Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 01-02-2007, 04:53 PM   #1
Macadoshus
Macadoshus's Avatar
Macadoshus is making a name for him/her selfMacadoshus is making a name for him/her self
Hondata SR20DET Heatshield Gaskets!!!
S13 Highport SR20DET only.
$50 shipped. In stock.
Read what Hondata has to say about their intake manifold gaskets below...
Originally Posted by Hondata
Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power.
Turbocharged cars often use an aluminum intercooler to cool the air compressed by the turbo. The intake manifold is also made of aluminum but because it is heated by the head from combustion and coolant, works in reverse to an intercooler by heating the intake air by as much as 50° C.
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
Around town, testing has shown an average drop of around 10 degrees C which is good for around 3 percent power increase. Remember though that 3 percent power increase is difficult to feel. You'd feel a greater change in performance getting rid of that passenger. In certain conditions a 30° C drop has been measured.
The Honda manifold is heated in up to 5 places. From the head, the interior heating takeoff hose, the cold idle valve, the idle control valve and the throttle body heater. The Heatshield gasket kit contains an insulating gasket, and installation instructions. A race version only version with the thermostat bypass blocked is also available.
The graph above shows the results of installing the Heatshield gasket and bypassing the throttle body heating and idle control valve heating. If you examine a Type R intake manifold you will find that most sources of water heating are removed. Further temperature drops are possible when in addition the interior heating hose is blocked. What the graph shows, is that as you open the throttle, the intake temperature drops slowly as it cools the intake. When you descend a hill with the throttle closed or drive around town on a light throttle the temperature climbs quickly. It takes a good 15-20 seconds for the temperature to drop again when you open the throttle. So if you start your 1/4 mile drag with a hot intake manifold - you are only starting to develop maximum power near the end of the run when the intake has been cooled. The Heatshield gasket kit gives you 4-5% more power immediately by lowering the intake temperature.
R/T Tuning
Macadoshus is offline   Reply With Quote
Old 01-02-2007, 04:59 PM   #2
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
I bought one from passwordjdm I dont remember how much but it is white and 1/4 inch thick
Slide Happy
chuy is offline   Reply With Quote
Old 01-02-2007, 06:48 PM   #3
Campos
Campos's Avatar
Campos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura about
Send a message via AIM to Campos
gimme a special deal if i order 3 of them?
Parting out SR build....
Campos is offline   Reply With Quote
Old 01-02-2007, 08:04 PM   #4
Macadoshus
Macadoshus's Avatar
Sure will, sent you a PM with a price.
R/T Tuning
Old 01-06-2007, 07:50 PM   #5
GoodOl'S13
GoodOl'S13's Avatar
GoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfectionGoodOl'S13 is close to perfection
Send a message via AIM to GoodOl'S13
i want one!
paypal?
GoodOl'S13 is offline   Reply With Quote
Old 01-07-2007, 09:38 AM   #6
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
any chance of getting one for the KA?
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 01-09-2007, 03:25 PM   #7
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
highport sr20det... does that mean any s13 sr20det?
and does that suggst the heatercore hoses be blocked off for better cooling?
How hot would the thing be with the heater core hoses?
sepulchral is offline   Reply With Quote
Old 01-09-2007, 08:05 PM   #8
Macadoshus
Macadoshus's Avatar
I don't know of any plans to make them, so sadly probably not.
Yep.
The gasket doesn't do anything with the coolant temperature, it has to do with manifold temperature.
R/T Tuning
Old 01-10-2007, 06:03 AM   #9
sepulchral
yeah. i know. but it states in that quote from Hondata that the temp will be dramatically decreased if we block coolant lines going to the intake manifold. i'm guessing the coolant will still keep the intake manifold hot unless we block the lines correct?
Old 01-10-2007, 04:48 PM   #10
Macadoshus
Macadoshus's Avatar
That documentation is actually Honda specific. I should probably remove it to avoid confusion. There aren't coolant lines that go to the intake plenum on the SR as there are on the Hondas.
R/T Tuning
Old 01-11-2007, 07:53 PM   #11
Macadoshus
Macadoshus's Avatar
PMs replied.
R/T Tuning
Old 01-23-2007, 12:54 PM   #12
Macadoshus
Macadoshus's Avatar
Just got 4 more of these in stock!
R/T Tuning
Old 01-29-2007, 09:22 AM   #13
MI SO FST
MI SO FST's Avatar
MI SO FST will become famous soon enoughMI SO FST will become famous soon enoughMI SO FST will become famous soon enough
Send a message via AIM to MI SO FST Send a message via Yahoo to MI SO FST
i want one as well
Thanks,
Art N
MI SO FST is offline   Reply With Quote
Old 03-05-2007, 06:35 PM   #14
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
Will this also fit with s13 Greddy intake manifold?
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
