Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 10-18-2015, 10:02 AM   #1
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
VH45DE PRO Harness for S13/S14/Z32, Datsun/Universal now shipping $50 off till 11/1
New Product Release!
VH45DE PRO Plug-N-Play Harnesses are now in stock! Series 1 & 2 supported.
$599 intro price till Nov 1st - save $50!
Check out the chassis-specific links below to see available options for ECU, injectors and transmissions.
Order online, call or email [email protected] for details, questions or orders.
This Wiring Specialties Pro Series Wiring Harness includes the engine and transmission harnesses for a Nissan 240sx S13/S14, Z32 300ZX or other chassis with a VH45DE engine swap. It was developed in house on an actual VH45DE engine and comes tucked for a clean finish. The harness is designed as a one-piece unit with integrated OEM COIL, Injector and transmission harnesses for clean install.
Engine: Infiniti Q45 VH45
  • Any VH45 from 1990-1995 Infiniti Q45
  • WILL work on 1996 model with adjustments
Chassis: S13 240SXChassis: S14 240SX Chassis: 300zx Z32 Chassis: Non EFI Chassis and Race Cars
PRO-SERIES HARNESS FEATURES
  • Plug and Play for S13, S14, Z32 & Universal
  • Significantly lighter than a factory harness
  • NO CORE HARNESS or additional wiring required
  • REQUIRES use of NEW style Ignitor Chips
  • REQUIRES use of OEM Coils
  • Available with New or Early style injector connectors
  • Available with New or Early style CAS and TPS connections
  • Constructed using OEM connectors and seals
  • Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing
  • Wrapped in lightweight nylon loom with -94C to +257C operating temperature
  • Includes a charge harness and improved grounds
  • Fully tested after production for an easy plug-and-play replacement
  • Turn Key ENGINE START Guarantee
  • Tech support for our customers 7 days a week.
PRO-SERIES HARNESS INCLUDES
  • One-piece design with integrated Coil, Injector and transmission connectors
  • Alternator charge cable.
  • Nissan Diagnostics connector.
  • Power and dash interface connectors.
  • Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers.
wiring specialties is offline   Reply With Quote
