05-07-2010, 10:00 PM | #1 |
SR making a screaming sound
I have a s13 redtop with stock t25, and recently it started making a sort of screaming sound when I get into boost. If i drive normal it does not make the sound, only when I hit the gas hard. So I think one of the fins is chipped, bent, or something of he sort. Can anyone confirm this, and can i be fixed without getting a new turbo? Thanks in advance.
If you bought or sold me something, please leave me some feedback here. http://zilvia.net/f/private-sellers/...80dreamer.html |
05-08-2010, 12:17 AM | #5 |
sounds like your manifold to turbo gasket. is it the stock gasket or metal? if its the stock thats deff what it is. do you smell fumes more ? and it will get worse a lot worse if thats what it is. youll know cuz it will start to sound like your running open headers lol and you wont boost as much
05-08-2010, 08:10 AM | #6 |
If it sounds like a scream, I would go with either exhaust manifold, turbo--->manifold, or turbo--->elbow gasket being leaky.
I had this before and it sounded like a high pitched shreaking.... If it is more of a vibrational, metal sounding noise, it could be turbo fins hitting the walls of the housing. J
Daily driven |
05-08-2010, 12:26 PM | #9 | |
They are the stock gaskets, and I have noticed fumes more than I normally do.
05-08-2010, 12:28 PM | #10 |
Haha, there is screaming, but only when they are drunk.
05-08-2010, 12:32 PM | #11 | |
02-17-2011, 11:26 AM | #12 |
I have a similar noise coming from my turbo. When hitting boost, near 5000rpm from inside the car you can hear a high pitch "zing" It still hits proper boost, and drives good. Not sure as to what it is, its currently in storage so I will try to look at it without being able to drive it. I did replace the gasket between the turbo and manifold about 5000km's ago... i dont think that it should be worn out already. Any advice would help. THanks!
02-17-2011, 01:13 PM | #13 |
check for Shaft play on the comprssor wheel
Usually when the turbos blow the comprssor wheel will make contact on the wall and make a buzzy screaming noise
02-17-2011, 05:28 PM | #14 | |
I want to put this as my sig.
sr20det, t25 |
