06-02-2013, 06:56 AM | #1 |
Trader Rating: (53)
Feedback Score: 53 reviews
Ball Bearing Turbo Rebuild Kit
JDSPerformanceTurbos.com
JDS-Performance-Parts.com NOT A GARRETT/PRECISION OR HKS PRODUCT!!! [email protected] ///ON SALE FOR LIMITED TIME/// $265 shipped or $250 picked up Concord, NC 28025 Pull those old door stops up off the floor and get them boosting again! Finally a Ball Bearing Turbo Rebuild Kit Will fit; GT25R, GT28R, GT30R, and GT35R Series TURBOS ///Ask about piston ring (oil seal) kits - for those leaky turbos that don't need a full rebuild/// ///KIT WILL COME WITH MY BALL BEARING TURBO REBUILD DVD/// SO YOU CAN REBUILD YOUR TURBO YOURSELF! You will have to get your CHRA balanced after the install. Be sure to check the oil hole on your oil restrictor to be sure its the same as the one supplied in this kit - if not you will need to reuse your oil restrictor. Also be sure to run a screw in oil restrictor if your application requires it...if you have any questions on this check Garrett's website they have all the detail you would need to know. Rebuilding a Ball Bearing Turbo is alot more involved than a Journal Bearing Turbo so if you do not have the patients I recommend getting a pro to do the rebuild! Also more special tools are needed verses the journal bearing turbos. We charge $135 dollars labor for the rebuild - that does not included a balance in that price! Last edited by JDS Performance; 04-17-2015 at 09:49 AM.. |
06-02-2013, 07:02 AM | #2 |
Trader Rating: (53)
I also have a few turbos I am rebuilding if interested LMK
T25 SR20DET Journal Bearing Turbo GT2560R - T28 Ball Bearing S14 Turbo GT2560R - T28 Ball Bearing S15 Turbo GT2560 - T28 S15 Journal Bearing Turbo GT2860RS - Disco Potato - Ball Bearing Turbo GT2871R - Ball Bearing Turbo GT3582R - Ball Bearing Turbo Precision 6152E-MFS - basiaclly a GT35 journal bearing turbo with slightly different size wheels HKS GT2510 - Ball Bearing Turbo Last edited by JDS Performance; 11-13-2013 at 12:16 PM.. |
11-13-2013, 12:14 PM | #13 | |
Trader Rating: (53)
Thanks kits are above which come with my rebuild dvd I have a rebuilt gt2871r with billet wheel 52trim in fs section... basically like new. . Check my listings I have a few blown turbos Please email me I don't want to break any form rules [email protected] |
11-13-2013, 12:14 PM | #14 | |
Trader Rating: (53)
