Old 11-09-2011, 07:35 PM   #8491
CantSTOP
CantSTOP's Avatar
CantSTOP is on a distinguished road
Originally Posted by codyace View Post
Reground the MAF to the chassis. Google it. If it turns on and shuts right off I'm still puttin gmoney on sensor related, not timing.
So I was checking the coolant temp sensor(CTS), and the plug was fcuked up! So I bought a new sensor anyways. Installed it, The car would stay on for more than 5secs now but eventually drop idle and die. But heres the weird part now...when I unplug the CT harness from the sensor the car stays on, rough-to-ok idle. Now when I step on the brake pedal, idle drops and if I keep pumping the brakes the car will die. So do I have a vacuum leak? or bad brake booster?
And I don't know if it's another cause to my problem but I do have a leak from the header. Missing like 3 bolts T_T car came like that. That would cause me running rich? but would it cause the car to die/stall?
HI HATERS! from the left to the right
CantSTOP is offline   Reply With Quote
Old 11-09-2011, 07:54 PM   #8492
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Originally Posted by machuca212 View Post
NEED OPINIONS!
whats the best way to relocate the wiring harness in the wheel well on a s13?
just started to rub the wires about to rub right through a couple of them. could you possibly post a link for a how to as well. thanks
Under the hood. Unplug and relocate. You can also pull it up. Or fab up a plate or some sort. Use the search function. Common enough problem that there is many threads on this. C'mon man.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 11-09-2011, 08:24 PM   #8493
KravingAKouki
KravingAKouki is an unknown quantity at this point
Is there a way to repair frame rust without having to cut out the rusted peice and having to weld a new piece in?
KravingAKouki is offline   Reply With Quote
Old 11-09-2011, 08:31 PM   #8494
Irresistible
No. msglngth.
Old 11-09-2011, 09:12 PM   #8495
chiboy002
chiboy002 is an unknown quantity at this point
NEED OPINIONS!
cheapest way = beer/coke cans + steel zipties
this is also very shitty and is just a bandaid
remove fender and pull it up or relocate it so its nice
Old 11-10-2011, 07:24 AM   #8496
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
ENGINE GROUNDS:
What are you guys running for engine grounds? One of my grounds, the braided one on hte back of the head with teh little clip, is getting hot, and arcing it looks like on start up. No idea why... Im starting to lose it with this car.
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 11-10-2011, 08:53 AM   #8497
joshls2
joshls2's Avatar
joshls2 is a well-known jackass
Hey, can someone point me in the right direction?
I'm doing a full suspension rebuild/upgrade and the last parts that I need are LCA bushings(front & rear) and tension rod bushings. ..but, of course, nissan doesn't sell 'em separate.
So does anyone know where I can get rubber LCA and tension bushngs?? ..I don't really wanna use poly for these arms.
joshls2 is offline   Reply With Quote
Old 11-10-2011, 10:17 AM   #8498
alcorp
alcorp's Avatar
alcorp is an unknown quantity at this point
s13 straight pipe, exhaust, apexi n1
Okay I came up on a apexi n1 exhast cannon but only the muffler and no resonator. If I were to put the apexi and put it straight to the cat, would it be loud? Would it sound all ricey and gay or would it sound mean and good? also should i just take off the cat and just go all straight piping and just have a muffler?
alcorp is offline   Reply With Quote
Old 11-10-2011, 03:05 PM   #8499
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Exclamation
NEED OPINIONS!
http://zilvia.net/f/chat/407974-tuck...like-baws.html
Search a lil better next time.
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 11-10-2011, 03:05 PM   #8500
niteridaz503
what motor are you running?
Old 11-10-2011, 05:22 PM   #8501
chiboy002
anyone know a good high temperature heat that looks like the gold brembo color?
ive only seen a few pale golds and then like orange-golds. nothing yellow-gold
Old 11-10-2011, 06:31 PM   #8502
azsr20det
azsr20det is an unknown quantity at this point
if i remove the up and down adjustment stuff from my steering column, does it stay in the location i left it in when it was removed? or fall limp or what?
i wanna take it off so i can put my gauge trim back in, and im thinking id just leave it off.
looks way cleaner without the plastic cover/wiper & signal stalks
car doesnt need wipers, i can put headlights on a switch, and signals dont appear to work anyways. im sure they could be given buttons if i really need them
question was the first bolded part.
rest was additional jargon, feel free to give imput on that too.
azsr20det is offline   Reply With Quote
Old 11-10-2011, 07:50 PM   #8503
dontxploitme
dontxploitme's Avatar
dontxploitme is an unknown quantity at this point
ok i tried installing godspeed gen2 toe arms on my s13 today but i couldn't get them in.
that part was too long and i could only get it in if i took off one of the little round end pieces but with 2 there was no way it would fit. i'm wondering maybe there's smaller ones for s13's cause if i remember correctly the s14 part where it bolts up is bigger. anyone know what this could be?
dontxploitme is offline   Reply With Quote
Old 11-10-2011, 08:50 PM   #8504
WERDdabuilder
WERDdabuilder's Avatar
from reading this thread...
http://zilvia.net/f/chat/416544-fort...ms-normal.html
seems like they gave you the wrong spacer(from s14 which are bigger).
may be that is some help.
When the power of love overcomes the love of power, the world will know peace
Old 11-11-2011, 10:02 AM   #8505
300ZXttZMAN
300ZXttZMAN is an unknown quantity at this point
Can i use a stainless steel bolt for my koyo radiator drain plug
hello yall do i have to have a titanium radiator drain plug or does it have to be titanium.. I was just wanting to be able to get it at my local hardware store...
Thanks in advance
My car is a 1990 twin turbo 5spd highly modified no confirmed dyno here is build thread.
300ZXttZMAN build thread.. Its time to go broke or GO HOME! : 300ZX (Z32) General - Page 2
LOOk at page one also. to see the parts..
this is the size of the plug
The plug is 10mm x 1.25
300ZXttZMAN is offline   Reply With Quote
Old 11-11-2011, 08:49 PM   #8506
newlovekid
newlovekid's Avatar
Trader Rating: (43)
newlovekid is an unknown quantity at this point
Feedback Score: 43 reviews
*edit... nevermind figured it out
newlovekid is offline   Reply With Quote
Old 11-11-2011, 09:36 PM   #8507
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
Ok, so I installed my coils and when i turn the car in full lock (doing a U-turn) I hear creaking coming from the front driver side anyone have an idea of what this could be? worn out bushings?
Jonathong is offline   Reply With Quote
Old 11-11-2011, 09:56 PM   #8508
WHAPSH
WHAPSH is an unknown quantity at this point
Hey guys I don't have a 240 but my brother in law has a s14 kouki bone stock and I was wondering what would be a good mod for it under 200 dollars? Any help would be greatly appreciated!
WHAPSH is offline   Reply With Quote
Old 11-11-2011, 10:52 PM   #8509
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Rubber Megan bushings on ebay, Nismo bushings or replacement OEM arms are your best options.
Originally Posted by azsr20det View Post
if i remove the up and down adjustment stuff from my steering column, does it stay in the location i left it in when it was removed? or fall limp or what?.
Falls limp
If it's like a spring binding noise then that is 'normal' for most coils.... there really should be a bearing on the spring so it can rotate without binding but for whatever reason there isn't on most coilovers. You can try torrington bearings but I hear they don't last long.
If it's more of a popping noise try tightening the top hats/camber plates
Old 11-12-2011, 08:25 AM   #8510
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
does anyone know the specs to this part: 55424-33P00 (S14 Differential Bushing Long Bolt)
i need to try and find it at a hardware store today, i just need to know the threading, pitch, length yadda yadda. thanks in advance
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 11-12-2011, 10:39 AM   #8511
KravingAKouki
Is it possible to remove frame rust from a door jam on the driver side on a kouki?
Old 11-12-2011, 03:28 PM   #8512
Origin
Origin is an unknown quantity at this point
Msglength+10
Origin is offline   Reply With Quote
Old 11-12-2011, 04:47 PM   #8513
projectanna
projectanna is an unknown quantity at this point
Check the vac lines to the egr mine were clogged scratched
my head all day checking compression and fuel
and all it took was 3.99$ worth of hose
projectanna is offline   Reply With Quote
Old 11-12-2011, 05:29 PM   #8514
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Has anyone used the Circuit Sports 340lph fuel pump? Any pros and cons? Noise, fitment in the tank, longevity etc.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 11-12-2011, 05:37 PM   #8515
killer skittle
killer skittle is an unknown quantity at this point
Save the headaches and go with walbro
killer skittle is offline   Reply With Quote
Old 11-12-2011, 06:32 PM   #8516
niteridaz503
Cold air intake like 150 for an AEM
Old 11-12-2011, 07:47 PM   #8517
Jonathong
Jonathong's Avatar
has anyone ever cut the muffler tips off a twin n1 style exhaust and just replace it with pipes, making it look like the trust DD exhausts?
Old 11-12-2011, 07:52 PM   #8518
240Lover770
240Lover770 is an unknown quantity at this point
Originally Posted by 240Lover770 View Post
im not a stranger to 240s and i have searched google and this sight and im stumped...but i just did a 5speed swap to my 92 SE and now she idles at damn near 1500rpms and i dont know why. the idler screw is all the way in and it still does the same thing. i also checked mythrottle cable and cruise control cable and there both fine. i also still have the auto ECU. 2nd i put in a brand new clutch and now i hear sort of a buzzing noise coming from the tranny near the flywheel. it sounds like the throwout bearing but i dont understand how when its new. you mostly hear it in neutral and when you accelerating in 1st 2nd and 3rd gears. you dont hear it in 4th and 5th. any impu would be appreciated
help anybody?
240Lover770 is offline   Reply With Quote
Old 11-12-2011, 07:55 PM   #8519
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
it's most likely the auto ecu. my idle jumped up a bit when i 5 speed swapped and left the auto ecu.
SW Fab
shiftdrift is offline   Reply With Quote
Old 11-12-2011, 08:19 PM   #8520
chuki.s13.coupe.
chuki.s13.coupe.'s Avatar
chuki.s13.coupe. is an unknown quantity at this point
What is the part connected to the steering rack, that all the hard lines connect to called? It has 3 wierd looking bolts
chuki.s13.coupe. is offline   Reply With Quote
