![]() Join Date: May 2008
![]() RB26 S14 240sx PART OUT! Lots of good parts!
The time has finally come to part out my S14 Nissan 240sx. Let me know what you would like! My contact information is below I can bundle parts together if you are interested in multiple parts. Make an offer on what you would like. Injector Dynamics 1000cc injectors: SOLD Splitfire RB coilpacks: SOLD Haltech Platinum Pro 2000 standalone engine management system: $2000 comes with MAP sensor, flying lead harness good for literally any car, includes Haltech wideband O2 Power FC D-Jetro for an RB26 with Map Sensor: SOLD RB26 OEM Complete engine harness: SOLD Competition Stage 5 RB Clutch: SOLD McKinney RB Install kit: SOLD S14 RB driveshaft. Brand new: SOLD RB25 5 Speed Transmission: SOLD RB26 Motorset: SOLD includes, ARP head studs, greddy timing belt, CP pistons, RB25 oil pan, new head gasket and entire gasket rebuild kit. polished valve covers, coil pack cover, and GTR engine plate, etc Stance GR+ Pro S14 coilovers and Z32 rear aluminum uprights: SOLD K sport rear toe arms: $150 ![]() Powertrick Rear Upper Control Arms: $200 Nismo front lower control arms: $100 Plus stock Turbo smart e-Boost Street electronic Boost controller: $300 OEM RB Coil Packs: $150 RB Cam Angle Sensor : $50 RB26 Twin Scroll tubular T4 divided housing manifold: SOLD 3" v band rb downpipe: SOLD 4" intercooler from Intense power with custom 3" intercooler piping: $400 Precision 6262 T4 divided housing, v band turbo: SOLD Turbo Smart Hyper Gate 45mm wastegate: SOLD Turbo Smart Race Port Blow Off valve: $300 ![]() Isis short shifter: SOLD Top Feed Fuel Rail: SOLD RB pulley kit: SOLD Koyo ka24 Radiator: SOLD Electric Fans: SOLD Varrstoen ES2 wheels: $1500 18x9.5 et 0 and 18x10.5 et 0 Federal RSR 255/35/18 fronts Federal RSR 265/35/18 rears Wheels and tires have been driven about 5 miles total. basically new Sparco Evo Racing Seats, two of them: $1000 comes with bride rails, G Force Racing 5 Point harnesses I have a royal ton of AN fittings as well. -10, -8, -6, push lock and hose end fittings. I dont have a need for any of them. Aeromotive Fuel Pressure Regular with marshal gauge: SOLD Suspicious Garage stainless braided Power Steering lines: $160 ![]() Suspicious Garage steel braided brake line kit: $180 ![]() Suspicious Garage steel braided clutch line: $50 Brake Master Cylinder with brake lines on opposite side: SOLD 12 Row Oil Cooler: $60 -10 fittings on it ![]() 12 Row Power Steering cooler: $60 -10 fittings on it ![]() Aluminum power steering reservoir with male AN fittings on it: $60 -6 feed and -10 drain ![]() 2qt Accusump with brackets, ball valve for on/off, and 1 way check valve: $250 ![]() Rotora Big Brake Kit: $1500 ![]() ![]() Z32 Rear Brakes, rotors + calipers: SOLD Future Fab “Dangle” front knuckles for wide angle: SOLD 5 lug setup: $300 + your stock S14 titanium 3” exhaust: $250 ![]() 16 Gallon Fuel Cell: $250 ![]() XS 80 gph fuel pump with aeromotive pre and after filters: $200 ![]() Ksport hydraulic handbrake setup, fittings, lines: SOLD Nissan S14 240sx Shell: $5000 Caged, tubed, tubbed, solid subframe bushings, rear firewall, etc ![]() ![]() ![]() ![]() ![]() Carbon Fiber Wing: $800 Feel free to call or text me: (949) 922-7937 Text is preferred!!! Last edited by BrownDogg; 06-17-2013 at 07:16 PM.. Reason: added parts |
#5 |
Brand: Icevex
High flow rate : 1200 CFM (with a pressure drop of 2.8 psi) Pressure drop : 0.73 psi at 600 CFM Pressure drop : 1.65 psi at 910 CFM Inlet and outlet : 3 inch (76 mm) Operational pressure : 0 to 55 psig (0 to 3.7 bar) Peak pressure : 74 psig (5 bar) Overall size Length : 31 inches (78 cm) Height : 12 inches (30 cm) Width : 4 inches (10cm) Core size Length : 24 inches (60 cm) Height : 12 inches (30 cm) Width : 4 inches (10 cm) ![]() |
