02-06-2011, 12:47 PM | #1 |
Holset turbo users!
Ok, i have a 95 ka24de-t the engine specs are bored .20, eagle rods, cp pistion 9:1 and a valve job. im also running the JGSlog manifold withh a holset hx35 wastegate welded shut and using tial 38mm with 750cc injectors tuning with nistune type 4 board. were supposed to put the car on the dyno sometime this week and im just trying to see what some of you fellow holset users are making HP/TQ on what psi of boost. im looking to run about 18psi.
02-07-2011, 08:01 PM | #4 |
im still running stock cams for now i have another head that im looking into building but if i do im going to run kelford 264's. and i have seen the holset hx35 on sr20det blacktop and has AMAZING boost responce heres the link to that vid.
YouTube - Julians Holset 180sx Kouki Team Haltech l lemme know what ya think. |
02-10-2011, 09:40 PM | #5 |
cp 8:5:1 pistons, ported/polished head, 850cc injectors, power fc d-jetro on rough tune, z32 transmission---446hp at 21psi blacktop sr20. full boost at 4700rpm. expecting 475+hp at similar boost levels with retune
'96 240sx - has a snail shell and some stuff... |
02-22-2011, 09:12 AM | #6 |
Which exhaust housing are you running? Which exhaust manifold are you running? Manual or Electronic boost controller? Have the dyno plot?
02-22-2011, 09:40 AM | #7 |
Friend of mine has one on a FWD sr20de-T. He made over 400whp on the dyno. It was kind of hard to get the exact number as the car would spin the tyres on the dyno after about 4500 rpm and then pick up little traction later in the rpms.
Turbo Holset HX40. Injectors Evo 560cc MAF Z32. Boost 22 psi. I will post the Dyno graph when I retrieve it from the dyno. |
