Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 01-17-2012, 06:19 PM   #31
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
Originally Posted by 1slowM6 View Post
Is this on an sr?how many psi and any other mods?
This is what i want to know also. I just want to replace my turbo and turn the boost up to 12psi and call it a day on my daily driver. Do i need a rom tune or more fuel or can the factory ecu handle it?
fullthrottle is offline   Reply With Quote
Old 02-18-2012, 01:47 PM   #32
240agsx
240agsx's Avatar
240agsx is an unknown quantity at this point
Hey how much for one if this babies shipped to 92806 im very interested pm plz
Sent from my DROIDX using Tapatalk
240agsx is offline   Reply With Quote
Old 03-11-2012, 12:46 PM   #33
90pearlz
90pearlz is an unknown quantity at this point
Anyone out there with one of these please post your reviews. Definitely considering buying one, I have read good things on many different forums
90pearlz is offline   Reply With Quote
Old 04-11-2012, 10:29 PM   #34
c1L
c1L is an unknown quantity at this point
was that dyno sheet with a stock ecu or a tuned ecu? very interested in this turbo.
c1L is offline   Reply With Quote
Old 04-12-2012, 03:34 PM   #35
TurboDaytona
TurboDaytona's Avatar
TurboDaytona is an unknown quantity at this point
Honestly, the setup doesn't really matter. Mainly the PSI. Stock T25's do not breathe past 220 at the wheels.. They pretty much stop making all power there.. the fact that is is making 270 at the wheels and not hitting a brick wall is more than enough for me..
TurboDaytona is offline   Reply With Quote
Old 04-26-2012, 05:05 PM   #36
h240
h240 is an unknown quantity at this point
Review??
So how is the turbo holding up?? Is there any other special mods that need to be done or is it a direct replacment..does a tune or injectors, maf need to be upgraded??
h240 is offline   Reply With Quote
Old 05-29-2012, 08:57 PM   #37
coupe92
coupe92 is an unknown quantity at this point
In for more info on this t25/t28 replacement as well. I have been running this turbo on my KA-T for around 8 months now, and about 4-5k miles. Spools fast, no smoking, pulls pretty hard. I have a boost leak or 2 (or 5) and a few exhaust leaks I'm sure, but this thing still spools pretty good and on my KA it's breaking loose the stock tires in 2nd when I hit peak torque. Have yet to dyno it though.. I have been running it from about 9-11 psi regularly with an adjustable actuator, however the stock actuator was set at like 14 psi and I couldnt lower it..This was partly because the turbo wouldn't fit my SSAC ka-t manifold so I had to clock it just a little, but this put the wastegate arm at somewhat of an angle, causing it to open a little later, but the fact remains that the spring is pretty stiff right away, I don't think you could get the wastegate they gave me to move under 10 psi.
I'm on the stock KA clutch at the moment and have developed some serious slippage, but I ordered a new comp clutch white bunny kit today. Once that arrives, I'll be trying turning up the boost to 13-14 psi. I still don't know much about this turbo though, and would like to get more specs on it.
coupe92 is offline   Reply With Quote
Old 07-23-2012, 04:45 PM   #38
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
^ how did you run the coolant lines to the turbo on your Kat?
shalezzz is offline   Reply With Quote
Old 07-26-2012, 08:56 AM   #39
TurboDaytona
I dont run coolant lines on my KA-t.. Just run a turbo timer. coolant lines are only for cooling after the engine shuts off..
But people do run coolant lines. Some run them from the throttle body pre-heat linews.
Old 07-26-2012, 09:32 AM   #40
shalezzz
shalezzz's Avatar
Yea I have seen that the only good write up I've seen, but I've seen people use the Goodyear heater hose and I feel like that would melt, and the cost to make custom an lines from the tb to the turbo will prolly cost more than the turbo. But I bought the Isis 3871 cause I thought it was just oil cooled, but like you said I may just run it w/o coolant lines hooked up
Old 10-05-2012, 06:08 AM   #41
swayc09
Trader Rating: (-1)
swayc09 is an unknown quantity at this point
Feedback Score: -1 reviews
i heard you have to run the isis trubo lines with it?
swayc09 is offline   Reply With Quote
Old 10-11-2012, 08:27 AM   #42
NightRider2.0
NightRider2.0 is an unknown quantity at this point
Couple questions. I just purchased DIF Forged Oil/Coolant lines and I wanted to know if they would fit this turbo and also, would I need to run a restrictor with this turbo?
NightRider2.0 is offline   Reply With Quote
Old 10-11-2012, 10:26 AM   #43
Enjuku Racing
Trader Rating: (29)
Enjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to behold
Feedback Score: 29 reviews
Send a message via AIM to Enjuku Racing
As long as their oil feed line is a 3an and NOT a 4an. Then yes you should be able to use their turbo lines. No, you do not want to run a restrictor on this turbo.
thanks
Ken
Office: 352-241-8399 / 1-888-SR20DET (772-0338)
YouTube.com/c/EnjukuRacingParts
http://www.enjukuracing.com
[email protected]
Enjuku Racing is offline   Reply With Quote
Old 01-10-2013, 12:33 PM   #44
BTMiata
BTMiata is an unknown quantity at this point
Is the downpipe flange on this turbo different from a Garrett? I've heard some churbo's have a slightly different flange. Thanks
BTMiata is offline   Reply With Quote
Old 01-10-2013, 12:43 PM   #45
Enjuku Racing
Trader Rating: (29)
No, it is identical to a Garrett 5 bolt flange/S14/S15 outlet flange
thanks
Ken
[email protected]
Old 01-10-2013, 12:45 PM   #46
BTMiata
thanks
Ken
Thank you!
Old 05-16-2013, 08:08 PM   #47
Maichael
Maichael is an unknown quantity at this point
I need to know the oil inlet and coolant correct location
I am buying the Isis T25/T28 and i need to know if the oil inlet line correct location is in the item in the picture and if the coolant lines has the inlet and outlet and Many Thanks Anticipated.
Maichael is offline   Reply With Quote
Old 05-17-2013, 04:20 PM   #48
Maichael
Thanks for the great info!!!!!!!
Old 06-22-2013, 01:50 PM   #49
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
Will this bolt up to my ca18det? Also, which turbo lines would I need to get to go along with it?
WTB: S13 Silvia front pieces
Need: Hood, Fenders, Bumper, Headlights + brackets.
Have decent pop-up front to trade with oem hood + vis racing carbon fiber hood if interested.
nissanfreak317 is offline   Reply With Quote
Old 06-25-2013, 12:20 PM   #50
Enjuku Racing
Trader Rating: (29)
Nissanfreak317, we attempted to test fit this turbo on a ca18det and it would not bolt up, Sorry.
[email protected]
Old 07-01-2013, 11:01 AM   #51
nissanfreak317
Trader Rating: (18)
Well, thanks for taking the time to do that. What didn't line up? I thought that any sr20 turbo would bolt up to the ca. Good thing I asked, haha.
Old 07-02-2013, 11:46 AM   #52
Enjuku Racing
Trader Rating: (29)
Sorry, we should have been more descriptive, our apologies. The o2 extension didn't mount up as the t25/t28 uses a t28 back housing. You cannot simply use an sr20det elbow as the 3 bolt flange is clocked differently. You can, however, use your ca18det elbow and drill out one of the bolt holes to fit accordingly. As for the turbo lines, they will have to be custom made. We can make these here for you if you are interested. Just one more thing also, the turbo must be clocked in order to fit properly.
[email protected]
Old 06-11-2014, 06:33 PM   #53
240sxkid223
240sxkid223's Avatar
240sxkid223 is an unknown quantity at this point
Ship to 94565 is the prize still good?
240sxkid223 is offline   Reply With Quote
Old 06-12-2014, 10:24 AM   #54
Enjuku Racing
Trader Rating: (29)
The price listed on this post is outdated. This thread was started back in 2011 and since then, the price for these turbos has risen. Currently, ISIS replacement turbos are selling for $359.99, marked down from $400.00.
ISIS performance has recently made remarkable improvements on the quality of their turbos. Every single turbo is pulled apart, inspected, re-balanced (if needed) and serial numbered. Also, all ISIS turbos are now using dual overlapping bearing seals. All in all, the new improvements has made one of our best selling turbos even better and we are excited to sell them here.
[email protected]
Old 07-17-2014, 07:36 PM   #55
doridoridori
doridoridori is an unknown quantity at this point
still have these turbos? i need one
doridoridori is offline   Reply With Quote
Old 07-18-2014, 08:32 AM   #56
Enjuku Racing
Trader Rating: (29)
We have a shipment of 20 coming in next week. They will go fast though. We already have 8 pre-ordered.
[email protected]
Old 07-18-2014, 05:52 PM   #57
doridoridori
gotcha, can i place an order with you guys through here?
Old 07-21-2014, 09:12 AM   #58
Enjuku Racing
Trader Rating: (29)
You can. Just send us a PM with your name and your zip and we can get you started on a quote.
[email protected]
Old 07-21-2014, 09:49 AM   #59
pjmrnolife1
Trader Rating: (-1)
pjmrnolife1 is making a name for him/her selfpjmrnolife1 is making a name for him/her self
Shipped to 33334?
pjmrnolife1 is offline   Reply With Quote
Old 07-21-2014, 07:34 PM   #60
doridoridori
perfect will do
