07-29-2022, 05:35 PM | #1 |
SR20 starts up but doesn?t idle, seeking insight
Seeking some assistance here, I recently did an SR20DET swap into my 90 s13 hatch, I got it to start up but doesn?t run or idle, it just kinda sounds like it chokes itself out, I tried holding open throttle while It cranks but nothing seems to happen just falls flat on its face, I currently have an AEM340 pump, radium fuel rail, 850cc top feed injectors, Apexi power ECU with commander, MAP sensor, wiring specialties harness and Greddy FMIC, any insight on why it?s not wanting to idle
07-30-2022, 03:29 AM | #3 |
So I haven?t hooked up my wideband O2 sensor yet, seems the wiring specialties plug is different from the AEM that I have, would that be an issue or can I run the AEM just on itself and not through the harness
08-04-2022, 06:11 AM | #5 |
08-04-2022, 01:48 PM | #6 |
Ahh I see so my best bet is to get a base tune then, I?m going to connect everything else and go about getting a tune then, thanks all for the input I?ll come back with an update lol
08-05-2022, 03:26 PM | #7 | |
Trader Rating: (130)
Feedback Score: 130 reviews
https://zilvia.net/f/showthread.php?t=226628 |
08-01-2022, 12:19 PM | #9 |
Sounds like you really just need to get a base-map installed in the ECU that accounts for injector size, etc. Verify it has a good startup tune first, then start chasing down other things like vacuum leaks or wiring/sensor issues.
08-01-2022, 02:10 PM | #10 |
have you verified FAST???
Fuel Air Spark Timing. start there, then report back *also make sure your fuel lines are not switched* |
08-03-2022, 09:24 PM | #12 |
Yea so that?s another thing I was also thinking I overlooked, since it starts up for like a few seconds and just dies, but when I open the throttle it tends to have no input like it just chokes out
08-04-2022, 11:22 AM | #15 |
yes, but there is also a "d-jetro" version of power fc that switches to MAP sensor.
