Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 10-26-2012, 02:21 PM   #1
Zerolift Autolab
Zerolift Autolab's Avatar
Zerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant future
Send a message via AIM to Zerolift Autolab
1 SET OF EACH LEFT : Buddy CLub D1 Spec Nissan S13 and S14
Hey Everybody !
SUSPENSION DEAL !
1 of Each SALE !
Buddy Club D1 Spec Coilovers
Nissan S13 and Nissan S14
Pricing is $1100 SHIPPED in the USA !
1. Ride-Height Adjustable
Vehicle ride height is adjusted independently of spring pre-load. With other alternatives available on the market today, vehicle ride height is adjusted by reducing or increasing the preload on the coil spring. This primitive methold leads to inconsistent spring rates that are dependent upon the vehicle ride height. With any of the Buddy Club suspension components, including the D1 SPEC, vehicle ride height is independent of spring pre-load. This method ensures that the spring rate is always consistent, no matter how high or low your car is. In addition, it ensures that the spring is always properly positioned onto the strut and effectively reduces miscellaneous and unnessary noise.
2. 15 Level Adjustment
Suspension adjustability is a key element when selecting a top quality coil-over system. The D1 SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
Also avaialble is the optional urethane isolated upper pillow-ball mount. The urethane isolating ring keeps suspension noise to a minimal while maintaining the precision feel of a solid mounted strut.
3. Mono-Tube type shell case
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
4. Exclusive Buddy Club Springs
In a complete suspension setup, the coil-spring is a very key element. The coil-springs used on all Buddy Club suspension setups are specially made to exacting specifications by Buddy Club engineers. Each coil spring is manufactured to exacting tolerances to ensure performance in every demanding situation
5. Beautifully Finished
To ensure that the D1 SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgandy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
Contact:
Phone - 513-874-2508
AIM - ZLR0bert
Email - [email protected]
Zerolift facebook - http://www.facebook.com/Zerolift
Zerolift Autolab is offline   Reply With Quote
Old 10-29-2012, 06:10 PM   #2
KOUKIboy
KOUKIboy's Avatar
KOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-known
I might of missed it or something, but what are the spring rates???
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87
KOUKIboy is offline   Reply With Quote
Old 10-30-2012, 09:52 AM   #3
Zerolift Autolab
I contacted Buddy Club today with this question.
Front - 7k
Rear - 5k
For both S13 and S14
Contact:
AIM - ZLR0bert
Old 10-30-2012, 10:02 AM   #4
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
If I didnt already order PBM's...
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 11-05-2012, 12:26 PM   #5
Zerolift Autolab
Still limited availability from Buddy Club US !
let me know if youre interested.
Contact:
AIM - ZLR0bert
