![]() Join Date: Apr 2011
![]() I have just completed a rhd swap as well as a sr engine trans the hole shebang. Tester I was finishing up by installing my gauges and when I got to he greddy oil pres gauge I believe I wired it incorrectly to the ignition. Now the car won't start and wha I mean by that is there is no power. The battery is good all of the ignition and acc relays are good. I removed the gauge from the wiring and tried to start the car and still nothing. I also have a apexi auto timer but it came with a plug and play harness. I also replaced the fuse link on the positive battery terminal. So what do you think?
It's wired correctly there is no voltage to the ignition switch. When I remove the apexi timer still no start. It seems that something between the battery and the switch is stopping the car from start up.
#5 |
I did wire the gauge with batt still hooked up. All of the fuses are good. Thanks for the help. I have been working in this car for 3 months now and I had here running perfect before this gauge install.
#13 |
Well after some more trouble shooting I found that my 10 gauge 12v live wire that goes to my ignition switch from the ignition relay 1 was compromised. I replaced the wire and it works like a charm. If you ever have any ignition issues I would use this link as a basis to start working from. HOW TO: Check ignition switch and relays easily - SR20 Forum.
Thanks guys for the help let me know if there is anything I can help with. |
