05-02-2011, 03:16 PM | #5851 | |
and yeah the valve cover gasket. I'll be replacing head gasket as soon as bolts arrive
street dancer. GLEAM |
05-02-2011, 03:27 PM | #5852 |
So ive been looking around for this bumper and can only find it through Shine Auto themselves. They quoted me 350 for the front bumper.
My question is, how much do these go for used? or anyone who makes a very similar bumper because im guessing this is already a replica of something.
"Show no compassion, like having a straight face orgasm" |
05-02-2011, 06:30 PM | #5854 |
I was driving my car today and started it up about 4 times perfectly fine, but after I shut it off to go into my house to grab a few things before I went off to class I tried starting it up and it will not turn over. All that happens is I hear a drill-like sound when I turn the key in the ignition, but the engine wont crank or turn over. Is this a bad starter or something else? Any help would be great, thank you very much in advance
05-02-2011, 07:22 PM | #5855 | |
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
05-02-2011, 08:23 PM | #5856 |
can anyone please help me out?
05-02-2011, 09:17 PM | #5860 | |
expect it to sell for like 8$ this is the dumbest question ever
05-03-2011, 12:53 AM | #5861 |
tried searching, no luck...very simple question:
for those of you s14s that have fortune auto 500 coils, what rim clearance do you get? what is the highest offset you can get away with for any given width before the wheel hits the strut housing? all i need is a few figures to do my own calculations...
s14| y34| 911 gts| exige s| 600rr| r3| 250r| 85 girlfriend |
05-03-2011, 10:21 AM | #5862 | |
05-03-2011, 11:17 AM | #5864 | |
If you don't have access to an impact.... then breaker bars and pb blaster are your only friend. Grounds are always good. No sense in removing them
This is my clever and witty signature. |
05-03-2011, 02:35 PM | #5866 |
ok guys, i have a question about fitting a 18x10.5 +15 in the front of an S14 Kouki with rolled fenders. i have went through many pages of the wheel fitment and max rubber thread, and i couldnt really find much info about it.
if someone can tell me if a 18x10.5 +15 will fit please lemme know asap! thanks!! |
05-03-2011, 03:43 PM | #5867 |
Okay i have a Kouki S14, i was just wondering what the inside of the roof looks like with no headliner? i was thinking of removing it for no reason at all...
97 Starfire Blue/93 Coupe, Black-SOLD 98 Starfire Blue-Auto, 1 owner, 102k |
05-03-2011, 08:38 PM | #5870 |
The wastegate needs to be connected to a pressure source as close to the turbo as possible. Ie compressor housing or hotpipe Do not use a signal from the intake manifold because engine vacuum will damage the diaphragm inside the wg. As for the nipple on the cold pipe that 1 inch connection is for the idle control. Do not use that. If you do not want to drill and tap the compressor housing or have a nipple welded to your hotpipe you can use something called a quick tap. You simply drill a hole in a silicone coupler and insert the fitting. This is what I use and works great. No boost leaks. Search atpturbo.com to find it.
05-03-2011, 08:59 PM | #5872 | |
Trader Rating: (58)
Feedback Score: 58 reviews
The cold pipe nipple or intake willbe fine. If you're that concerned, why not goto a welder and have a fitting put on your hotpipe? Like shit. Leave it in unless the rest of the car is a ragged gutted machine.
05-03-2011, 10:40 PM | #5873 |
i was taking off my head to replace the gasket and realized i removed the bolts in the opposite order like a retard...
I removed them in the order that you do if you are tightening it, cause i thought i had the tighten sheet with me at the time how fucked am i? i did it in 2 steps, i haven't completely taken it off to check distortion but what are the chances of it being junk now... if you don't get what i'm saying, i started with the intake side middle bolt and worked my way to the furthest back exhaust side bolt, 3 steps, instead of doing it the opposite way (starting at last exhaust and working inward)
05-03-2011, 11:56 PM | #5874 |
Trader Rating: (58)
You'll be just fine. The big thing is when you retorque it back down with the new HG to follow it in order.
Also remember that if using ARP studs, to torque them in order in increments of 10-15 up until 85 ft lbs.
05-04-2011, 12:24 AM | #5875 |
so i was changing out my headlight and i can't get the metal trim piece
and backing that goes around the headlamp housing off since the bolts are rusted pretty bad... (piece 3 and 4) and since i need it to hold the headlamp in place, I was wondering if it's possible to buy a replacement part? or if there are any other options? thanks! |
05-04-2011, 01:28 AM | #5876 |
are RB and SR clutch line fittings the same size/pitch at the slave?
on the reinforcement or the support bracket? it won't mount right on the support bracket, the zenki one curves up in the middle, the kouki is straight.
05-04-2011, 03:00 AM | #5877 |
noob question, but are there any discernible differences between s14 "zenki" and s14 "navan" sides? maybe im not paying enough attention, but they look the same to me...
05-04-2011, 05:28 AM | #5878 | |
05-04-2011, 06:55 AM | #5879 | |
thanks man, i would done it the fsm way lol
05-04-2011, 11:58 AM | #5880 |
So Im going to try posting in here before I make my own thread for this. Since I pulled the car out of storage this year when i start my car none of the power options (windows, locks, climate control, radio, dash lights or gauges) operate. There is absolutely no power to anything until i tap the throttle to give it a little rev, then it seems to jump alive, and everything starts to work again. I just replaced the battery and had the alternator checked so I dont know what could be causing this. The power locks also dont work after the ignition is turned off, which they did before.
Any help would be appreciated. Thanks. |
