Old 03-21-2002, 04:36 PM   #1
AZN GTR
AZN GTR is an unknown quantity at this point
Would premium gas be any better than regular for normal driving?
AZN GTR is offline   Reply With Quote
Old 03-21-2002, 04:47 PM   #2
black0ut
black0ut is an unknown quantity at this point
Send a message via ICQ to black0ut
It could be worse.
Notice how I gave just about as much info as you did? &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> &nbsp;What type of gas you get depends on your compression ratio, mods on the car, etc. There's no one greatest type. In fact, my stock car feels stronger using the lowest octane than the highest. How old is the engine, is it turbo, etc. It all depends on the car. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
...contact me...
black0ut is offline   Reply With Quote
Old 03-21-2002, 04:48 PM   #3
240sxracer
240sxracer is an unknown quantity at this point
depends, if your car is stock then its a waste of money
if your car is modified then it would be a good idea(higher octane rating less chance of detonation)
1990 240sx FastBack
1965 Ford F100
240sxracer is offline   Reply With Quote
Old 03-21-2002, 04:51 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
not necessarly.... although you might suffer from slightly less performance than with premium.
premium grade fuel (higher octane) has more burn resistance, so it's less prone to pinging from advanced timing or detonating from high compression. &nbsp;basically, you can expect a "better burn" in a high performance engine using higher octane fuel. &nbsp;
for normal driving, where you aren't necessarily trying to get the most performance out of your engine, you should be fine with normal grade fuel, although in a sense, premium would be "better".
AceInHole is offline   Reply With Quote
Old 03-21-2002, 05:02 PM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
Nevermind the Owners Manual says use premium gas.
and I quote:
"Recommended fuel:
Unleaded premium gasoline, at least 91 AKI number (RON 96)
If unleaded premium gasoline is not available, unleaded regular gasoline with an octane rating of at least 87 AKI (Research octane number 91) can be used.
However, for maximum vehicle performance, the use of unleaded premium fuel is recommended."
All I have to say is RTFM!
sykikchimp is offline   Reply With Quote
Old 03-21-2002, 05:13 PM   #6
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
Actually, 89-90 models will have this in their owners manual:
Recommended Fuel:
Unleaded gasoline with an octane rating of at least 87 AKI (RON 91)*1
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 03-21-2002, 05:14 PM   #7
twofortysx
twofortysx is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ Mar. 21 2002,4:02)</td></tr><tr><td id="QUOTE">Nevermind the Owners Manual says use premium gas.
and I quote:
"Recommended fuel:
All I have to say is RTFM!</td></tr></table><span id='postcolor'>
LOL, I made a post about this a while back. &nbsp;I was noticing decreased performance in my car when I switched from 91 to 87 and found that blurb in the owners manual. &nbsp;I wish the damn search function was working.
&quot;Now I'm in 3rd and you think that's quick? Wait till I hit 5th.&quot;
- 98 s14 -
twofortysx is offline   Reply With Quote
Old 03-21-2002, 05:15 PM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
yeah. this should be in the FAQ
edit - thanks transient. &nbsp;I knew someone would fill that in..
Old 03-21-2002, 05:41 PM   #9
tnord
tnord's Avatar
tnord is an unknown quantity at this point
get ahold of the newest issue of european car, it shows the benefits of high octane fuel, car and driver, european car, or SCC did a tech article on the reasons to run high octane as well a few months back
you have never seen a smoother dyno pull than the turbo M3 on 104 octane
tnord is offline   Reply With Quote
Old 03-21-2002, 06:04 PM   #10
onebadm5
onebadm5's Avatar
onebadm5 is an unknown quantity at this point
Send a message via ICQ to onebadm5
as some other forum members pointed out, higher octane content relates to how fast the fuel burns. high octane fuel use is only justified for high compression or forced induction applications, especially under boost, cause higher octane also resists pre ignition or detonation which is prevalent as the boost increases.
onebadm5 is offline   Reply With Quote
Old 03-21-2002, 06:09 PM   #11
DrDubbleB
DrDubbleB is an unknown quantity at this point
Doesn't lower octane gas also contribute to more condesation in your gas tank? &nbsp;Condesation would = dirty fuel system, and less performance, also would heighten the chance of detonation I would think. &nbsp;I don't know, I heard that somewhere, I'm probably just speaking out of my ass, I don't know much about fuel.
DrDubbleB is offline   Reply With Quote
Old 03-21-2002, 08:10 PM   #12
Tuck&Poke
Tuck&Poke is an unknown quantity at this point
Send a message via AIM to Tuck&Poke Send a message via Yahoo to Tuck&Poke
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (onebadm5 @ Mar. 21 2002,7:04)</td></tr><tr><td id="QUOTE">as some other forum members pointed out, higher octane content relates to how fast the fuel burns. high octane fuel use is only justified for high compression or forced induction applications, especially under boost, cause higher octane also resists pre ignition or detonation which is prevalent as the boost increases.</td></tr></table><span id='postcolor'>
actually the octane has to do with how easily the fuel ignites not how quickly it burns. &nbsp;the higher the octane the harder it is to accidentally ignite it. &nbsp;it was found that on some cars using higher octane fuel when lower was recomened reduced preformance. &nbsp;it happened on a dodge ram and a honda accord. &nbsp;some cars got better hp though so it depends
Tuck&Poke is offline   Reply With Quote
Old 03-21-2002, 08:32 PM   #13
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
where i live, there is only 87, 89, 93. i've used 93 since i've had my car, and when gas prices went up, i went to 87 with a 1/3 tank of 93. throttle response increased 'barely' at lower RPM. then the next gas price inflation came...on my second tank of 87 octane my car was pinging like crazy! i had to drive to the gas station at high rpm to keep the motor from blowing. the SOHC motors do not have a knock sensor so it will not alter the timing. i am forced to use 93 octane and i don't have a problem with it.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 03-21-2002, 09:11 PM   #14
fridexter
fridexter's Avatar
fridexter is an unknown quantity at this point
fridexter is offline   Reply With Quote
Old 03-21-2002, 10:33 PM   #15
200sx
200sx is an unknown quantity at this point
Ok folks.. heres some food for thought: &nbsp;An old (93 or so) VW mag I read had an article about premium/regular gas comparisans. &nbsp;There was an Audi (I think) that was running poorly, but no mechanical/electrical problem could be found. &nbsp;When the dealer called Germany, the german tech said something like "Ya, is dat Dishwasher Soap you use for &nbsp;gasoline over there." (or something to that effect). &nbsp;I have heard this kind of thing from others too. &nbsp;Basicaly, a higher octane rating is a CLEANER and LONGER burn. &nbsp;Yes, that means the same amount of premium gas will last longer that regular. For example, a table spoon of regular will burn for say... 10 seconds. &nbsp;The same size spoon, with premium, will burn for 15 seconds. &nbsp;(not exact here, just trying to explain the concept) &nbsp;Premium will also leave less residue and deposits in the cylinder head/pistons, in turn prolonging the life and power of your engine.
I know I am crazy, but hear me out!
200sx is offline   Reply With Quote
