12-18-2010, 05:15 PM | #1681 |
18x9.5+20 All around
F245/40 R275/35 All Stock Fenders, GR-2 shocks, eibach sportline springs. Rears rub a little bit and will need very minor pull, Or loose weight haha. Fronts rub on full lock, screw it, dont go full lock. My KWv3 are in the mail and I'm wondering if i will rub the coilovers with my offsets? I dont want to go smaller tire but i might have to ]: Any alignment set ups to stop the rubbing? Thanks.
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 |
12-27-2010, 07:57 PM | #1684 |
can someone clue me in as to what the maximum backspacing we can run on our cars (s14 chasis)?im trading my 19 inch volks w/305's and geting 18inch CCW classics with 315 azenis...thanx in advance.
-ross-
" NEO VVL BABY FTMFW!" Originally Posted by shagspeed Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines |
12-27-2010, 08:22 PM | #1685 |
You don't want to go more than 175-180mm backspace. I had coilover body interference at 183mm backspace and was very close to the LCA using an 11.5 et+29.
01-01-2011, 08:09 PM | #1686 |
Okay, first post but I have spent the last 3 hours browsing this thread and the "whore" thread, and still have not gotten my answer...
Looking to see if anyone is running 17x9.5 with 285/40/17 or similar rubber up front. Trying to figure out an offset to stay under stock fenders and without contacting the coils (Stance GR+Pro). I don't mind pulling, but do not want to put fiber over-fenders on the car due to my experience with fiberglass in the body shop business the past 7 years. Any help is appreciated, in the mean time I will continue my search! Phil EDIT: This is for an S14, Sorry! |
01-01-2011, 08:11 PM | #1687 | |
Trader Rating: (163)
Feedback Score: 163 reviews
01-01-2011, 08:14 PM | #1688 |
ive seen 275s on a couple cars with a pull but were on 9" wheels not 9.5".
I have my reasons, I am doing very similar to a certain white S14 a couple pages back. car is being built for serious time attack and some street use... I saw one guy that is doing steel widebody front fenders, and if I have to I will do that, but I was trying to see if I could avoid it first. |
01-01-2011, 08:19 PM | #1689 | |
Why not fiberglass front fenders? Cheap and easy. |
01-01-2011, 08:23 PM | #1690 |
After working on older vettes, dealing with mustang hood repairs etc... Fiberglass can kiss my @$$... Just not worth it cause after so long, it just starts to crack and chip and turn to crap and needs to be fixed. Since I am spending the time and effort to do like the other member did with his steel widebody in the rear, I feel strongly that it would look nicer and last longer with steel. Also, easier to repair in the event of an accident. Once fiberglass is cracked, I don't care how many patches you put on it, its not the same.
Thought I put 14, sorry guess I spaced out there, I will edit that post momentarily. |
01-01-2011, 11:34 PM | #1691 |
probably a noob question but i searched around this thead... i can't determine if it get 17x10 + 40 offset wheels for the rear would i rub with coilovers? i currently have stance lx+ not sure what tires i'd be getting as of yet. but, the tire determination will be based on the rubbing issue if i do have any. thanks for the help guys
01-02-2011, 12:41 AM | #1693 |
oh, wow thank you sir, that's a good answer... but, did he have to roll or pull? or just left fenders as is and how low did he go? thank you sir for your answer i really appreciate it. and happy new year!
01-02-2011, 06:12 PM | #1695 |
that was just rolled.
don't be afraid of rolling as long as you do it RIGHT. Rolling is not some mysterious black magic. It is easy to do (without trashing your car) with a heatgun, roller, and lots of patience. On s13's its a little different because the quarter panel can "dimple" if you're not careful though. |
01-06-2011, 01:40 AM | #1696 |
can some one tell me what is average tire that is supposed to be on my rim.
17x9 +0
"If you're not first ..... you're last" Ricky Bobby |
01-07-2011, 01:29 AM | #1698 | |
if you want to check out my build thread on nico here is the link Hxc_Nismo RB26 Build Thread : RB20DET / RB25DET / RB26DETT Forum |
01-08-2011, 09:49 AM | #1699 |
01-09-2011, 05:57 PM | #1701 |
I've been so hung up on >305s I forgot how MEATY 275s can look! Nice work!
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
01-12-2011, 06:09 AM | #1702 |
I've been fiddling with idea of getting bigger wheels and tires all together and desperately want to get rid of the rear camber and want it to sit at around -1~1.5 camber at most in the rear.
setup I'm looking for is.. RPF1's in.. Front: 18x9.5 +15 235/40/18 Rear: 18x10 +38 275/35/18 or wider, front fitment I know it's going to work, I'm just having a real hard time finding a pic of the rear setup on a S14 and see if +38 is high enough offset for me to shove 275's and -1 camber together on stock fender[rolled/pulled 1/4 inch with no flare] and here's my ride height that i want to keep at. current setup is rpf1's, 17x9+22[+2 effective]225/45/17, 17x10+18 245/40/17[-3.8 camber ] thanks for any inputs.
01-12-2011, 08:00 AM | #1703 |
You should be good, Personally I'd run closer to -1.5 static camber all the way around. I fit a 17x10 +12 with a 255-40 NT05 in the back with a 1/2" pull and about -1.8* camber.
Also I'd suggest not running such a large staggered tire set up. 245/265 would be ideal. If you do a 235/275 you're looking at understeer city. And lmk what you want for your 17's, I really want white RPF1's and 17x9 +22 is the perfect size for stock S13 fenders. |
01-12-2011, 11:15 AM | #1704 | |
but yea i'm very interested in those rpf1s if you're gunna sell them. |
01-12-2011, 02:37 PM | #1705 | |
and btw, my wheels are for sale, looking for local sale to start with first. But I will be keeping the current setup until I get my 18's fully setup. So it will be a while? lol.[July or so...] and why would the car understeer with 235/275 setup? is that just simply because of grip ratio from front/rear? I do not want to over work my steering rack by putting anything bigger then 235's up front. and also looked at the most common used tire sizes since the price won't be so sky high at that point, so i came up with 235/275. This car won't see track any time soon, just gona be my daily cruiser...with lsx later this year.
01-12-2011, 02:44 PM | #1706 |
You wont over work anything with 245's in the front, and if your worried it takes 15 minutes to install a fluid cooler for your PS system.
But honestly yes it will be terrible, your mentioned 235/275 set up is similar to what ass-ended 911's run. 240's generally need either a square set up or only a small stagger. Anything over board will cause a huge imbalance in front/rear grip and its going to understeer horribly. How much power do you have? Large tires weigh A LOT, so you need to take into account the added weight of the tire vs how much actual grip you need. I never needed anything more than a 255 NT05 on my car with about 300lbft of torque. |
01-12-2011, 03:01 PM | #1707 |
I drove a friends s13 that was running 235 (maybe even 225, don't remember) in front with 275s in the rear and it understeered like a pig. I don't remember the sidewall sizes though.
01-12-2011, 05:26 PM | #1708 |
I deff don't want the car to under steer, that's a no no! haha.
i'll stick with 235/40/18 on 18x9.5+15 in front and 255/35/18 on 18x10+38 then. I did have 255/40/17's on the rear before my 245/40's and didn't feel much difference as far as grip was, but then again, i do have almost -4 degrees of camber so i'm maybe using 60% of the tire thread patch. Thanks for all the info guys. will keep you posted.
