Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 09-12-2013, 09:38 AM   #1
StreetRacerMotorSports
StreetRacerMotorSports's Avatar
StreetRacerMotorSports is an unknown quantity at this point
StreetRacerMotorSports.com Free US Priority Shipping
$95 Shipped US Priority
AEM High Flow In-Tank Fuel Pump Features:
Designed for high output naturally aspirated and forced induction EFI vehicles
In-Tank design
Tested to flow 320 lph @ 43 PSI
39mm diameter fits most applications
Offset inlet design eases installation
Each pump individually tested
For gasoline vehicles (pump life may be diminished when used with E85 fuel)
Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead
$120 Shipped US Priority
Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline
In tank design
Each pump is tested to flow 320 lph @ 43 PSI
$187.23 Shipped
OVERVIEW
AEM’s legendary Wideband O2 Air/Fuel UEGO Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. This gauge-type controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. All AEM digital gauges feature a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
$359 Shipped
WHY YOU WANT ONE
The AEM Water/Methanol Injection System comes loaded with more STANDARD features and high quality components than any other comparably priced injection system on the market today. The AEM injection kit comes with a 1 gallon tank with built-in low level indicator. The "Boost Safe" injection readiness system is standard in all AEM Water/Methanol Injection Systems. An integrated check valve in the nozzle prevents unintended fluid flow. One injector and two interchangeable nozzles are included to cover a wide range of potential horsepower levels and 20 feet of injection tubing facilitates installation on almost any vehicle.
PRODUCT FEATURES
1 Gallon tank with built in low level switch
Boost referenced progressive controller
“Boost Safe” readiness safety system
Check valve integrated into nozzle to prevent unintended fluid flow
One injector and two nozzles to cover a wide range of HP levels
High Pressure 200psi Recirculation-style pump
Progressive Controller: Start Injection Boost 1-11psi. Full Injection Boost 6-39psi
LED dash light for system status and low fluid warning
20 ft. of injection tubing
Message us for more details
or e-mail [email protected]
StreetRacerMotorSports is offline   Reply With Quote
