Old 04-10-2014, 06:44 PM   #1
stayclassy
stayclassy's Avatar
stayclassy is an unknown quantity at this point
S14 SR20 limp mode?
Hey guys, I recently just got my s14 on the road, everything seemed great until I hit a puddle. After hitting the puddle my RPMs dropped then CEL came on, started dumping fuel reading 10.0 afr, won't go over 3k RPMs, and I don't have a fuel pump prime. I Checked all my grounds, changed MAF with a known good one, and replaced CAS. Reason for replacing CAS was because when I unplug it, the fuel pump primes? When I eventually get it running it seems to be in limp mode. Doesn't run any different if I disconnect MAF either. Starting to think I have a bad ECU? Right now I have a WC with nismotoronic so I can't really pull any codes. Prior to hitting the puddle, the car wouldn't warm up so it's possible I may have a bad coolant temp sensor? Thanks for any help, please don't tell me to search because I've searched every thread I could find and none of them seem to have the same symptoms I'm having.
stayclassy is offline   Reply With Quote
Old 04-13-2014, 10:30 AM   #2
stayclassy
stayclassy's Avatar
No input from anyone?
Old 04-13-2014, 11:02 AM   #3
Def
Check all your fuses and relays.
S13 Hatch - Goes around tracks quickly
DEFSPORT
