Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 09-19-2012, 12:01 PM   #1
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
Thumbs up Circuit Sports S13/S14 Suspension Links ~ FREE SHIPPING OVER $150 ~
Godzila present you Circuit Sports Suspension Parts for lowest price ever!
Circuit Sports (CS) is a new product line which branched from an OEM manufacturer of chassis reinforcement and performance products. As an OEM manufacturer, we were subcontracted to build products for well-known Japanese and U.S aftermarket companies.
Please PM for price/combo package available!
Free shipping over $150
S13
Toe: $108
Traction: $108
Tension: $108
RUCA: $133
FLCA: $355
RLCA: $415
S14
Toe: $108
Traction: $108
Tension: $113
RUCA:$130
FLCA:$355
RLCA:$415
Payment Method:
-Paypal
-Money Order
Circuit Sports Suspension Parts:
Circuit Sports Front Tension Rods S13/S14
Allows adjustability of caster
High quality 3pcs teflon rod end
CNC one piece aluminum body for light weigt and strength
High quality blue anodized finish
Direct bolt on with all new hardwares
Circuit Sports Rear Toe Links S13/S14
Circuit Sports adjustable rear toe links for 89-98 240SX
Adjustability of rear toe for alignment purpose
3pcs teflon rod end for durability
High glaze powder coat for surface protection
Reinforced end "U" bracket for strength
Circuit Sports Rear Traction Rods S13/S14
Circuit Sports adjustable rear traction links for 89-98 240SX
Adjustability of rear caster for alignment purpose
Circuit Sports Rear Upper Control Arms (RUCA) S14
Circuit Sports rear camber arms for S14 95-98 240SX
Allow adjustability of rear camber for alignment
High glaze blue powder coating on tubing body
Circuit Sports Rear upper Control Arms (RUCA) S13
Circuit Sports rear camber arms for S13 89-94 240SX
Allows adjustability of rear camber for alignment
High quality clear glaze powder coat on arm tubing
Circuit Sports adjustable front lower control arms S13/S14
Adjustable FLCA's allows full adjustment to front suspension in conjunction with tension rods, steering tie rods, and camber plates to dial in their car for track and drift use. High glaze powder coat finish for durability and long lasting finish.
Circuit Sports adjustable rear lower control arms S13/S14
Circuit Sports adjustable rear lower control arms replaced OEM fixd rubber type bushings that most often is already wore and torn on the 240SX's. The adjustable rear lower control arms also allows full adjustment with the car's rearsuspension links (rear traction trailing links, rear toe, and rear upper control arms) to fully work with each other in conjunction to dial in your car's suspension to take advantage on the track or drifting. High glaze powder coat finish for durability and long lasting finish.
pink godzila is offline   Reply With Quote
