10-30-2011, 12:53 PM | #1 |
Fortune auto toe arms, is this normal
The gap (exposed thread), this concerns me as the bush sleeves on the arm float about. just need some reassuring.
On a side note if anyone has a spare toe arm inner bolt, nut & washer, the cam/adjustable one please let me know as i am missing one, unless it is ok for me to use a normal high tensile bolt now i have the adjustability of the arm itself? |
10-30-2011, 12:56 PM | #2 |
hmmm my isis ones were certainly a lot wider than that, had pretty much no gap at all are s13/14 different at all maybe you could have gotten a s13 arm?
10-30-2011, 01:19 PM | #4 |
Yeah get yourself some washers to fill in that gap. Just make it even in the middle.
You can use a regular bolt, but make sure it can't move around in the bigger hole. They make lockout kits for when you have adjustable arms.
10-30-2011, 02:15 PM | #8 |
Terry@Fortune-Auto (http://zilvia.net/f/members/terry-fortune-auto.html)
He has been nothing but helpful from my experience, he'll definitely take care of you. |
10-30-2011, 02:19 PM | #10 |
Lockout kits.
SPL sells this kit: SPL PRO SUSPENSION | 89-94 Nissan 240SX S13 Ballerbolts sells this one: Nissan 240SX S13 Suspension Bolts
10-30-2011, 03:10 PM | #11 |
thanks man! il get a set of those.
on a side note are these ok to use for the flange from prop shaft to diff?: 240SX Drive Shaft Bolt Kit S13 / S14 |
10-30-2011, 04:52 PM | #12 |
Pm'd you back. Just need some measurements from you.
Also we are heading out to SEMA this week so I apologize in advance for any delayed responses. |
10-30-2011, 09:44 PM | #14 | |
since nobody has made the statement after so many posts: s14 toe arm has longer gap in the subframe in order to use s13 after market arms you need wider misalignment spacers. btw, thought this has been common knowledge for years |
10-30-2011, 10:23 PM | #15 |
^^^ yeah what he said...
its only the ruca and traction arms that are the same width...looks like you have s13 toe arms and s14 subframe. did you buy the arms used? |
10-31-2011, 05:28 AM | #16 |
Iv only been in the s body game for just over a year, thats my excuse
I brought them new from FA for my s14, hopefully they can sort it when there back from wherever |
10-31-2011, 09:11 AM | #18 |
I was sent 14 toe rods on accident and theyre a lot wider than s13 subframe. do not put spacers or whatever else on there, either swap out the ends if you can or send them back for s14 ones.
AEM Series 2 ECU 30-6620 and Chase Bays S14 SR20DET engine harness for sale |
11-08-2011, 04:30 PM | #21 |
Oh, well I did not know this. Thanks for the clarification.
