11-08-2012, 06:58 PM | #7 |
You comment on the "ricer" gauges when you got the car, and then bought gauges? Lol looks like a good build, youll have fun with the 2JZ. What are you doing to engine as far as mods go?
@hcr32love 400whp NEO R32 Sedan |
11-08-2012, 07:09 PM | #9 | |
Rebuilt bottom and top end, with Bc 264s cams. Would like to buy some HKS Cam gears when I get around to it. |
11-09-2012, 09:38 AM | #10 |
Sounds good, thats what Im boutta do to mine soon. What paint did you use for the engine?
11-09-2012, 05:18 PM | #12 |
11-12-2012, 08:59 AM | #17 |
11-12-2012, 04:06 PM | #20 |
Trader Rating: (43)
Feedback Score: 43 reviews
^^^ u should start making rad hoses and heater hoses just for the s13/s14 2jzgte swapped man!! I think their is a market for it
fdrea |
11-12-2012, 05:06 PM | #21 |
11-13-2012, 08:38 AM | #23 | |
Thanks
Mishimoto Automotive |
11-16-2012, 02:44 PM | #27 |
That wiring looked pretty intense. How involved is it? I'm thinking of doing one myself. I might go with the zero lab kit which includes driveshaft engine and tranny mounts. I will have to deal with exhaust fab wiring and fuel lines correct. Anything else super involved?
11-16-2012, 04:48 PM | #28 |
Thought I would put down a fast list of the things on the 240
Engine -Stock 2JZ-GTE Engine -Walbro 400 fuel pump -Mr2 turbo radiator (With Turbo Samco Hose's) -Dual Flex-A-Lite electric fans -Dif Dual fan Controller -Serpentin belt (With AC) -HKS Timing belt -Wireharness Mod -Aem Ems V1 -New 240sx Motor Mount's -2jzgte mod Motor mount's -Clevite Bearing Kit -Engine Rebuild (With Thermostat, oil filter, with Royal Purple) -Light Weight Pulley's -Hks Racing Hi-Power (75mm) -Custom downpipe with Mid pipe -Fuel line's, with all the Fitting, 2 Inline filters, (ETC) -Front Sump Oil pan Setup -Greddy Intake Manifold (Gasket's, etc) -2jzgte Igniter -Fuel Injecter Clinic Rail -Oil Catch Can -Relocation Battery box (2g wire, etc) (With Optimal Battery) -Band new Belt Tensioner -BAND NEW USDM Waterpump -FRP Fuel Gauge -FRPer Turbo Setup -Mishimoto Intercooler 31x12x4 -Oil Feed Line's For Single turbo Kit -3 inch Intercooler Piping (Custom) -XS Manifold T4 Turbo (Gasket's, etc) -BW Turbo S3 -44mm Tial wastegate (purple) -Tial BOV (Purple) -4Inch Intake Pipe -4 bolt to v-band adapter -wastegate DumpTube Driveline -R154 Tranny (With BAND NEW REBUILD) 0 MILE"S (5 Speed) -LightWeight Flywheel (11.5 LBS) -1jz bellhousing (With Bolt's) -V3 short throw shifter -Custom Driveshaft -300zx TT left Side Axle -q45 right Side Axle -Q45 Differential LSD -All poly subframe bushings (Energysuspension) -Sikky front Sway bar -Shifter Extension -Act 7m/1jz Clutch -New Clutch Slave -2jz Clutch line Suspension/wheels -BC Coilover's -300zx TT Big Brake's (Front and Rear) -300zx E-brake Assembly -R33 E-brake cable's -Drilled/Slotted Rotor's (Front and Rear) -Band new 300zx Rear hub's -Strut bars front and rear Interior/sound: -Cage -Defi Oil Pressure gauge (52mm) -AEM Boost Controller gauge (52mm) -Defi WaterTemp gauge (60mm) -Defi Oil Temp gauge (60mm) -Gauge Pod's (2) 52mm -Custom Door Gauge Pod's (2) 60mm -Dak (Tachometer) -Dak (Speedmeter) Exterior: -HID Kit low Beam's (10k) -s14 Fog Light's -New Front new ( Hood,Fender's,Front Bumper) -New Trunk Lid -Navan grill -New comer light's -headlight's -Rear and Front Lip's |
11-16-2012, 05:20 PM | #29 | |
11-17-2012, 09:40 AM | #30 |
Its on the road, oh no..
Taking for Tune, Then body work is next The rear set of tires are for sell (Like Band New!) Maby 300 miles, No burn outs done with them. Here's Link...http://zilvia.net/f/wheels-tires/485...760-sport.html |
