04-06-2014, 09:59 AM | #62 |
Interesting, never heard of blue/green oil before! It does have an even, thicker consistency, so I'm sure it isn't a mix of oil/coolant otherwise I would see the froth or separation between oil and coolant. Thanks for the quick inputs, maybe this motor is in even better shape than I thought.
Well, other good news is I got the bushing in all the way and got a new pressure plate. Not gonna take my chances with the old used crap causing me problems down the line. Now I just need to find a front sump pan setup...
89' KA-T S13 |
04-06-2014, 06:35 PM | #63 |
There wouldn't be any sludge if the engine was dry of oil and coolant was just sitting on the bottom of the pan. Little to no oil and sitting around for a while you won't see sludge.
wipe up some of it with some newspaper and let it sit overnight. If it's coolant/water based it will evaporate. If it's oil it will be the same as when you left it....mystery solved |
04-13-2014, 11:22 AM | #64 |
I was assuming turtle meths mounts were solid, but that's not the case. So I picked up some loctite PL S30 polyurethane. (1 tube per mount)
Cleaned the old stock mounts up with simple green and hot water Then filled them up and shaped with a putty blade Then let them cure in warm weather for the day (its cold here, I did it last night and right now they are still a bit gooey)
89' KA-T S13 Last edited by Panda-Eats-240; 04-13-2014 at 12:24 PM.. |
04-13-2014, 04:23 PM | #65 |
Trader Rating: (41)
Feedback Score: 41 reviews
Good to see another 1uz build thread going. Let me know how everything works out for you, or if you've got any questions.
"cigarettes killed my father, and raped my mother!" |
04-13-2014, 05:54 PM | #66 | |
Now that it'll be hardened do you think it would be fine to rotate the mounts 90 degrees so there's more mounting surface mount-to-mount?
89' KA-T S13 |
04-13-2014, 09:17 PM | #67 |
Trader Rating: (41)
You probably could if you'd like to, but I don't think there will be any advantages to doing so. Just make sure to keep the mounts loose until the trans is bolted up with the bracket because that is what determines the engine placement.
04-17-2014, 01:25 PM | #69 |
05-01-2014, 11:15 AM | #71 |
Yeah I was assuming they were solid, but I kinda like turtles mounts more being that I can change it up easier if I wanna try different hardnesses/heights out.
89' KA-T S13 |
05-07-2014, 09:34 AM | #73 |
Hey sorry, I did see your PM, I've been slammed on dealing with housing/schooling/newjob right now otherwise I'd be long done with this swap..
I could bolt it all up just to get mount alignments down but I still need a front sump pan so I'd rather not deal with unbolting it all and doing it back up again. I need some 1UZ god to just be like 'Oi...here's a pan and harness mate...'.
89' KA-T S13 |
05-10-2014, 11:37 PM | #74 |
Trader Rating: (41)
I can handle harnesses now, and I may have a front sump pan hanging out somewhere. I'll look around for it.
05-20-2014, 05:01 PM | #76 |
That would be amazing, let me know. Otherwise I'm at a standstill for now.
89' KA-T S13 |
06-29-2014, 03:46 PM | #80 |
Hi guys, I'm not dead! I cringe at the progress I've made on this.. It's taking me a long time but I promise to come through on it. Slowly but surely.
Here's how she sits on the stock motor mount/turtlemeth combo I picked up a new energy suspension master bushing kit from a buddy for a sweet price, that's what I'm currently working on. Tension rods completed with new bushings and #goldmember paint I got excited with my grinder and started on a cowl hood and tubbed fenders Solid steering bushing I also finally made it out to my first event!!! Brainerd Proving Grounds 2014.1 Our convoy for the way there Just one very small picture, I've got loads of pics and vids. Might post a couple more up later.
89' KA-T S13 |
06-29-2014, 08:28 PM | #82 | |
Drunk multi-colored galactic neon jizz fight one is Cody's, I'm not the biggest fan (mostly on neon colors) but it's definitely something different which I do like, and some areas would look sweet if it was consistent across the whole car
89' KA-T S13 Last edited by Panda-Eats-240; 06-29-2014 at 09:49 PM.. |
08-05-2014, 04:48 PM | #83 | |
08-05-2014, 07:24 PM | #84 | |
The rear/mid sump will not clear the crossmember, and I'd prefer to retain the best weight ratio possible and have room up front for a beefier radiator at the same time.
89' KA-T S13 |
10-09-2014, 10:42 PM | #86 | |
And from my understanding, theres no way the pan will clear with rear sump with how close the crossmember is to the firewall. If you're saying it can be raised high enough to clear the crossmember, I'd rather keep it low.
89' KA-T S13 |
12-10-2014, 06:29 PM | #87 |
Still not dead, I ordered up the oil pan conversion setup. I'll wait for that to get here and then can mate the tranny up and get everything final mounted.
I see the pictures have been removed from the host, I'll try to update the thread later with photobucket this time.
89' KA-T S13 |
06-03-2015, 12:51 PM | #88 |
In for the wiring =)
Contemplating doing this swap on one of my hatchs and run it while I finish my 2J. It'll all come down to $$$ and how easy the wiring is. I have tons of swaps under my belt, just about everything you can put into an S chassis so that's not an issue. I just have two 2J swaps I'm working on right now, so time is scarce. I just hate running this stock KA, and if it's an easy enough swap, it could be fun just to throw it in one weekend. I also haven't even seen anyone running the 1UZ in person yet, that's why it appeals to me.
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP |
03-02-2016, 08:46 AM | #89 |
My bad guys, this is still happening. I plan to have it finished up within the next month or two, and then will have to go through and basically just re-make a build thread because this has been pathetic.
89' KA-T S13 |
