Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 07-26-2010, 08:49 AM   #1
IMPORTIMAGE
IMPORTIMAGE's Avatar
Trader Rating: (78)
IMPORTIMAGE is an unknown quantity at this point
Feedback Score: 78 reviews
Send a message via AIM to IMPORTIMAGE
BC racing coilovers @ Import Image Racing!!******************************************
CALL 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!!
**Remember with Import Image you make YOUR OWN package deal! The more you buy the even great your discount gets **
We are the #1 Vendor in the nation for BC Racing coilovers!
BC Racing BR series Coilovers $999 Shipped!! Free Custom Spring Rates as well!!
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
BC Racing RAM type (Inverted) $1225 Shipped!!!
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series $1850 shipped!!
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
Questions: Billy (804)-690-2452
(email)[email protected]
AIM- importimagebilly
IMPORTIMAGE is offline
Old 07-27-2010, 12:55 PM   #2
IMPORTIMAGE
Trader Rating: (78)
Up to the top with BC racing coilovers!
Get $50 to ImportImageRacing.com when you purchase a set of BC coilovers.
PM us to make combo deals
Regards,
[email protected]
804-690-2452
AIM: ImportImageBilly
Old 07-28-2010, 12:04 PM   #3
IMPORTIMAGE
Trader Rating: (78)
Do we ever stop working??????
NOPE!
PM US!
We'll get you the best deals 24/7
Regards,
[email protected]
804-690-2452
Old 07-29-2010, 04:31 PM   #4
IMPORTIMAGE
Trader Rating: (78)
Need more than one part and want better prices?!?!
That we can handle. the more you buy the lower your cost
PM/Call/Email us for best service and prices
Regards,
[email protected]
804-690-2452
AIM:ImportImageBilly
Old 07-30-2010, 03:56 PM   #5
IMPORTIMAGE
Trader Rating: (78)
To the top!
Regards,
[email protected]
804-690-2452
Old 08-01-2010, 12:24 AM   #6
IMPORTIMAGE
Trader Rating: (78)
NOPE!
PM US!
Regards,
[email protected]
804-690-2452
Old 08-02-2010, 09:26 AM   #7
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-03-2010, 11:35 AM   #8
IMPORTIMAGE
Trader Rating: (78)
To the top!
Regards,
[email protected]
804-690-2452
Old 08-04-2010, 02:58 PM   #9
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-05-2010, 02:56 PM   #10
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-06-2010, 01:28 PM   #11
IMPORTIMAGE
Trader Rating: (78)
**Buy BC and get a $50 gift certificate for ImportImageRacing.com!!!!!
Want to slam your car?? That's no problem with BC racing coilovers!!
Come on in and get the best deal around!
Combo parts with BC racing and get crazy deals
Regards,
[email protected]
Old 08-09-2010, 01:33 PM   #12
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-10-2010, 02:31 PM   #13
IMPORTIMAGE
Trader Rating: (78)
PM or Call us to receive the best deals around!
We're more than happy to take care of you. Best customer service on Zilvia guaranteed!
Regards,
[email protected]
804-690-2452
Old 08-11-2010, 03:17 PM   #14
IMPORTIMAGE
Trader Rating: (78)
To the top!
Combo any parts to get a better deal.
Regards,
[email protected]
804-690-2452
Old 08-12-2010, 03:22 PM   #15
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-13-2010, 01:29 PM   #16
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-15-2010, 07:51 PM   #17
IMPORTIMAGE
Trader Rating: (78)
NOPE! PM US!
Regards,
[email protected]
804-690-2452
Old 08-16-2010, 05:59 PM   #18
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-17-2010, 09:07 PM   #19
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-18-2010, 10:34 AM   #20
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-19-2010, 10:20 AM   #21
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-20-2010, 02:45 PM   #22
IMPORTIMAGE
Trader Rating: (78)
Up to the top for the best prices around!
Combo any parts for the BEST deals.
Regards,
[email protected]
804-690-2452
Old 08-23-2010, 02:49 PM   #23
IMPORTIMAGE
Trader Rating: (78)
Up to the top!!
PM us for the best deals.
Regards,
[email protected]
804-690-2452
Old 08-24-2010, 04:01 PM   #24
IMPORTIMAGE
Trader Rating: (78)
BC Racing in stock ready to ship!!
Regards,
[email protected]
804-690-2452
Old 08-25-2010, 02:16 PM   #25
IMPORTIMAGE
Trader Rating: (78)
We have TONS of BC racing in stock and ready to ship!!
Ask about their "Extreme Low" Kit !
We will beat ANY competitors price!
Regards,
[email protected]
804-690-2452
Old 08-27-2010, 09:01 AM   #26
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-28-2010, 09:02 PM   #27
IMPORTIMAGE
Trader Rating: (78)
NOPE! PM US!
Regards,
[email protected]
804-690-2452
Old 08-30-2010, 07:41 PM   #28
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 08-31-2010, 12:50 PM   #29
IMPORTIMAGE
Trader Rating: (78)
Regards,
[email protected]
804-690-2452
Old 09-01-2010, 02:23 PM   #30
IMPORTIMAGE
Trader Rating: (78)
To the top for the best parts, prices, and service on Zilvia period!!
Come on in and let us know what you want! The more you buy the better your discount
Regards,
[email protected]
804-690-2452
