05-31-2006, 12:30 PM | #151 |
lol, its not that I dont trust you just double checking before i order them hahahaha
Anybody got a used set of z33 track rotors f/s????
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
05-31-2006, 05:51 PM | #152 |
If anyone is interested, I have a contact who already has the hubcentric rings made for the cobra rotors. They use them over at maxima.org with Z32 calipers. I also have a 92 Maxima SE 5-speed.
Let me know if you can't find them on .org.
I have car? |
06-01-2006, 04:56 PM | #153 |
anyone in socal with this setup btw? reason i ask is because i would like to test wheel to caliper fitment on someones setup, "hopefully" my main concern is obvioulsy the front.. EVO rotor and STI caliper.. how much different is it then the Z32 set-up? If i were to check on someone's STI this should do the trick right? although STI rotors being 2mm less wide then the EVO, if they clear basically the other set up should as well? Any thoughts?
i tried the above fitment on an 04 EVO and the wheel seems like it will clear the caliper, but it didnt go all the way on i think because of the hub diameter.. anyone know whats EVO's hub diameter? At the same time, if these front rotors with on S14 hub, the S14 hub must be smaller.. so the rotor will probably have some play? although this combination still works fine with the STI caliper? i tried to put on a wheel w/skyline hub bore, 17x9.. i'm assuming all nissans share this bore.. i understand that it didnt fit on EVO as its problably different.. but makes me think how come this EVO front rotor works on S14 hub and that it doesnt have play? any advice? Last edited by hybrid_eg; 06-02-2006 at 10:06 PM.. |
06-04-2006, 01:49 AM | #155 |
Shermantank, you will be added.
To all the members that want this bracket please email me at [email protected] In the subject please put Big Brake Bracket. I will reply with payment information. price will include shipping and the coating. Paypal or money order will be accepted. You will be required to send only half of the amount and once they are made you will be asked to send the rest. it should take no more than a week to manufacture them. Shipping will be via EMS. It will be trackable. I hope I am not breaking any rules with this. |
06-12-2006, 12:30 PM | #156 |
One last bump from me to see if any more
are interested in the bracket. We got two member interested 4 sure and one that will wait for more to jump on. With three members price is 300 shipped. 10 will bring the price down to 250 shipped. |
06-18-2006, 09:57 PM | #157 |
Finnally my brakes installed
Once again these are cadillacs CTS v calipers, with my own bracket and hawk hp + brake pads. I originally posted i was going to use the cobra rotors but after much deliberation, and the fact that i got some powerslot cryoed rotors pretty cheap i decidede to use evolution rotors. I had to move one of the bolt holes about 4 mm. I still have the stock master cylnder and stock rear brakes so its definitly over boosted and biased tremendously towards the front. As for performance after i bedded in the rotors and pads i took it out and did a bunch of hard stops from 60 - 0 and 120- 0 and it stops on a dime. I run falken azenis rt615 235/45/18 in the front and was able to lock the brakes at 120 , which i couldnt do before on z32 and hawk pads. I cant wait to see how it evens out when i do the rears. enjoy!!!
06-19-2006, 02:37 AM | #160 | |
btw, is that a 57 nomad?
if you're not original owner, you're just another bandwagoner |
07-14-2006, 05:23 PM | #162 |
pics of the bracket and w/o wheels finnally.
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com Last edited by gsracer; 11-03-2006 at 09:21 AM.. |
07-14-2006, 06:01 PM | #163 |
Gsracer, nice setup. Your rotors are on the wrong side if you haven't swapped them yet. When looking at it, the slot should start out and then go towards the middle. Swap the right rotor onto the left and vice versa.
I'm driving fast -drew |
07-14-2006, 06:20 PM | #164 | |
actually they are on the right way. Power slots are like that, they specificly stamp the left and right, I called them because at first I thought they where stamped wrong but they told me thats hw they go/
11-08-2006, 09:57 AM | #170 |
it was alot of measuiring and slight modification to the caliper took me about a week to sit it on with as little pad over hand as possible, it would probably sit better with a 350z rotor that is slightly bigger
12-11-2006, 11:55 AM | #171 |
is their anything in the way of doing this same setup on a 4lug?
front; sti calipers, evo rotors(redrilled for 4lug), and the bracket. rear; sti calipers, evo rotors(redrilled) and do i need the bracket? what about the z33s? same thing? |
12-11-2006, 07:23 PM | #172 |
Ok, im about to maybe pick up a set of evolution brembos, what can i do in terms of brackets, the Sti = evo im assuming from this thread, and then just use the rotors as well?
12-11-2006, 08:57 PM | #173 |
i'm putting front evo brembos on my S14 but utilizing track 350z rotors...bracket is very similar to the one on this post, i can post pics tomorrow night. you can't beat a set of front huge brembos for $350!! there is NO demand for these suckers since all the evo guys gottem
12-12-2006, 05:16 PM | #174 |
Yeah, i might be able to get a front pair of calipers and rotors for a ben and a half, which would end up way cheaper than z brakes, which i already have for the rear sitting in my garage. Then a front 5 lug conversion and ill be set.
12-12-2006, 05:52 PM | #175 |
my brackets are different only b/c i'm using Z33 track rotors, i was going to mount them today but i seemed to have lost my locking lug socket not good!!!
12-12-2006, 07:54 PM | #177 |
Remember the bleeder screws go on the top...
12-12-2006, 08:58 PM | #179 |
brake setup looks great! i've got a question though.
Have you considered running a 6061-T6 spacer instead of the 4340? Reason I ask is that is because the bracket looks heavy, and you want to reduce the amount of unsprung mass as much as possible to increase your wheel hop frequency. |
