03-22-2010, 05:24 PM | #1 |
Fortune Auto Coilovers & BC Racing Coilovers @ Import Image!!
CALL 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!! Zilvia, We are now the Master Dealers of Fortune Auto coilovers! **Join their Facebook page!** Fortune Auto's Facebook Page Price: $999 + shipping to your door! (PM for best price) Only 4 sets of S13's left! GET THEM WHILE YOU CAN UNTIL THE NEXT SHIPMENT!! All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers. Features: * Dyno tested*** * Stainless steel body / piston * 30-way adjustable dampers * Pillowball mounts * Forged aluminum locking collars * Dust boots on all pistons * 50mm piston (beyond the industry standard of 44-47mm) * Anodized aluminum camber plates** on front upper-mounts * Fully anodized body * 1 year Manufacturer's Warranty * Height adjustment independent of preload * ISO 9002 certification Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification. These Coilovers go LOW!!! Custom Spring Rates!! Done in the U.S.A! Zilvia Username: 95KA-Turbo One of our customers showing off how great these coilovers work! Zilvia Username: 240sxdriftin We are also the #1 Vendor in the nation for BC Racing coilovers! BC Racing BR series Coilovers $999 Shipped!! Free Custom Spring Rates as well!! & ** Order ANY BC racing coilovers and receive a FREE HID KIT!! Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system. - Mono-tube shock design - 30 levels of damping force adjustment, adjust compression/rebound - Pillowball mounts and adjustable camber plates included (where applicable) - Adjustable rear camber plates available - Separate full length height adjustable - One year warranty - Rebuildable Technical - Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force. - Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control. - Patented concave lower locking ring, to prevent unseating. - Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation. - T6061 Aluminum utilized in spring locks and seats for high strength and lightweight. - Iron lower brackets on MacPherson struts to ensure rigidity. - Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking. - High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life. - 2 step coating process utilizing nickel and chromium plating to prevent corrosion. - Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation. - An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself. BC Racing RAM type (Inverted) $1225 Shipped!!! BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally. - Inverted Mono-tube shock design - 30 levels of damping force adjustment, adjust compression/rebound - Pillowball mounts and adjustable camber plates included (where applicable) - Adjustable rear camber plates available - Separate full length height adjustable - One year warranty - Rebuildable BC Racing ER series $1850 shipped!! Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials. - External Reservoir Mono-tube shock design - 30 levels of damping force adjustment, adjusts both compression and rebound separately - Twin piston design - Pillowball mounts and adjustable camber plates included (where applicable) - Adjustable rear camber plates available - Separate full length height adjustable - One year warranty - Rebuildable Questions: Billy (804)-690-2452 (email)[email protected] AIM- importimagebilly Last edited by IMPORTIMAGE; 04-25-2010 at 03:39 PM.. |
03-25-2010, 10:53 AM | #2 |
Get some BC or Fortune on your car.
Best coilovers for your money Ask me about specials and combo deals!! |
03-29-2010, 03:08 PM | #4 | |
Shop with us for the best deals ! |
03-30-2010, 10:20 AM | #6 | |
Fortune Auto and BC Racing up to the top with great deals!! |
04-01-2010, 02:45 PM | #8 |
You have PM sir!
04-06-2010, 02:12 PM | #9 |
We are FULLY stocked with Fortunes!! Just got in 10 sets if S13 today
Get them while they last. These sell quick! |
04-08-2010, 09:50 AM | #11 |
PMed up to the top!
04-14-2010, 10:08 AM | #12 |
04-16-2010, 12:42 AM | #13 |
Trader Rating: (18)
Feedback Score: 18 reviews
got my fortunes days after ordering, crazy fast shipping from Florida to Hawaii!.
buy these coilovers, i love them, you'll love them and your spine will too. they ride amazingly smooth and go hella low. daily driver friendly!. |
04-16-2010, 11:15 AM | #14 | |
Theres only 4 sets of S13 left, get them while you can!! |
04-20-2010, 12:59 PM | #16 |
Up to the top with Fortune and BC!!! Only a few sets left in stock for Fortune s13's!
04-25-2010, 03:38 PM | #17 |
Zilvia Username: 240sxdriftin |
04-27-2010, 09:19 AM | #18 |
Only 1 set left till the next shipment for S13 get it while you can!!
04-28-2010, 09:05 AM | #20 |
PM'ed we'll get you taken care of!
Join the Fortune Auto satisfied customers and get your set today! |
