Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Intake & Exhaust
Old 04-04-2010, 09:18 AM   #1
Ravspec
Ravspec's Avatar
Trader Rating: (25)
Ravspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really nice
Feedback Score: 25 reviews
Send a message via AIM to Ravspec
TOMEI Expreme Exhaust Manifold and Turbo Outlet *** New Lowered Price ***
***** Optional Service High Temp Heat Coating - $199 For Both *****
Expreme SR20DET Exhaust Manifold - $531 + Shipping
Our EXPREME exhaust manifold is now available for SR20 owners who want a performance upgraded from the genuine exhaust manifold. With our product you can retain the genuine setup and no special modifications are needed to fit the standard turbo. With the SR20DET the exhaust manifold was designed to be close from the exhaust port to the turbine. With the comparison test of our isometric prototype & the factory genuine manifold which also utilizes the same layout, it shows that ours has succeeded in delivering an overall improved performance in both torque and power increase in areas like in the higher RPM range in which you were not able to utilize before. With our extensive testing we have reached the conclusion that the normal design is superior as a total overall efficiency. So to develop an exhaust manifold similar with the design and setup as the factory manifold we were finally able to produce a product worthy to bear our name as a product that has the potential to deliver an overall increase in performance.
Expreme SR20DET Turbo Outlet - $171 + Shipping
The genuine turbine outlet diameter is small which causes the secondary exhaust pressure to rise. This in turn results in a loss of power, response & unstable pressure. The TOMEI outlet has a larger internal diameter for the best optimization of exhaust flow efficiency & helps reduce the exhaust pressure substantially. If used in conjunction with our TOMEI ARMS turbine. You will see large gains in all aspects of performance. The corrosion-resistant stainless steel material used in manufacturing this product is good with heat resistance up to the flange.
Ravspec is offline   Reply With Quote
Old 04-04-2010, 09:50 AM   #2
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
How do I order? I can't find the elbow on your site?
reactor is offline   Reply With Quote
Old 04-04-2010, 10:21 AM   #3
Ravspec
Ravspec's Avatar
Trader Rating: (25)
Upgrading to a new site .. still under construction, but here, try this. (Select Free Shipping)
TOMEI Expreme Turbo Outlet - RavSpec - RavSpec Race Work - JDM Performance Parts Central
Old 04-04-2010, 10:52 AM   #4
bboyoracle
bboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to behold
Send a message via AIM to bboyoracle
Any pictures of the coating you offer?
bboyoracle is offline   Reply With Quote
Old 04-04-2010, 10:56 AM   #5
blasting_speed
blasting_speed's Avatar
blasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfectionblasting_speed is close to perfection
Send a message via Yahoo to blasting_speed
Are there any deals going on by ordering both of these products???
blasting_speed is offline   Reply With Quote
Old 04-04-2010, 05:15 PM   #6
Ravspec
Ravspec's Avatar
Trader Rating: (25)
yeah, knock extra 5% off ! LMK
Old 04-07-2010, 07:02 PM   #7
kylezeits
kylezeits is an unknown quantity at this point
Do you guys ship these items to Canada for free?
Also where can i find the exhaust manifold on your site?
kylezeits is offline   Reply With Quote
Old 04-08-2010, 12:40 AM   #8
Ravspec
Ravspec's Avatar
Trader Rating: (25)
PM you thanks.
