Old 03-15-2012, 05:17 PM   #1
EvolutionVIII
EvolutionVIII is an unknown quantity at this point
FS/FT: 1998 Nissan S14 Fully Built RB25 **CUSTOM AND CLEAN**
Up for sale is my monster 1998 RB25 S14. Alright heres the story, A few months ago i traded my truck for this car. When I got it, it was blowing smoke from the exhaust and the guy told me it was because he put some oil cleaner in the oil and it was shooting all the bad stuff out the exhaust. It turned out, he lied to me and the motor was blown with damage to all 6 cylinders from running too much boost on stock internals(17 psi). He refused to trade me back or pay the money to fix it so I had to spend $5500 to get the engine fully rebuilt and build the internals to handle the power. So the engine was JUST built like 50 miles ago and I have ALL the paperwork to prove the work done!! It was built by SR20Store and it runs absolutely perfectly with no issues at all! Im still breaking the motor in. With that said, the car is absolutely perfect. The interior is absolutely perfect 10/10 with leather back seats and no rips, tears, or scratches anywhere! the exterior is 8.5/10 as there are a few cracks here and there but nothing too bad. It's still extremely clean! The swap was done almost perfectly and looks like it comes stock like that. Everything was done really clean and a lot of time and money was put into this car. I am looking to sell or trade it. Price is now 17k OBO. I can also keep the wheels and seats to lower the price a little. Im in absolutely no hurry to sell so you can leave your lowballs at the door! As for trades, I'm looking to get into something like an Evo or an STi. This car is a great, really fun car that with the build, can be running 600 hp. It is tuned at 422 hp to the rear wheels and it is running that reliably! I have dyno sheets too! This is a true 98 S14 and there were only 1000 98s produced in America! Heres the list of mods!
BODY/Chasis
- Clean Title 1998 Nissan 240sx LE Kouki w/ ~230ishKM on body(138k miles)
- S14 rare cream beige leather back seats
- Powered sunroof (it doesn't leak!! I know!! Weird, right!?!?)
- No surface body rust and cleanly maintained
- Spare tire removed
- Windsheild washer fluid removed
- AC system removed
ENGINE
- Series one Rb25DET with about 50 miles on it. Just fully built by SR20Store
- GM 3-bar map sensor
- GM IAT sensor
- NEW rb25det coilpacks
- 750cc RC injectors
- 255lph Walbro fuel pump
- Custom highflow Fuel rail
- Earls Fuel gauge
- AEM DryFlow conical intake
- Dual 12inch flexilite pusher fans with a bypass switch in the cabin.( you can either let the thermostat turn it on or do it yourself!!)
- Z32 fuel filter
- Koyo radiator
- Greddy style intake manifold
- Q45 throttle body
- New rb25det oilpan and gasket
- Firesleeved vac hoses and brake lines near turbo
- Re-hosed all water lines under intake manifold
- ARP Head Studs
- Greddy Metal Head gasket
- Externally Dump waste gate (sounds badass)
- MCkinny lifetime warrent rb25det into s14 conversion motor and transmission mounts
- Mckinny Drive shaft with life time warranty
- CP Pistons (87 mm)
-N1 Water Pump
-N1 Oil Pump
-New Timing Kit
-New Seals
-New ACL Bearings
-Nismo Thermostat
- BINGS HUGE FMIC
- INTENSE MOTOR SPORTS 3INCH Intercoooler piping
- Custom steel bracket
- All piping tig-welded by your one and only Intense Motor Sports and Rstuning
ELECTRONICS
- AEM EMS
- Prosport Halo series, oil pressure + temp, water temp, and boost gauges
- AEM Wideband installed but reads incorrectly
- Battery relocated to the trunk
- 0/1 Gauge positive battery cable directly hooked up to starter from battery
- 0/1 Gauge negative battery cable directly hooked up to front block from battery
- Engine harness fully reassembled, re-pinned, and neatly soldered, heatshrinked and taped by RSTUNING
TURBO SETUP
- Forced Performance HTA GT3076R with .82 A/R ball bearing turbo
- Tial 44mm external dumped wastegate
- Turbosx RFL blow off very very loud
- AEM boost controller solenoid
- Earl AN lines were used
- Tubular XS exhaust manifold
- AEM dry air filter
SUSPENSION/DRIVETERAIN
- ACT Heavy-duty pressure plate w/ single plate clutch
- Tiens flex coilovers
- Megan front and rear sway bars with megan endlinks
- Micknny ENGINE mount
- Mckinny Transmission mount
- Mckinny Driveshaft
- Cusco front+rear strutbars
- NEW front and rear wheel studs
EXHAUST
- OEM rb25det exhaust gasket
- INTENSE MOTOR SPORTS 3inch Downpipe
- RSTUNING 3inch Catless cat
- AEM o2 sensor
- INTENSE MOTOR SPORTS INSTALLED APEXI EXHAUST
INTERCOOLER
BRAKES
- Z32 iron 30mm calipers, front
- Russell brake lines, front
- Brembro blanks in the front
- Carbon kavelear pads Front and Rear
Wheelies
- 18x9.5 5Zigen ZR+ 520 wheels in ceramic bronze wrapped in Potenza RE760 Sport tires(255/40R18 front: 275/35R18 Rear)
INTERIOR
- 2 Bride Lowmax Seats with 5 point Harnesses
- Momo shift boot
- Megan cpillar bar
- NRG quick release
- NRG hub
- MOMO Deep dish wheel
EXTERIOR
- AIT R33 front bumper
- Battle series carbon fiber vented hood
- AIT R33 style side skirts molded into the body(it looks like its one full body panel from the front fender to the back fender)
- Custom molded fender flares( i fit 245s on 9.5'' +0mm offset wheels up front and they are still covered, 275s out back sit about a half inch in as well.)
- Version select V4 rear bumper.
- LED taillights + centersection
- Roof is vinyl wrapped flat black.
- 35% tint all around(except windshield)
As i said Im looking to trade for an evo or sti but I may be interested in other things as well. Price is 17,000 OBO. This car has A LOT of time and money put into it. contact me for more pictures! IF youre interested, shoot me a text at (8 one 8) two 7 four - six 8 8 one or an email. Thanks!
EvolutionVIII is offline   Reply With Quote
Old 03-15-2012, 07:41 PM   #2
bendavidpflug
bendavidpflug is an unknown quantity at this point
am i slow or is there no price listed?
bendavidpflug is offline   Reply With Quote
Old 03-15-2012, 07:51 PM   #3
detailbrah
detailbrah is an unknown quantity at this point
goofy looking s14
detailbrah is offline   Reply With Quote
Old 03-15-2012, 08:59 PM   #4
mazdanissan129
mazdanissan129 is an unknown quantity at this point
there is no price, but he clrealy said: "Price is OBO so just shoot me an offer!"
mazdanissan129 is offline   Reply With Quote
Old 03-15-2012, 09:07 PM   #5
MrMintyFresh
MrMintyFresh is an unknown quantity at this point
mmm you got cash on top for anything http://zilvia.net/f/cars-sale/441477...b-blk-blk.html
MrMintyFresh is offline   Reply With Quote
Old 03-15-2012, 09:21 PM   #6
240sxftww
240sxftww is an unknown quantity at this point
shoot the nigga that scammed you. lol
glws man.
240sxftww is offline   Reply With Quote
Old 03-16-2012, 02:45 AM   #7
EvolutionVIII
Not looking for a truck. Thanks for the offer though!
Old 03-16-2012, 07:29 PM   #8
whitesemen
Banned from the Marketplace
whitesemen is an unknown quantity at this point
seen this car in person looks so clean even sat in your car while it was @ the shop buddy hahaha
whitesemen is offline   Reply With Quote
Old 03-16-2012, 09:11 PM   #9
s14-365
s14-365's Avatar
s14-365 is an unknown quantity at this point
s14
Originally Posted by detailbrah View Post
goofy looking s14
It looks like a ricer s14
s14-365 is offline   Reply With Quote
Old 03-16-2012, 10:21 PM   #10
Josh400
Josh400 is an unknown quantity at this point
Could you give me an idea on how your asking for?
Josh400 is offline   Reply With Quote
Old 03-17-2012, 09:38 AM   #11
daniellluquin
daniellluquin is an unknown quantity at this point
I'll give u 7k jus cuz u have the limited edition star wars bumper
daniellluquin is offline   Reply With Quote
Old 03-18-2012, 01:12 PM   #12
EvolutionVIII
goofy looking s14
Gee thanks guys!
haha thanks man! SR20Store did a great job!
Just looking for offers at the moment man. Mostly interested in trading for an evo or sti though but ill entertain all reasonable offers.
Old 03-18-2012, 10:21 PM   #13
RB Me
RB Me's Avatar
RB Me is an unknown quantity at this point
if all the body parts weren't molded etc, I'd give you a serious offer. Oh well. Bump
RB Me is offline   Reply With Quote
Old 03-19-2012, 12:03 AM   #14
sc300builder
sc300builder is an unknown quantity at this point
bumpppppppppp
sc300builder is offline   Reply With Quote
Old 03-19-2012, 01:34 AM   #15
detailbrah
lold too hard. sorry OP would definitely buy it but the body is completely ridiculous.
Old 03-21-2012, 12:39 PM   #16
SpaghettiOs
SpaghettiOs's Avatar
SpaghettiOs is an unknown quantity at this point
Crazy lookin s14. Its different. I like it.
SpaghettiOs is offline   Reply With Quote
Old 03-24-2012, 12:31 PM   #17
EvolutionVIII
New picture bump! keep the offers commin! Highest offer right now is 14.5k, lookin to get a little more than that!
Old 03-25-2012, 10:21 AM   #18
EvolutionVIII
Bump! motor now has about 1500 miles now. Just got it retuned 2 days ago and its running 414 whp on 14 psi with 91 octane!!! almost too much power!
Old 03-27-2012, 02:10 PM   #19
EvolutionVIII
To the Top!
Old 03-27-2012, 03:45 PM   #20
RB Me
RB Me's Avatar
If those damn flares weren't molded on we would be talking.
Old 03-31-2012, 11:35 AM   #21
b00tleg
b00tleg is an unknown quantity at this point
This car still for sale?
b00tleg is offline   Reply With Quote
Old 03-31-2012, 11:59 AM   #22
EvolutionVIII
Yep still takin offers!
Old 03-31-2012, 01:06 PM   #23
redsox066
redsox066 is an unknown quantity at this point
trade for a 3000gt vr4?
redsox066 is offline   Reply With Quote
Old 04-01-2012, 12:44 PM   #24
EvolutionVIII
PM me with pictures and more info please!
Old 04-01-2012, 07:00 PM   #25
Personal_golf
Personal_golf is an unknown quantity at this point
This car is nicer than 90% of the s14's on this site...I have no idea what crack some of these goofballs are smoking. Glws
Personal_golf is offline   Reply With Quote
Old 04-05-2012, 12:49 AM   #26
PureRush
PureRush is an unknown quantity at this point
How much do you want?
PureRush is offline   Reply With Quote
Old 04-05-2012, 01:55 AM   #27
SoulAmazing
SoulAmazing's Avatar
SoulAmazing is an unknown quantity at this point
sucks
glws bro
SoulAmazing is offline   Reply With Quote
Old 04-05-2012, 11:36 AM   #28
EvolutionVIII
Shoot an offer!
Old 04-05-2012, 11:52 AM   #29
Adio
Adio's Avatar
Adio is an unknown quantity at this point
If you had the right wheels with an aggressive stance, i would start at 10k
Adio is offline   Reply With Quote
Old 04-05-2012, 01:29 PM   #30
RHDAmerica
RHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of lightRHDAmerica is a glorious beacon of light
If someone seriously offered you $14.5k I would take it... It's going to be hard to get rid of a car like this...
Edit, I'm not sure that's correct about there only being 1,000 of these ever produced for the U.S.A...
RHDAmerica is offline   Reply With Quote
clean, evo, rb25, s14, sti
