12-12-2008, 10:58 AM | #453 |
I did the EVO front swap and the z32 rear swap on a S15 with ABS and BMC, can anyone tell me if this combination of caliper and BMC has performance issues ?
12-12-2008, 12:25 PM | #454 | |
Trader Rating: (128)
Feedback Score: 128 reviews
as far as performance issues its really up to the driver and what you are going to use it for. only thing else you should look into is high quality brake pads and or 2 peice hat and rotors for your application. if that doesnt work there is carbon ceramic rotors from the PGT |
12-12-2008, 05:07 PM | #455 | |
Oh and I'm still running the S13 non-abs MC. With hawk blues front/back (Z32 setup in the back) and 275 RA-1's on all four corners, braking is great. On 235 advan street tires I can get rear lockup if i don't heel/toe at threshold braking. |
12-13-2008, 04:07 AM | #456 | |
Same thing happend to me with the old brakets for the fronts...i've ran threw Endless ceramic pads in only 3 monthes of usual driving... pix (notic the "ring of rust" near the hat of the rotor) http://i198.photobucket.com/albums/a...g?t=1229166160 Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL. |
12-14-2008, 04:56 PM | #458 |
Trader Rating: (29)
Feedback Score: 29 reviews
You can try it and then realize that common sense would tell you no it will not fit. Esp when a evo brembo is almost 2x the size of a z32 caliper and the evo rotor is 1inch larger in diameter over a stock z32 rotor.
12-15-2008, 02:05 AM | #459 | |
The Z's Are 280mm and they fit on OEM S13/14/Z32/R32/R33/R34.... Evo Are 320mm With HUGE caliper... Short answer...No The EVO rear's (caliper and rotor) fit under The S14 rim tho, Ali
01-28-2009, 01:02 PM | #463 |
test fitted the rears today
*note the awesome jack and I'm aware air bleeders up I need to rant a little bit.. because I'm fucking annoyed trying to get a bracket made: I go to pick up a piece of mild steel at a steel shop 7in x1.25in x 0.50in I get their.. guy says all they have is 7in x 1.5in x 0.50in, note this stuff is 1/2in thick.. a hacksaw won't do and grinding it takes forever.. yesterday I call up another steel shop, ask if they have it.. they do, they close at 5pm so I wait till tomorrow today I drive down to that shop get the metal pieces drive home start measuring everything out go down to sears pick up the drill bits and a few angle grinder discs to make the notch go to kragen / checkers / autostore pick up some brake fluid and an extension on a brake line ( doubt I need ) I have everything to need to swap over the brakes... I go to start drilling and notice.. hmm this looks a lot smaller than a half an inch... measure it 1/4 of an inch! 7in x 1.25in x 1/4in / 0.25in those brackets people have up for sale.. are dam tempting heh, but I need this bracket done for tomorrow
01-31-2009, 03:37 PM | #464 |
Trader Rating: (43)
Feedback Score: 43 reviews
^^^are u doing evo fronts and sti rear or you completely changed to sti all around? hit me up if u need either brackets....
fdrea |
01-31-2009, 04:01 PM | #465 |
I just got done with a kit for my hardbody, im going to be doing the same on the 240 when I get done with the truck. Not a bad deal, the wilwoods are around $160 per caliper and I used 03 Cobra front rotors. 13" 4 pistons for a good price. Now the brackets are going to be a little bit of cash....
01-31-2009, 08:20 PM | #466 | |
02-01-2009, 01:10 AM | #467 |
Retired General
So are you running STi stuff all around or what?
02-03-2009, 02:07 AM | #469 |
I'm glad you decided to go Sti Brembos... you won't regret it. Promise man.
BTW, thanks for making the Stainless brackets as I requested florante... track marshall approves. |
02-03-2009, 04:28 AM | #470 |
florante rea :
How much for front brakets...? i'm selling my EVO front WITH out the brakets... And I'm upgrading to ROTORA BBK Front And EVO Rear's... PM me with the prices bro, Ali
02-03-2009, 01:32 PM | #471 | |
STI rears bolt on, EVO rears don't..... |
02-03-2009, 01:50 PM | #472 |
LOL I mean EVO rear....son check the page befor this one and you will know what the fuck i mean..... Ali
02-27-2009, 01:46 AM | #473 |
Trader Rating: (22)
Feedback Score: 22 reviews
anyone figure out how to run sti front rotors? i dont like how the evo rotors push the calipers out 10mm further than sti or z32 rotors do.
03-09-2009, 03:14 AM | #480 |
To be completely honest, you should know piston area and pad area for the 6pots you're using and compare that to Z32 fronts - I'm imagining they're 6 "small" pistons (as opposed to Z32's 4 "large" ones), so I'm guessing overall piston area and pad area shouldn't be too different... and you're using z32 rears, so that makes it even easier.
Just pointing that out for future reference, as this is a pretty tits thread for 'big brakes'.
