Old 03-31-2008, 07:28 PM   #1
s1495
s1495 is an unknown quantity at this point
Timing Issue
Hia people
This is on KA-T with '95 KA24DE.
What could be causing timing to be 30 BTDC. I recently replaced turbo and IACV - have 22 HG of vacuum so I know it's not leaking, idle is bit high - about 1100. TPS is around 0.45v, MAFs works, car misfires.
If I rotate distributor to the left (front of the motor), it gives me 30 BTDC. If I rotate to the right - I get about 44 BTDC.
I've tried setting TDC over and over several times but same result.
Any help would be appreciated.
Thanks
s1495 is offline   Reply With Quote
Old 03-31-2008, 10:57 PM   #2
slider2828
slider2828's Avatar
Isn't the KA 20BTDC? Did it recently change? Was it right before?
Turn and Burn!
Old 03-31-2008, 11:01 PM   #3
murda-c
murda-c's Avatar
make sure your tps is unplugged when you check the timing.
otherwise the ecu might have fed some advance in.
