Old 08-15-2009, 05:04 PM   #1
geoff240sx
geoff240sx's Avatar
geoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond reputegeoff240sx has a reputation beyond repute
what is the differnece between chuki zenki an kouki s14 sr20det wiring harnesses????
ok so i bought an manual s14 sr motorset from this whack importer in canada "jdmplanet on ebay"... long story short they sent me wrong engine harness an there is no way they are going to send me the right one.
i dont mind spending the money on buying a brand new harness, i just need to know what harness i need to order, the options are chuki s14? zenki s14? or kouki s14?
what do i look for on my engine to determine the right harness?
also they gave me "WC in red lettering" ecu witch means zenki from what i have researched, but i cant just go off of that considering they sent me a harness that is not compatible to my sr20. so who knows if the ecu they gave is for my engine.
on the engine i have the tps sensor only has one female plug on it but the harness that came with my swap has a brown male plug the connects to the tps but there is a grey plug right next to the brown plug the dosnt plug in anywhere... i know that that grey plug is important because on my friends s15 sr it has both the grey an blown plugs on his tps and when you unplug the grey plug, the vvt makes a insain tapping noise.
these are the plugs im talking about, "my engine is all apart an being rebuilt due to shity compression results/ later to find 2 broked ring lands, this is why i say jdmplanet is a whack importer"
sorry for the poorly composed thread an grammar errors lol and thanks in advace to anyone who helps me figure out what harness i need to buy!!!!
geoff240sx is offline   Reply With Quote
Old 08-15-2009, 05:25 PM   #2
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
S14 SR has VTC solenoid, S13 doesn't
gijoe69 is offline   Reply With Quote
Old 08-15-2009, 05:37 PM   #3
geoff240sx
geoff240sx's Avatar
^ yes, im not asking anything about s13sr harness thogh.... i have an s14sr
Old 08-15-2009, 05:37 PM   #4
Sileighty_85
Sileighty_85's Avatar
that probably an Automatic Harness
The Auto Tranny engine use 2 plugs on the TPS
On a side note
looks like one of you fuel injector caps is comming loose
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-15-2009, 05:45 PM   #5
geoff240sx
geoff240sx's Avatar
On a side note
you might be right, so they probably sent me an automatic harness, but what harness do i need to buy?
on thenismoshop.com the 3 choices are chuki s14sr, zenki s14sr, or kouki s14sr
The Nismo Shop : West Covina Nissan : Nissan OEM Engine Harnesses :: S13/S14 SR20DET
i didnt think they even made chuki s14 lol but thenismoshop.com aka westcovina nissan has that as an option
Old 08-15-2009, 05:49 PM   #6
geoff240sx
geoff240sx's Avatar
On a side note
i know, i removed the stock injectors from the rail and sold them an didnt tighten the screws down afterwards
thank you for looking out though
Old 08-15-2009, 06:26 PM   #7
Sileighty_85
I believe you can just swap over a A/T TPS and it should be fine
as long as you have the appropriate wire harness and ECU
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 06:47 PM   #8
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
I am curious to know this as well. How do you tell the difference between the engines and harness? I know on the kouki (and I believe chuki) harness the maf plug is oval instead of rectangle. You can use that as a reference.
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 08-15-2009, 06:59 PM   #9
geoff240sx
geoff240sx's Avatar
that that would probably work, but i think it would be more of a pain hunting down a automatic tps an ecu plus this harness i have is already pretty hacked up...i would rather just buy the proper harness for my engine brand new and send it to yurry @ wiring specialties to service it to go into my s13 so that i know 100% the wirring is right
thank you for that pointer. but my swap didnt come with a maf... im just going to use a z32 maf
Old 08-15-2009, 07:03 PM   #10
Sileighty_85
there should be a serial number Tag on the ECU harness close to the ECU, if it does then you can find out what model it is
S14 Zenki Harness 24011-65F04
S14 Kouki Harness 24011-80F00
Originally Posted by Monooxide View Post
a way to tell an S14 SR20DET(Zenki) from an S14a SR20DET(Kouki). Is that on the Zenki engines(93-96) the valve covers had Stud and Nut combination for the attachment, while in the Kouki(S14a) engines it used a Bolt and tapped hole in the head
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 07:05 PM   #11
Enna
I guess seeing how it doesn't have the maf, you can't check the plug. All I know is kouki harness wont work with zenki. Don't know the specifics, but they changed some things up.
Do you have any pictures of the head/valve cover? Might help in identifying what engine you have so you can get the appropriate harness.
Old 08-15-2009, 07:21 PM   #12
geoff240sx
geoff240sx's Avatar
kinda hard to see but... the head has the cooling fins like an s13 black top
Old 08-15-2009, 07:28 PM   #13
Sileighty_85
for some weird reason someone wrote the word "Harness" on the valve cover in japanese but thats all it says
Whats the first part? is it (8) C70?
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 07:36 PM   #14
geoff240sx
geoff240sx's Avatar
really??? lol so the Japanese writing to the right says harness?
the letters in the middle says (f) cpo or (f) cpu i cant really tell in the pics, now the the valve cover has been cleaned an the writing has been washed off
Old 08-15-2009, 07:41 PM   #15
Sileighty_85
Youp thats all it say....weird
but according to Monooxied info thats a Zenki engine
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 07:49 PM   #16
Enna
^ He is right. Atleast according to monooxied. Pick up a zenki harness and you should be good to go.
Old 08-15-2009, 07:54 PM   #17
Sileighty_85
what does the MAF plug look like is it oval or square?
Zenki MAF plugs are Square
Kouki's are Oval
Aslo what color is the ECU plug?
Ive heard Koukis are White
and Zenki's are blue
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 07:56 PM   #18
geoff240sx
geoff240sx's Avatar
yeah that is weird...
cool, that works out sence i have the zenki ecu already
thanks again man you have been a lot of help so far!
Old 08-15-2009, 08:05 PM   #19
geoff240sx
geoff240sx's Avatar
Kouki's are Oval
the harness that came with my swap "one with extra grey tps plug" has a blue ecu plug an square maf plug... so they probably gave me the right harness but for an automatic sr
thats what im going to do, cool now i can sleep good tonight lol
thanks again guys
Old 08-15-2009, 08:07 PM   #20
Sileighty_85
there ya go, sees everything in order now :P
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 09:02 PM   #21
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I could have sworn the Kouki ECU plug and the Zenkis are different. You cant connect a zenki harness into a kouki ECU and vice versa. Kouki Harness and S15 harness are similar with the slight exception that S15 harnesses doesnt use igniter chip.
Thats what was explained to me before by the guy who tuned my PFC when I was looking for a PFC to put into my S15 engine set.
CLICK HERE!!!
Old 08-15-2009, 09:16 PM   #22
Enna
He already mentioned he has a zenki ecu though (red WC). They just gave him an auto harness with it.
Old 08-15-2009, 09:16 PM   #23
Sileighty_85
What do you mean?
The WC ECU is the Zenki desho? and he has the blue plug ECU and Square MAF plug so that means its a Zenki harness with the zenki engine according to the Valve cover fasteners
後輪駆動車1番
1986 SR86 - 200ish
Old 08-15-2009, 09:42 PM   #24
anotherblusi
anotherblusi is an unknown quantity at this point
There are actually quite a few S14 variations that i've seen but the most common ones are these:
Zenki S14: Blue Ecu Plug, square maf plug, all other plugs the same
(There are some variations on the harness such as having multiple Black/Red wires on the M63 plug, but they all still use the zenki WC ecu)
Early Kouki S14: Blue ecu plug, oval maf plug, all other plugs the same
(Same as above, but I don't remember ecu code of the top of my head)
Late Kouki S14: White ecu plug oval maf plug, all other plugs the same
(Super rare harness. It is a cross between an s14 and s15. This harness comes on the latest model s14 engine but has similar ecu pinout as s15 harness)
And if it isn't obvious already, all sensor plugs on all s14 motors are the same EXCEPT for the maf plug which is either square or oval. So the only components that need to match up are the maf, engine harness, and ecu.
Also for the TPS issue, If the harness has a second connector, it is for the throttle position switch as opposed to the throttle position sensor which is necessary on all motors. You do NOT need to have the throttle position switch plugged in, so don't worry if your missing the dual plug tps.
anotherblusi is offline   Reply With Quote
Old 08-15-2009, 10:50 PM   #25
geoff240sx
geoff240sx's Avatar
i'm 99% sure that 2nd plug NEEDS to be plugged in, i unplugged that grey plug on a friends s15 then stated the engine, it idled normal but when i gave it any throttle it would make a terrible tapping sound coming from the vvt.... then plugged it back in an it sound would stop
possibly s15's require that plug to always be plugged in an s14's dont? or maybe youre saying if you have the single plug tps it wont matter if the 2nd plug is plugged in?
either way i still think im just going to buy a new harness because the one i have is has a few broken plugs an has been hacked up, looks like someone useto have some kind of piggy back wirred in before an did a poor job of repairing it
Old 08-15-2009, 11:14 PM   #26
Sileighty_85
here you can get the TPS if you get another Auto Wire harness
The Nismo Shop : West Covina Nissan : Nissan OEM Throttle Position Sensors - S13/S14/S15
But im sure if you ask yury he has a couple of plug laying around, plus im pretty sure he can repair that harness.
(Just trying to save you a few hundred bucks)
後輪駆動車1番
1986 SR86 - 200ish
Old 08-16-2009, 06:18 PM   #27
wbarrett48473
wbarrett48473 is an unknown quantity at this point
Doesn't the fins on the front of the motor mean that its a Kouki?
wbarrett48473 is offline   Reply With Quote
Old 08-16-2009, 06:32 PM   #28
Enna
No. If you were to actually read, it would say its a zenki motor.
Old 09-13-2009, 09:19 PM   #29
anfitch2k5
anfitch2k5 is an unknown quantity at this point
will either s14 harnesses,ecu, maf work on a s15 long block?
anfitch2k5 is offline   Reply With Quote
Old 09-24-2009, 05:49 AM   #30
andiqqqq
andiqqqq's Avatar
andiqqqq is an unknown quantity at this point
Hi.
I bought the late zenki JDM ecu.
It is black WC.
I find that JDM late zenki harness has everything like early zenki harness but MAF plug is oval.
It's wierd but i cant figure out whts wrong with this ecu.
I run it on a s14 squareplug maf.
On a days i will fit s14kouki maf.
I'm wondering is it diffrent in sending signals.
The engine starts on this JDM ecu but i cant switch off the engine.
I take the key and it's still working.
It gets boost cut on 0.4bar.
On stock ecu everything goes to normal.
any idea?
andiqqqq is offline   Reply With Quote
