![]() Join Date: Jan 2010
S13 to S14 Dizzy
Well... the tech section is gone and as the title states I would like to convert from an S13 to an S14 dizzy. The reason being is that I have two toasted S13 dizzys and 2 good S14 ones. I found a couple write ups on how to wire a S14 dizzy into an S13 but I'm not wiring-savy enough to make sense of it, let alone reverse-engineer the crap to put an S14 dizzy in an S13.
I've been chasing ignition problems since August and I'm gonna pull my motor for the 3rd time in December when I'm back for break more than 3 days. My idler sprocket is a tooth off making it impossible to time the car correctly and on top of that I killed my first distributor when I was cleaning it, put it in the car and the distributor killed the ecu, got a new distributor and the killed ecu killed my new distributor.. So now that I *fingers crossed* will be getting another DOHC ecu shortly. Anyways I have a picture and a link. I can make sense of the picture but someone said somewhere in that thread that it isn't that simple, and it leaves 2 wires going to no where (the 3rd that plugs into the ignitor chip, and that spade connector ground that goes to the coil). Picture: ![]() Link: http://jimwolftechnology.com/wolfpdf...TRANSISTER.PDF Thanks in advance for anyone's input.
#5 |
![]() Join Date: Dec 2010
![]() Feedback Score: 13 reviews
i was thinking of doing the same thing but dnt really under stand the diagrams ive seen
UNDER DESTRUCTION!: 91 s13 Top Secret Build |
#6 |
![]() Join Date: Apr 2004
Bump, can someone please shed some light on this. I have an S14 distributor I want to use on my S13 chumpcar.
#7 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
#8 | |
#9 |
Trader Rating: (58)
Doh! I didn't even see that hidden down there.
#10 | |
#11 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
my car has this...
dont forget u also need the resistor from the s14 harness...
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
