Old 12-10-2011, 08:24 AM   #8821
Bob_Sagat
Bob_Sagat's Avatar
Bob_Sagat is an unknown quantity at this point
Is there a difference between s13 and s14 rear spindles? I have a set in my garage but can't remember what they're from lol.
Bob_Sagat is offline   Reply With Quote
Old 12-10-2011, 08:46 AM   #8822
Future240
Future Moderator
Future240's Avatar
Originally Posted by JasianBlazin View Post
When i turn on my ac its makes a constant loud clicking noise. ONLY when i set it to blow at my feet and face it doesn't make the noise. If i install a new climate control will it fix it? or do i just need a recharge?
If from dash
http://zilvia.net/f/tech-talk/197909...e-control.html
Originally Posted by ThatGuy
Future240 is online now   Reply With Quote
Old 12-10-2011, 01:00 PM   #8823
Vitzio240sx
Vitzio240sx's Avatar
Vitzio240sx is an unknown quantity at this point
Please help,
I've looked and searched for days and hours. I got an s14 with stock ka, however the idle is very high and rough. Usually when Im driving and come to a stop light the car will idle at 1700k and will not drop. Same thing when i turn it on, it goes right up to 1700k and stays there. Also when im driving around 2k-3k the car loses power and starts to stutter and buck as if it was not receiving fuel. I've checked for vacuum leaks, checked the fuel pump as well(ordered a walbro 255), cleaned the Maf sensor, recently did a tune and nothing. I was gona be cleaning the throttle body and IACV, also the engine harness and connections are very oily and dirty so I was thinking of cleaning that as well. Question is what else can i look for? and also when i clean all this parts do i use carb cleaner? and with the wiring can i also use carb cleaner? Im gona clean everything and see the results.
thank you everyone, any comments, questions, complaints are highly appreciated!
-Was also thinking about replacing the coolant temp sensor.
"Men with guts attack those corners!"-Keiichi Tsuchiya
Vitzio240sx is offline   Reply With Quote
Old 12-10-2011, 04:38 PM   #8824
lg54
lg54 is an unknown quantity at this point
Hey guys.
What are the parts needed for an sr20det REFRESH??
Water pump, gasket kit, what else??? Timing chaing? what else?
please help! thanks
lg54 is offline   Reply With Quote
Old 12-10-2011, 07:55 PM   #8825
Dudegonefresh
Dudegonefresh is an unknown quantity at this point
I went KA24det and took off the kit. I used a n60 maf and safc. Car wont run right just bogs. I just got a stock g20 Maf and i need the pin outs for a stock maf. I got a pigtail from a altima and sentra either one works. But what are the pin outs from left to right , driverside being right. THanks and yes i searched and found (1)white (2)black and (3)white and black
Dudegonefresh is offline   Reply With Quote
Old 12-10-2011, 11:12 PM   #8826
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
what kind of code scanner should buy to use on my 240's
they are both s13's with stock ka-e and ka-de
Old 12-11-2011, 12:22 AM   #8827
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
Just use the diagnostic mode by turning the screw on the ECU. Otherwise you'll be stuck hunting down all of the CONSULT stuff, which won't be useful for any other car. Unless you're ultimately going to run Nistune, I wouldn't recommend it. That said, you'll need a CONSULT to USB adapter and some kind of software.
Google is your friend.
Prime is offline   Reply With Quote
Old 12-11-2011, 02:29 AM   #8828
ZenKi_373
ZenKi_373's Avatar
ZenKi_373 is an unknown quantity at this point
what the hell is the exhaust called when its bent at a 45 degree angle and comes up high. i knew a few actual co. that made it without actually welding it. care to aware me? refer to link
.its.a.lifestyle.
ZenKi_373 is offline   Reply With Quote
Old 12-11-2011, 09:54 AM   #8829
hartig
hartig is an unknown quantity at this point
i think the nismoshop used to sell kouki tails separately.. they dont seem to anymore..
anyone know a site that does? i just need a left light
hartig is offline   Reply With Quote
Old 12-11-2011, 11:30 AM   #8830
delado
delado's Avatar
delado is an unknown quantity at this point
Where can I find Silvia side skirt replicas? I can't seem to find them :/
delado is offline   Reply With Quote
Old 12-11-2011, 11:55 AM   #8831
7evil
7evil's Avatar
7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough
Anyone have the specs list of the Nissan Silvia S13 that won the JDM All Stars with Luke Fink?
七転び八起き
7evil is offline   Reply With Quote
Old 12-11-2011, 02:26 PM   #8832
rat240
Trader Rating: (87)
thanks
im going to try the cel light thing
Old 12-11-2011, 03:52 PM   #8833
Banana_Cute
Banana_Cute's Avatar
Banana_Cute is an unknown quantity at this point
Looking for a place that would or could possible refurbished/ re coat my cracking and old Nardi wheel.
Orange County, California preferred, or Inland Empire. Southern California.
Thanks.
Simplicity is the key to brilliance
Banana_Cute is offline   Reply With Quote
Old 12-11-2011, 04:46 PM   #8834
PNgo12
PNgo12 is an unknown quantity at this point
Okay I'm not yet ready to accept that my VLSD is going bad that it's turning into an open.
I've googled searched and nothing really satisfied what I need to know. I'm running 75/90 redline gear oil in my diff but its not really locking and I don't remember if I used GL-4 or 5 but when I searched some are saying use GL-4 while others say use GL-5 and some say use the additive and some say don't since its already a closed unit and does not need it. I'd like to put this to rest. Should I be using GL-4 or 5 and do I need the LSD additive? I'm also going to be switching up to 80/90
PNgo12 is offline   Reply With Quote
Old 12-11-2011, 07:56 PM   #8835
mowgli 240sx
mowgli 240sx's Avatar
mowgli 240sx is an unknown quantity at this point
would a stock air intake piping off of a s13 ka24de fit on a s14 ka24de ??
mowgli 240sx is offline   Reply With Quote
Old 12-11-2011, 10:08 PM   #8836
rat240
Trader Rating: (87)
I tried a s14 intake on a s13 kade
And the bends are different and the s14 has less Bungs than the 13 one
Old 12-12-2011, 02:53 PM   #8837
sdterrible1
sdterrible1's Avatar
sdterrible1 is an unknown quantity at this point
Any one know why this would happen? Lowered car more. Car is probably close to 1 deg - camber. Now coliover body is hitting the toe rod bolt.. Any ideas?
sdterrible1 is offline   Reply With Quote
Old 12-12-2011, 06:24 PM   #8838
daftphunk
daftphunk's Avatar
daftphunk is an unknown quantity at this point
So as I was driving today I heard a loud clunk. Saw a bunch of smoke coming out from behind and eventually a lot of clunking coming from the rear end.
When I pulled over to take a look at it, I saw smoke coming out from my diff it seems like. I had a welded diff and it's all clunky now, I'm going to just guess that I broke the welds on it. Would that be a safe assumption?
And I am about 25 miles away from my house, how safe would it be to drive it home? Or am I better off just getting it towed on a flat bed tonight? Was thinking of pulling the diff out tomorrow but was gonna see if a shop can get it on a lift and just reweld the gears together.
How plausible is all of this?
daftphunk is offline   Reply With Quote
Old 12-13-2011, 02:34 PM   #8839
fckillerbee
fckillerbee's Avatar
can someone PM me telling me what/where that rear fender lip is and where I can find one. I've searched URAS stuff, and had no luck.
Mucho thanks.
Old 12-13-2011, 02:35 PM   #8840
fckillerbee
if it's your diff....then eventually one of those welds may get stuck inside, and lock it up (my buddy had it happen on the freeway. Instant drifting on the HWY).
Drive slow if it's worth it to you. 25 miles is a ways away.
Old 12-13-2011, 04:13 PM   #8841
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
Ok so i installed my coils. After i got done i noticed my camber became different in the front, like this and yes the offsets and tire size is the same, what im wondering is if i get my car aligned with they fix all the camber and make both the same because it looks like my passenger side has positive camber? any input is greatly apperciated. (hope the pics help explain what im trying to get at.)
drivers side
passenger side
Jonathong is offline   Reply With Quote
Old 12-13-2011, 04:35 PM   #8842
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
did you adjust the camber plates on top...
did you make sure the 2 bolts on the bottom mount were equal pushed in/out when you tightened them on.
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 12-13-2011, 04:55 PM   #8843
Jonathong
Jonathong's Avatar
i didnt adjust the camber plates at all,
hmm i should do that, looks like im gonna try installing my coils again lol
Old 12-13-2011, 05:06 PM   #8844
JonathanPrem
JonathanPrem's Avatar
JonathanPrem is an unknown quantity at this point
Can you start s20det with out intercooler piping to see if the motor is fine? Car will be running with map senor.
JonathanPrem is offline   Reply With Quote
Old 12-13-2011, 05:55 PM   #8845
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
Originally Posted by Future240 View Post
thanks for the help! and yes its from the dash!
JasianBlazin is offline   Reply With Quote
Old 12-13-2011, 06:34 PM   #8846
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
You don't have to reinstall them to adjust the camber plates. And if you were to get an alignment (which I recommend to make the car feel great) they will set the camber back to what you want it at. On both wheels, evenly.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 12-13-2011, 06:37 PM   #8847
David48
David48's Avatar
David48 is an unknown quantity at this point
Send a message via AIM to David48
If the camber plates are even then check that the top bolt on the lower mount of the coilovers is pushed all in or all out as evenly as the other side.
David48 is offline   Reply With Quote
Old 12-13-2011, 06:39 PM   #8848
Irresistible
Some coils don't have slots. Some just have holes that are even. And some are just holes that are offset. So that's not always the issue. When you lower your car, the toe gets affected as well, so that might have an impact on how it looks.
Old 12-13-2011, 07:05 PM   #8849
Most Wanted
Most Wanted is an unknown quantity at this point
Im a put my BOV on the cold pipe, and put a small adapter for the waste-gate on the hot pipe, will J-B Weld with their cold weld be enough and not mess up on the inter cooler piping?
Most Wanted is offline   Reply With Quote
Old 12-13-2011, 10:33 PM   #8850
chiboy002
chiboy002 is an unknown quantity at this point
are you serious?
take it to a shop, they can weld it on super easy. don't be fucking stupid
street dancer.
GLEAM
