Old 04-16-2014, 09:02 AM   #1
1quk240
Banned from the Marketplace
1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough
SR Turbo building boost at idle
Just finished up things on my SR and so I start the motor and the turbo is building boost. It's a GTX3076. The vaccum is at 0, when I give it a little gas the vaccum drops to where it should be around (17-20).
It's running off the base map of a PFC, has 256 cams.
Also, the downpipe had a crack in it which is getting fixed today but not sure if that big of an exhaust leak would cause the turbo to do this?
Anyone else ever have this type of problem?
1quk240 is offline   Reply With Quote
Old 04-16-2014, 09:27 AM   #2
wowzers9930
wowzers9930 is an unknown quantity at this point
vacuum leak I would say
wowzers9930 is offline   Reply With Quote
Old 04-16-2014, 09:30 AM   #3
Scott@FontanaNissan
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
im going to vote you have your vacuum line in the wrong spot.
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
Old 04-16-2014, 09:47 AM   #4
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
This^^^
Are you sure it's actually building boost, or does your boost gauge just "say" it's building boost?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 04-16-2014, 09:53 AM   #5
sr23det
sr23det is an unknown quantity at this point
anti lag ftw!
sr23det is offline   Reply With Quote
Old 04-16-2014, 11:30 AM   #6
cotbu
cotbu's Avatar
That not considered building boost at idle so your title is wrong. Most likely case is the vacuum line for your boost gauge is hook up wrong that means to a source before the throttle body or something similar. A vacuum leak that big would be audible from the engine bay, if not boost leak test it.
Old 04-16-2014, 12:00 PM   #7
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
As said above you need to use vaccum after the Throttle body, Mine is T'd off from the FPR line and reads -22 at idle.
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 04-18-2014, 08:25 AM   #8
Boostd2
Boostd2 is an unknown quantity at this point
the number 0 vacuum (gauge indicated) is not actually positive pressure. It means that the pressure/vacuum is equal to that of the surrounding atmosphere. Which is 14.7 psi sea level.
anothing above that is considered positive pressure/boost. ( so 0 on your gauge is really 14.7 psi absolute pressure.)
but as others mentioned above, simple fix involving changing the vacuum source of your gauge, and other things you currently have routed that way.
Boostd2 is offline   Reply With Quote
