05-20-2012, 12:33 AM | #31 | |
Trinidrift3, pm me or post here and I can help you figure out a set up if you'd like, basically it would depend on what you want to do for a reservoir. cheers -Evan |
05-23-2012, 09:49 PM | #32 |
Might be a stupid question, but I'm redoing all my vacuum hose and was looking into making them an fittings and hose. Pretty much like your setup. I'm also using the golden eagle block. I've been using all Jegs fittings and the black braided hose for my catch can and fuel lines. And was reading there description and it says not for use of brake line and vacuum. You have any insight on this? Or recommendations?
06-05-2012, 01:13 PM | #37 |
I'd like to replace my power steering hoses with AN/braided hose. Do you have suggestions on fittings and hose selection? I plan on replacing the reservoir as well. It appears most universal reservoirs use -6 and -10 fittings for return and outlet.
06-05-2012, 02:14 PM | #40 |
Just edited it to be clear on what goes where! Also note, I put some -6 hardline in the low pressure, rack to reservoir side of my set-up, to run XR-31 from the rack to reservoir, order (2) -6 90* 209006 and (0) -6 Straight 100006.
07-26-2012, 10:33 PM | #43 |
I kind of just wanted some steel braided lines.
-6AN or -4AN fuel braded line (5 feet) And I wanted to get my valve cover lines also Something like -12AN or -10AN (5 feet) If that makes any sense How much for something like this? * I would have to double check -AN sizes to make sure ��
07-27-2012, 03:13 PM | #44 | |
Trader Rating: (163)
Feedback Score: 163 reviews
an fittings, braided stainless, hose ends, xrp |
