity at this point
Tail Lights Dont Turn Off
Since i bought my S13 back in 09, there has always been an unidentified drain on the battery, so i had a quick disconnect installed on the battery to counter that. While i was overseas my buddy installed my new S14 SR into my S13, but every time i connect the battery, the tails come on automatically. The key isnt turned at all, just power to the battery. Ive checked the fuses, and gone over all the grounds i can find, but i havent found a solution yet. My next plan is to pull up the carpeting and check to see if the wiring may have become frayed or damaged, but before i do that i thought id ask in here. Also, i looked into the button behind the brake light, and it seems to be fuctioning fine. Reverse lights dont come on, ever, but the running/brakes do whenever i attach the battery. Thanks for any help guys.
FOR SALE! FRIDE Vios III http://zilvia.net/f/sale-items/45107...eat-trade.html
kiriyama is offline   Reply With Quote
Old 09-14-2012, 05:22 PM   #2
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
Do they come on as if the brake pedal is depressed? Or just running lights staying on?
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 09-14-2012, 06:02 PM   #3
nyka435
nyka435 is an unknown quantity at this point
There's a little button on the brake pedal that turns the lights off when there is pressure on it. If the little plastic piece falls off then the brakes lights stay constantly on.
nyka435 is offline   Reply With Quote
Old 09-14-2012, 06:31 PM   #4
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
If they are on as if you were pushing the brakes it's the little rubber behind the switch on the brake pedal
Old 09-14-2012, 06:56 PM   #5
kiriyama
kiriyama's Avatar
Alright, i thought i looked good, but ill double check tomorrow to see if that piece is missing
Old 09-15-2012, 05:58 PM   #6
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
I had the same problem a while back and it was the plastic plug came off. Easy fix ran a small nut and bolt to fix it
buentellomma is offline   Reply With Quote
Old 09-15-2012, 06:27 PM   #7
Bboyswift
Bboyswift is an unknown quantity at this point
i had the same problem on my hatch. i jb welded a nickel where the plastic peice was and i never had a problem after that.
Bboyswift is offline   Reply With Quote
Old 09-15-2012, 06:32 PM   #8
humilde_s13
humilde_s13's Avatar
humilde_s13 is an unknown quantity at this point
had same problem on my coupe..crazyglued a quarter in there lol
I will give you my pistol ammo at the speed of light towards your doom
humilde_s13 is offline   Reply With Quote
Old 09-17-2012, 09:29 PM   #9
SX-f@n@t!c
SX-f@n@t!c's Avatar
SX-f@n@t!c is an unknown quantity at this point
alright so i have the same problem except my running light stay on and my brake light dont turn on at all??
S13 coupe Sr20det
SX-f@n@t!c is offline   Reply With Quote
Old 09-17-2012, 09:42 PM   #10
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
^^ Wrong bulbs?? Or the little soldering on the bottom of the bulbs melted also check the connectors for the bulbs, they have a habit of melting too
Mishkin_707 is offline   Reply With Quote
Old 09-17-2012, 10:07 PM   #11
nyka435
i superglued 3 pennies together and superglued it to the bracket. It's been about a year with no problems
Old 09-18-2012, 09:25 PM   #12
SX-f@n@t!c
SX-f@n@t!c's Avatar
so i went to the junk yard and got the whole tail light assembly since the connecters were melted so my lights turn on fine now..but how do i fix the fact that even when the car is turned on my running lights dont turn off so everytime i turn off my car i have to pop the trunk and disconnect the tail lights????
S13 coupe Sr20det
Old 09-18-2012, 11:55 PM   #13
SX-f@n@t!c
SX-f@n@t!c's Avatar
Nevermind I fixed it lol
S13 coupe Sr20det
Old 09-19-2012, 01:18 AM   #14
TheRealSy90
TheRealSy90's Avatar
So what was it?
Such a good signature.
Old 09-21-2012, 01:41 PM   #15
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
like everyone was suggesting, most likely the actuator on the brake pedal not making contact with the switch. i just double side taped 2 pennies do it. you will know what everyone is referring to once you get in there and look.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
help a veteran, s13, tailights, wiring body harness s13
