Old 05-13-2011, 05:50 PM   #6061
Torq_Meister
Torq_Meister's Avatar
Torq_Meister is an unknown quantity at this point
Originally Posted by Torq_Meister View Post
is wiring for the 5th gear sensor required when doing a 5 speed swap? does it matter if its for manual or auto ecu? i have been running an auto ecu after my 5 speed swap and i never wired the 5th gear sensor because i heard it wasnt required. but i just picked up a manual ecu and someone said that i needed to wire the 5th gear sensor if i was to run the manual ecu?...
Dont use the 5sp ECU stay with the Auto, No rev limiter or speed cut.
i wanted to use the manual ecu to remove the check engine light. Also the Automatic ECU only bypasses the governor which sets the speed limit, the rev limiter is still set at 6500.
Torq_Meister is offline   Reply With Quote
Old 05-13-2011, 07:35 PM   #6062
chiboy002
chiboy002 is an unknown quantity at this point
the s14 5-lug brembo rotors they sell on frsport are for non-abs cars right?
they seem to suck at putting proper info in their product descriptions
street dancer.
GLEAM
Old 05-13-2011, 08:23 PM   #6063
heavyd06
heavyd06 is an unknown quantity at this point
so my s13 shell had no positive cable(meaning no lower harness), i bought a lower harness and that didnt had the positive cable either. so my question is what should i do with two plugs that originally conected to he battery positive post??
heavyd06 is offline   Reply With Quote
Old 05-14-2011, 08:29 AM   #6064
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
OK:
Need less offset on my front wheels in order not to run so much neg camber to fit my wheels under my fenders. (18x9 +13 w/ 225/35)
I am running S14 LCA's/5 lug on my S13
can I Swap back to S13 LCA's and Move the S14 Knuckle Over to the S13 and have less Offset?? Which Ball Joint do I need???
S14 LCA's allow 10mm more offset on a S13???-
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 05-14-2011, 08:36 AM   #6065
l240driver
l240driver is an unknown quantity at this point
okay guys im in need of some serious help with my SR20det its an S13 SR in a hatch, i recently did an engine swap. The problem is that it boggs out between 4500-5000 rpm ant it wont rev up any more than that when its running no matter what gear im in. It seems like its getting fuel cuts or not enough air. I have searched and tried everyones options on this subject but nothing seems to take care of the problem. My engine is stock nothing upgraded besides fmic, an the exhaust. ive been having a problem since the engine swap was done, heres a list of what i have tried to resolve my problem.
i have tried two different engine harnesses
2 different sets of stock injectors
3 different sr20det mafs
i have check an recheck for boost leaks
i have tried two different walbro fuel pumps
ive change out my fuel filter for a 300zx one twice
i added a fuel presure regulator thinking the stock one was bad
ive change out and gapped my spark plugs
i have tried 2 different ECU's
ive change out my CAS twice
i have check my timing i tried advancing the time
I feel like im out of options guys let me know if i missed something ill keep working on it till then.
l240driver is offline   Reply With Quote
Old 05-14-2011, 10:35 AM   #6066
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
couldnt figure out how to quote everyone who answered my question, but thanks to all for the input. i didnt end up getting the car, because as you guys said it was too high. decided to buy a shell and start my own project.
GL Chrillz is offline   Reply With Quote
Old 05-14-2011, 11:14 AM   #6067
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
What's the thread pitch on the 2871r for the turbo elbow studs?
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 05-14-2011, 04:28 PM   #6068
JDM SPUG
JDM SPUG is an unknown quantity at this point
trying to get info to help my friend.
He has an S14 and is putting in an s14 sr20det. he asked me where he can have his harness done. does any1 know of a place that does a clean job with doing harnesses?
Sorry i don't know the correct term for putting the 2 harnesses together.
Thanks
JDM SPUG is offline   Reply With Quote
Old 05-14-2011, 05:48 PM   #6069
Wake
Wake's Avatar
Zilvia Sponsor
SR20DET Wiring Harness Services
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 05-14-2011, 06:03 PM   #6070
MidwestMyriad
MidwestMyriad's Avatar
MidwestMyriad is making a name for him/her selfMidwestMyriad is making a name for him/her self
Thumbs up
The MQ button next to the quote button is for multiple quotes.
@MMyriad
MidwestMyriad is offline   Reply With Quote
Old 05-14-2011, 06:06 PM   #6071
JDM SPUG
Thanks WakeBHR
Old 05-14-2011, 08:06 PM   #6072
namfbroh
namfbroh is an unknown quantity at this point
What type of power steering fluid should I use in my SR redtop? I've read around and in the FSM it seems Dexron should be used, but I've also read that ATF works just as fine. I have ATF, but I don't have Dexron. Does it really matter? I just want to be sure before I go to the store and buy some.
namfbroh is offline   Reply With Quote
Old 05-14-2011, 08:56 PM   #6073
BlackestCoupe
BlackestCoupe's Avatar
BlackestCoupe is an unknown quantity at this point
How many posts do you need to make a FS thread?
BlackestCoupe is offline   Reply With Quote
Old 05-14-2011, 09:00 PM   #6074
chiboy002
300,000
read the stickies
street dancer.
GLEAM
Old 05-14-2011, 10:16 PM   #6075
chiboy002
i just replaced my headgasket and now my s13 ka24de is overheating... >.>
i greatly doubt its the headgasket, unless i warped the head on removal/install
i've heard ka24de are notorious for developing air pockets, how can i go about making sure there are none? as well as trying other methods to fix it...
i filled it up while it was on an incline with the bleeder screw open so idk
street dancer.
GLEAM
Old 05-14-2011, 10:24 PM   #6076
Wake
Wake's Avatar
First thing i would always do (if you havent) reaplace the ECT's both the 2 and 1 wire.
If that doesnt change anything, i would next suspect water pump or therno.
As far as just burping procedure, I just fillup the radiator slowly with the engine off, until it is full, then run the engine and continue filling as more air escapes. After the radiator is full with engine running, I put the rad cap on and open the bleeder until solid colant/water come out. close the bleeder.
I have never had over heating problems, and I pretty much always do it the same way.
S.P.P.S. Member #00
Old 05-15-2011, 12:30 AM   #6077
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Would it be bad if I mixed power steering fluid and Nissan atf? The previous owner of my car put power steering fluid into the reservoir instead of atf. I have a leak and its super low as to where I think the pump is pulling in air. So I was wondering if I can just top it off with atf even though it has power steering fluid in there already without damaging seals, the rack, or the pump. Thanks.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 05-15-2011, 12:32 AM   #6078
S14DB
AFC #1
S14DB's Avatar
http://zilvia.net/f/forum-suggestion...look-here.html
If you are only here to sell things I suggest you go somewhere else.
Old 05-15-2011, 12:44 AM   #6079
jamg
what is preloding a coilover? adjusting the tension of the spring within the coilover itself?
Old 05-15-2011, 01:36 AM   #6080
kalypso123
(ノಠ益ಠ)ノ彡
yes, compressing the spring with a clamp, and then putting the coilover back together with a preloaded spring.
People do this in an effort to lower their car more.
but its unnecessary :0)
Old 05-15-2011, 03:05 AM   #6081
Razi
Razi is an unknown quantity at this point
Open the rad cap.
Cut a soda or water bottle in half and flip it.
Fill your new DIY funnel with coolant.
Run the engine until bubbles stop coming out of the bleeder screw, then close the bleeder screw.
Run the heater full blast, that should burp up any bubbles in the heater core and suck up excess coolant you have left in your funnel.
Also squeeze the radiator hose once in a while to release any bubbles in there.
Hopefully, that works.
Razi is offline   Reply With Quote
Old 05-15-2011, 11:55 AM   #6082
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
For those of you who have done the Z32 brake swap with the new e-brake lines. Is it a must to you have some sort of bracket for the e brakes to sit on before connecting to the main line (the T-bar)?
For Sale #1 | For Sale #2
Old 05-15-2011, 12:23 PM   #6083
chiboy002
what's an ECT? Im not very good with acronyms... sorry lol
if its engine coolant temp sensors, i don't pay attention to the one on the gauge cluster cause its shit, i have an aftermarket one.
Originally Posted by Razi View Post
Open the rad cap.
the thing is though, i filled it up with a funnel until a stream of water came out of the bleeder screw, closed it, kept filling. Took off top hose, filled it then reinserted and filled again.
Should i drain it all and re-do it? I doubt its my tstat or my pump cause it was running perfectly fine last week, but idk. I'm using an electric gauge and it was at 188* before and it hit 230* yesterday while i was on my way home
street dancer.
GLEAM
Old 05-15-2011, 12:36 PM   #6084
l240driver
Does any one have any idea on whats happening to my engine
Old 05-15-2011, 04:42 PM   #6085
s14owner95
s14owner95 is an unknown quantity at this point
Send a message via AIM to s14owner95 Send a message via Yahoo to s14owner95
Does anyone know where Nissan usually pulls it's Tach signal from? Is it the CAS, injectors, MAF (obviously that one is a joke) but I'm just curious..
If it's different on different motors, would anyone happen to know what the KA uses and what the RB uses?
s14owner95 is offline   Reply With Quote
Old 05-15-2011, 05:44 PM   #6086
Nick 240
Nick 240 is an unknown quantity at this point
95 ka into s13
hey guys. I'm swapping a 95 s14 obd1 ka engine into my s13. I know i have to swap my intake manifold, exhaust manifold, distributor, and maf. Is there anything else i have to swap?
Thanks in advance.
Nick 240 is offline   Reply With Quote
Old 05-15-2011, 05:51 PM   #6087
RentonD
RentonD is an unknown quantity at this point
Can anyone tell me why there is a gap between my hood and grill?
RentonD is offline   Reply With Quote
Old 05-15-2011, 05:59 PM   #6088
chiboy002
Thanks Razi & Wake, it got fixed
i wasn't bleeding it with the engine running so no air was coming out lol
RentonD: looks like your car was in a front end collision before you bought
street dancer.
GLEAM
Old 05-15-2011, 07:08 PM   #6089
Irresistible
Originally Posted by RentonD View Post
[IMG]pic
Yeah... what chiboy said. I'd take of front bumper off and headlights out and try to find what's bent or whatever the case may be.
Also, reposting this question, I'm afraid I'll fuck up my p/s if I don't add ATF. But I don't wanna add more p/s fluid.....
Old 05-15-2011, 08:00 PM   #6090
afiser
afiser is an unknown quantity at this point
talking 240sx's
would a '98 manual lower harness work in place of a '95 manual lower harness?
afiser is offline   Reply With Quote
