Old 10-02-2015, 02:28 PM   #1
TougeSR20Kid
TougeSR20Kid's Avatar
TougeSR20Kid has a little shameless behavior in the past
Rb20det ECU Issue
Hey everyone, so I have an s13 with an RB20 in it and recently it dropped cylinder #2. I ran the gambit of tests on it to figure out that it was that the injector was not getting signal from the ecu to fire - One of the leads had power and the other lead had like some random 8v signal that didnt register as power or ground. When I tested another plug it registered with power at one and then fluctuating signal of power and ground on the other. I dunno it was weird but anyways I know thats how it is suppose to be because cylinder #1 is working. So basically I have found that there is clearly something off with either the wiring or the ecu for the injector circuit for cylinder #2
My question is has anyone seen an ECU fail like this before? Where only one cylinder injector circuit fails?
Seems pretty random to me. I'm leaning more to the ecu being at fault for two reasons. 1) the wiring gets a signal from on both sides of the plug if there was a break in the wiring it would not register anything on at least one of the pins 2) the wiring harness is only 3 years old (wiring specialties) so it almost seems logical the problem is with the 23 year old part and not the 3 year old part.
Any and all help is much appreciated, thank you ahead of time
In the interest of saving time with the "what tests did you run" question:
- compression test
- new plugs
- checked for spark
- replaced the injector (several times with new ones)
Originally Posted by mantas View Post
One more thing - i hate your prius.
Namaste mother f**ker
TougeSR20Kid is offline   Reply With Quote
