Old 03-25-2009, 12:30 PM   #1
s13tony
s13tony's Avatar
s13tony is an unknown quantity at this point
s13 sr20det oil filter help????????
sup guys its me again. just did an oil change on my s13 sr20 blacktop for the first time and was wondering if the oil filter that i used is the right one. reason i ask is because the filter that was on there was much bigger than the new one i got from nissan over in duarte. the old one model number is: AY100-TY015 by Pit Work. new filter is: 15208-53J0A by Nissan. thanks guys
s13tony is offline   Reply With Quote
Old 03-25-2009, 01:18 PM   #2
nissan240
nissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to all
you can always use the se-r oil filters!!! 91-94. btw you should just search next time it, will save you lots of time
nissan240 is offline   Reply With Quote
Old 03-25-2009, 01:23 PM   #3
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
yes sir that is correct the P# is
15208-53J0A
Dont forget to change your drain plug washer as well
P# 11026-01M02
WoolyS14DET is offline   Reply With Quote
Old 03-25-2009, 01:26 PM   #4
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
as long as it screws on the the gasket is the right size, it's the right filter.
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 03-25-2009, 01:27 PM   #5
Mr.s13r
Mr.s13r is an unknown quantity at this point
hey make sure u get the right one or else at high rpm it will pop the filter out and ur screw. Here is the right one for s13 blacktop n redtop that you could use from the se-r= 15208-53j00. This is for a fact because i have a s13 blacktop as well and i use some another model but from the se-r as well and it filter fell off on me. GL man.
ps- there are other filters from other cars that you can use as well though
Mr.s13r is offline   Reply With Quote
Old 03-25-2009, 01:27 PM   #6
WoolyS14DET
Trader Rating: (18)
Originally Posted by Mr.s13r View Post
hey make sure u get the right one or else at high rpm it will pop the filter out and ur screw. Here is the right one for s13 blacktop n redtop = 15208-53j00. This is for a fact because i have a s13 blacktop as well and i use some another model but from the se-r as well and it filter fell off on me. GL man.
FYI !!!!
15208-53J00 superceeds to a 53J0A
Old 03-25-2009, 01:30 PM   #7
Mr.s13r
wat is superceeds? im guessing it the same then
Old 03-25-2009, 01:32 PM   #8
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
Toyota part number 90915-YZZF1 works too. I have a 98 toyota corolla that uses that filter also. That way I can make just one trip to the toyota dealer and buy filters for both my toyota and my nissan. I have a s13 sr20det and have been using that filter for the past 4 or 5 oil changes. Also this filter is about an .5-1 inch longer so just a tad more oil capacity.
Also Toyota filters are made by Denso which are supposed to be one of the better filters out there.
garagelu is offline   Reply With Quote
Old 04-15-2009, 08:28 AM   #9
weshole
weshole's Avatar
weshole is an unknown quantity at this point
The Napa filter (which is made by Wix) is 1396. Very good quality filter imho.
weshole is offline   Reply With Quote
Old 04-15-2009, 09:51 AM   #10
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
i use a K&N KA24DE filter. why cause its much bigger for my SR and it seems to work pretty well. oil seems much cleaner after using it
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-15-2009, 07:56 PM   #11
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
Good idea!!!!
speedgod^s13 is offline   Reply With Quote
Old 04-15-2009, 10:42 PM   #12
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Easiest way to remember it...Redtops = 91 SER ; Blacktop = 95 SER.
CLICK HERE!!!
Old 04-15-2009, 11:27 PM   #13
iRONDONkey
iRONDONkey is on a distinguished road
arent OEM the best ones?
iRONDONkey is offline   Reply With Quote
Old 04-15-2009, 11:35 PM   #14
240=180
240=180's Avatar
240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about
oem oil filters are as shitty as frams
Battlescars FTW
240=180 is offline   Reply With Quote
Old 04-15-2009, 11:41 PM   #15
fliprayzin240sx
Who told you that crap???
CLICK HERE!!!
Old 04-20-2009, 12:36 AM   #16
iampoor
iampoor's Avatar
iampoor is an unknown quantity at this point
The Nismo Shop : West Covina Nissan : Nissan OEM Oil Filters not that bad if you order a few
iampoor is offline   Reply With Quote
Old 04-20-2009, 11:41 AM   #17
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
Its true, they did a nissan oil filter on one of the oil fiters exposed deals and it was complete shit. Ill try and find it.
n240sxfnatic is offline   Reply With Quote
Old 10-10-2009, 10:08 AM   #18
s13tony
s13tony's Avatar
i dont know man i used the oem oil filters and there not bad for 6 bucks from the dealer. they also have the nismo ones for better oil pressure.
Old 10-10-2009, 10:25 AM   #19
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
Yes where did you hear this. Plus iv been running fram's for the past 6 years never had one prob.
S14_Kouki is offline   Reply With Quote
Old 10-10-2009, 11:06 AM   #20
projectRDM
projectRDM's Avatar
Explain how an oil filter can produce better oil pressure.
FORMERLY R240NA
Old 10-10-2009, 11:59 PM   #21
s13tony
s13tony's Avatar
well thats what i said. i never used it. but nismo claims that it does produce higher oil presure
Old 10-11-2009, 12:06 AM   #22
s13tony
s13tony's Avatar
..... well thats what i was told by the nissan dealer in duarte. mynismo.com. ill try and find the link
Old 12-02-2011, 08:58 AM   #23
gotta240
Talking bout back from the dead. See, i searched!!!
Why do people say redtops use 91ser filters but blacktops use 95ser filters? Dont both engines have identical oiling systems? Why cant you use one filter on both?
2. If running a relocation kir, can one use the largest filter that threads on and seals regardless of make, model? Ie: arent all filters the same thing, just made in different sizes?
Old 12-02-2011, 10:28 AM   #24
!Zar!
!Zar!'s Avatar
It won't screw on because they are different sizes.
Yes you can run a huge filter if you want. If you are running something gargantuan I suggest priming your oil system after oil changes before starting the car.
Old 12-03-2011, 11:40 AM   #25
gotta240
Thanks!!!! So to clarify, filters dont have different pressure relief valves, or resistance to them? Just different sizes, right?
Why doesnt everyone stop running these tiny ass filters then? Its not like the sr20 carries a lot of oil as is.....it needs every additional drop you can fit
Old 12-03-2011, 12:13 PM   #26
!Zar!
!Zar!'s Avatar
sr20's don't really have a problem with oil capacity. The problem with them is their shitty oil pickup.
Old 12-22-2011, 08:26 AM   #27
fightinchunk
fightinchunk's Avatar
fightinchunk is an unknown quantity at this point
any word on mobil 1 filters?
fightinchunk is offline   Reply With Quote
Old 12-22-2011, 09:28 AM   #28
bb4_96
bb4_96 is an unknown quantity at this point
Cut that bitch open and find out
bb4_96 is offline   Reply With Quote
Old 12-22-2011, 09:45 AM   #29
Chaluska
Chaluska is an unknown quantity at this point
overpriced for sure.. expecially for something you are going to be replacing in a few months.
i have used every different brand of oil filter, and my oil always comes out the same in the end.
i have heard rumors of fram's exploding on big-block mudding trucks... but i havent seen pictures or anything to proove or dis-proove it.
edit...
here is a good showing of the comparisson between a few "popular" filters...
http://www.lxforums.com/board/f71/oi...-heavy-291232/
Chaluska is offline   Reply With Quote
Old 12-22-2011, 09:46 AM   #30
bb4_96
I'd be willing to bet exploding is an exaggeration
