11-06-2011, 02:50 PM | #1 |
KA24de Slight Clutch Grind Noise (Video inside)
Everytime I press the clutch in, the grind goes away. Everytime i release the clutch the noise comes back. whether its in neutral or gear. Still makes the noise...At :30 seconds you can hear what I'm talking about...
2011-10-25_17-50-33_36.mp4 video by rseslar - Photobucket |
11-06-2011, 03:51 PM | #2 |
Trader Rating: (56)
Feedback Score: 56 reviews
Have you ever had the clutch replaced? Mine was making a similar noise and it was my flywheel bolts. One bolt was backing out and the clutch disk was grinding on it.
11-06-2011, 04:40 PM | #4 |
Throw out bearing?? Since when u pushed the clutch in it faded. Mine was more of a whine though. Any problems going into any gears? Reverse is usually the first to give you troubles...
11-06-2011, 07:28 PM | #6 |
You hit the nail on the head, reverse gives me trouble almost everytime. I actually have to put it in first then shift to reverse for it to work.
I thought throw out bearing was only when it made a noise when you pushed the clutch in, not when you release it.. |
11-06-2011, 07:50 PM | #8 |
11-06-2011, 07:56 PM | #9 |
i highly doubt it, sometimes my reverse doesnt go in smoothly too until i go to 1st then reverse. if the noise bugs you get another trans, mines been doing it for 2 years but i recently picked up a temporary one so i can rebuild mine
11-06-2011, 07:58 PM | #10 |
2 years? if that's the case ill just let it go...Did the noise get worse over the span of that time?
11-06-2011, 08:18 PM | #12 |
Throw out bearing...$60 tops for it already pushed in, which I recommend unless you have machine/tool is almost impossible, but surely beats sitting at a light and one day it not go into gear and there you are... Poof be input shaft...BUT, like I said, more peace at mind. My trans always whined, but thats just the KA trans for you lol. Never had gear oil cause it would not hold it...Idk like I said rather have peace at mind and might just fix your problem.
11-06-2011, 08:24 PM | #14 |
Trader Rating: (56)
I originally thought mine was the throw out bearing but when we pulled the clutch you could tell. If it is your throw out, AutoZone had mine for $25-$30?
Best bet is pull the trans and investigate.
