Old 01-06-2013, 07:01 PM   #2701
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
On my hatch, an 18x10 +30 with a 285/30/18 and a good amount of pull at at the ride height I chose, I had a good amount of contact between the tire and the inside part of the fender on the seam welds. Adding 3mm spacers helped a little and I still need an alignment but I'm either going to have to "adjust" the inner fender on the inside or raise it up a little. Next time I will go with a 275/35/18 as the 285 has enough of bulge on an 18x10 and the wheel lip never contacts the inside just the bulged tires.
niscur29 is offline   Reply With Quote
Old 01-06-2013, 07:17 PM   #2702
Grimace
Grimace is an unknown quantity at this point
Send a message via AIM to Grimace
Originally Posted by ka-titties View Post
how the hell do you have a rear windshield wiper?
Legit Silvia I imported, Its got some other rare-ish oem goodies too.
Grimace is offline   Reply With Quote
Old 01-07-2013, 01:45 PM   #2703
RumInDaCoconut
RumInDaCoconut is an unknown quantity at this point
Originally Posted by Chris28 View Post
255/40/17 Toyo RA1's all around. 17x9 +25 front, 17x9.5 +30 rear. -3 camber up front, -2 in the rear. Fronts are rolled, rears are rolled and pulled.
would those front's 17x9 + 25 255/40/17 fit in the rear with a roll and no pull, any change in camber needed for that or slightly different offset ?
looking for flush + meaty fitment on my S13 hatch.
RumInDaCoconut is offline   Reply With Quote
Old 01-07-2013, 03:19 PM   #2704
mojos13
mojos13 will become famous soon enoughmojos13 will become famous soon enoughmojos13 will become famous soon enough
Actually yes, I'm making about 460-whp on 350Z 17" wheels running 225/45/17 in front & 245/40/17 rear and when boost hits in 5th gear, it's pretty much allover the place :-). never mind 1st, 2nd, 3rd & 4th..I'm running 650-cc injectors, turbonetics 62-1 turbo, boost cut, safc-II, 3" turbo-back straight thru exhaust @ 22/23-lbs, I don't wanna go to 265's and have to do this allover again cause i'd like to turn the boost up a couple of more pounds when I go dyno for the last time :-) ..Thanks for your help guys, the car is not very photogenic at this time but, i'll post a couple of pictures soon!
mojos13 is offline   Reply With Quote
Old 01-07-2013, 05:40 PM   #2705
jr_ss
Originally Posted by mad-ass View Post
Broadfield, can you please take a picture of your rear lower control arm that's been notched?
I'm scratching my head on this one to figure out how to actually do it.
Thank you.
In for pictures... Toby, Toby.
Old 01-10-2013, 05:48 PM   #2706
JN1AS4
JN1AS4's Avatar
JN1AS4 is an unknown quantity at this point
stock body s13. fenders rolled but I can get them pulled slightly if need be, with megan coils/ruca 17x9.5 +25 front and 17x9.5 +30 rear 255/40 squared setup. Without running a shit ton of - camber( -2.5 front, -2 rear) give or take. I seen a few post up where the 2 tone coupe is running 17x9 +25 in the front with a 255/40 w/ -3 camber under the stock fenders. My setup would't be to far off from his, and it should work too right?
JN1AS4 is offline   Reply With Quote
Old 01-10-2013, 06:18 PM   #2707
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
All depends on how low you are.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 01-10-2013, 06:44 PM   #2708
JN1AS4
JN1AS4's Avatar
That 2 tone coupe a few postings up is about right at my ideal ride height.
Old 01-10-2013, 07:13 PM   #2709
Broadfield
Broadfield's Avatar
Your front setup would stick out another 6mm from what that 2-tone coupe does. That may be enough for it not to work out for you... it's hard to say until you try it.
My Portfolio
Please Share
Check Out My Builds
Old 01-10-2013, 09:36 PM   #2710
silviaks2nr
silviaks2nr's Avatar
that coupe is a hatch
'98 240sx 5spd
kouki 2jz t56 swap build
Old 01-11-2013, 02:07 AM   #2711
240SilviaX
240SilviaX's Avatar
240SilviaX is an unknown quantity at this point
CHASSIS: 93 s13 Hatch
WHEELS: 527 17x8.25 / 17x9.75, +25off
TIRES: Hankook, Ventus V12, 245/40ZR17, 255/40ZR17
MISC DETAILS: Fully adjustable coilovers 8k/6k and arms, tension, traction, ruca, toe, PBM CroMo Inner tie Moog outers. J30 flca's boxed up, block of wood and metal pole flairs (rear)
PURPOSE OF CAR: DD, canyon/ mountian, track ,, grip
240SilviaX is offline   Reply With Quote
Old 01-14-2013, 07:15 AM   #2712
bllabong89
bllabong89 is an unknown quantity at this point
I tried searching through the thread search and google but can't find too much info on my soon to be set-up.
285/30zr18 on Enkei PF01 18x10.5 +15 will be the wheel/tire combo all around on an s14 kouki...I have overs on the rear but does anyone have info on fitting the fronts. I am hoping to get away with a mildly aggresive pull but couldn't find anyone else running 285s up front. Any help would be appreciated.
bllabong89 is offline   Reply With Quote
Old 01-14-2013, 07:33 AM   #2713
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
Did you punch that into a one of those calculators?
Tire size calculator
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
245/40-17 3.9in 12.4in 24.7in 77.6in 816 0.0%
285/30-18 3.4in 12.4in 24.7in 77.7in 815 0.1%
Just referenced it to the setup above you as a guide...
I think you should be fine, granted you are not slamming it to the floor?
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 01-16-2013, 05:47 PM   #2714
bllabong89
Well I have the wheels on. They sit flush with the back overs but the front fenders will need a lot of pull. The issue I run into now is the fact that the tire hits the front bumper when turning. It's as if the wheel is sitting too far forward in the wheel well.
YOUR CHASSIS: S14
WHEELS: Enkei PF01 18x10.5 +15 all around
TIRES: General Exclaim UHP 285/30zr18 all around
MISC DETAILS: rb25 with supporting mods, tein coilovers and fully adjustable multi link and sway bars
PURPOSE OF CAR: street & track
Old 01-21-2013, 06:09 PM   #2715
mojos13
Originally Posted by Broadfield View Post
He would need a pretty decent pull to fit a 285 on a 10.5 +22 on an S13. I'm running 18x11 +30 on a 285/30/18 and it's absolutely perfect. That's with -2.75 degrees of camber, about a 25mm pull and I'm fairly low. Mojos13 If you want to be low at all you will also need wide front fenders to fit a 245 on an S13. Not to mention you will need to modify the upper wheel housing lip, back wheel housing lip and relocate the drivers side chassis harness. Otherwise a 245 will rub on all of those while at full lock.
My rear fitment and pull for reference... this is probably exactly what you are looking for:
Front fitment: 18x9.5 +12 with a 245/35/18 with -2.5 degrees of camber and 20mm wide fenders:
Let me know if you need any other pictures to check out.
Note: with an 11" +30 I had to modify the upper wheel housing, and notch the OEM lower control arm. So you may want to roughly stick to the size that JDM SPUG mentioned... a 10.5" in the +24 range or a 10" +17 range.
You can also go here if you want to see some of the different size setups I have had over the years. Let me know if you need additional close-up fitment pics of any of those setups.
Flashback(exterior) « Broadfield's Blog
O.K. guys, did a little homework/shopping and here's what i'm looking at now... XXR535's (F) 18X8.75 +20 235/35/18 (R) 18X10.25 +25 275/35/18, besides some rolling and a little pull in the rear, what other issues do you see with this setup for my stock sheet metal hatch?..Thanks for your help!..I could spend all day on this thread!
Old 01-22-2013, 12:01 AM   #2716
240SilviaX
240SilviaX's Avatar
I run 245/40/17 on +25 offset 8.25 rim with 2.5- camber on stock fenders with a mild roll. On a 13,, edit; (and with J30 flca same dimensions as 14's)
Old 01-22-2013, 12:10 AM   #2717
240SilviaX
240SilviaX's Avatar
Also an idea, you can get different offset wheel,, 1 that takes up most of the space between your wheel and the coilover ( if there is any space now) and mabe a 20mm fender. might work.. how much space do you have between your rim and the coils right now? I know 14's have more room than the 13's.. that white coupe is clean as hell
Old 01-22-2013, 01:42 PM   #2718
tayloray
tayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura abouttayloray has a spectacular aura about
My old coupe, 18x9 front et 24 18x10 rear et 22 265/35 front 285 35 rear
tayloray is offline   Reply With Quote
Old 01-22-2013, 02:59 PM   #2719
turbo-2ns
turbo-2ns is an unknown quantity at this point
looking for help im not good with wheel offsets and the more i look the more confused i get lol
looking at the xxr 530s in f 17x8.25 and rear 17x9.75
from what i hear they offer +25 and +30
any way i can fit these under s14 stock front and rear(rolled) fenders or will they stick out, i really dont want to run any neg camber since it is a drag car mostly,, just looking at the xxr for something to roll on the street
also any thing els i should worry about rubbing like coilovers or control arms ext
turbo-2ns is offline   Reply With Quote
Old 01-28-2013, 02:20 PM   #2720
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
How will 18x9.5 +0 fit an S14 w/ 20mm front overs?
BlewByYou is offline   Reply With Quote
Old 01-28-2013, 05:52 PM   #2721
silviaks2nr
This is the max tire fitment thread not the ask questions about wheel fitment to fender thread. If you're posting in this thread you're picking the tire before you pick the wheel. Always go with a high offset in the rear to get as close as the coil as you can.
Billabong89, there's no way that 285 is going to ever fit up front without overfenders. It's not worth fucking up nice OEM fenders to make them "fit". Get an 18x9.5 with 255 up front.
'98 240sx 5spd
Old 02-01-2013, 07:03 AM   #2722
bllabong89
Here is the updated fitment on front. Found out my wife is pregnant with our first kid so I can't spend money on the car like I used to for a bit. Tires came with the wheels so I just ran them because it is the cheapest route.
Enkei PF01 18x10.5 +15 with 285/30ZR18 at all corners.
I am going to attempt to make custom front over fenders my self and see how I like them because it will be cheap and hopefully nice looking. lol.
Old 02-01-2013, 10:53 AM   #2723
sterlinge
sterlinge's Avatar
sterlinge is an unknown quantity at this point
285/35 18x11-31 up front
sterlinge is offline   Reply With Quote
Old 02-01-2013, 02:25 PM   #2724
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
^ 285 on a x11 -31... what? how do you possibly steer?
jaysgottaredtop is offline   Reply With Quote
Old 02-02-2013, 03:32 PM   #2725
sterlinge
sterlinge's Avatar
Like this..
Enough angle to daily drive
Old 02-04-2013, 02:28 PM   #2726
Yop
Yop is an unknown quantity at this point
Sterlinge which overfenders are you running ontop of the widebody fenders?
Yop is offline   Reply With Quote
Old 02-05-2013, 11:04 AM   #2727
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Sup guys. I have read through this entire thread and love the amount of information and pictures so I thank you all for that.
I did want to ask for suggestions on a tire setup that would be as square as possible for my 17x8.5 and 17x9.5 rims. I was looking at something like a 245/40 front 265/40 rear. Was also considering a 235/40 front and 255/40 rear but I feel that the tires would be a bit stretched at that size.
This is going onto an S14 body with hopefully minimal camber so I am expecting a roll and pull. Car is currently on the lift but has FA 500 coilovers....if any of that matters.
Thanx in advance.
2muchboost is offline   Reply With Quote
Old 02-05-2013, 11:32 AM   #2728
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
IMO I would do a 245 and a 275 I think a 245 might look a bit better then the 235.
I couldn't find the offset
17 x 8.5(front) / 235/45/17
17 x 9.5(rear) / 275/40/17
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 02-05-2013, 11:45 AM   #2729
Flicktitty
Flicktitty's Avatar
Just wondering if anyone on here runs R888's and what there thoughts are on them?
Old 02-05-2013, 12:09 PM   #2730
2muchboost
Trader Rating: (33)
Flick....thanks for the input.
