Old 03-07-2017, 07:31 PM   #1
brokenheartedhatch
brokenheartedhatch is an unknown quantity at this point
Sr20det CAS timing problem
So I'm trying to check my cas timing on my black top to narrow down why this thing isn't starting.
The problem I'm having is, I don't have 2 links in the timing chain that are darker than the others like there should be.
Any idea why this may be? And where do I go from here?
brokenheartedhatch is offline   Reply With Quote
Old 03-07-2017, 08:40 PM   #2
Kingtal0n
Kingtal0n's Avatar
you turn the engine so that both cyl#1 cam lobes face outwards. The dots on the cams will go 10 and 12, roughly when you do that. You then look down at the crank to make sure it shows piston 1 TDC. Count the links between the dots to make sure it is the correct number of links also.
Then stab the CAS.
Old 03-12-2017, 09:44 PM   #3
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
Then stab the CAS.
Bingo. You don't need the colored links. Cam lobes facing out, crank at second link from left. Cam Dowel pins at 10 and 12.
When you put the chain on the cam sprockets count 20 link roller pins between the dots on the cam gears. Stab the CAS and you're at 15*.
rc1honda is offline   Reply With Quote
Old 03-20-2017, 05:55 PM   #4
brokenheartedhatch
Right on, got it set.
Thanks guys!
