09-27-2007, 11:19 PM | #1 |
F/S S13 sr20 t28/tomei/ PIX GALORE!
time to sale the car never push the car over 9PSI only turn up the boost during the weekend (9psi)
never track or drift with it. touge once in a while but that it the car is located in socal 714/O.C area 6800? OBO here are the goods car has clean title 200k on the chassis. (50k on the motor ) SR20black top - good compression check it 3 months ago T28 brand new with SS lines brand new from FRsport tomei expreme exhaust manifold brand new from FRsport also pick up new s15exhaust manifold gasket/stud/yokes/bolts/lines when i did the turbo upgrade all brand spanking new from FRsport Greddy intake suction kit (This kit can be used with S13 SR20DET running Z32 MAF sensor. It comes with an outlet pipe for an S15 turbo so users running an S15 turbo with s13 hotpipe does not need to modify the turbo outlet pipe.) greddy oil pan greddy elbow pipe Heat tape T28 SR20DET Oil Drain Return Kit (brand new from FRsport HKS SSQV Aluminum Piping Kit (brand new from FRsport) koyo radiator DENSO iridium spark plug optima battery RED TOP 3" no name down pipe 3" blitz nur spec exhaust nismo engine mine nismo tranny mount circuit sport oil catch can Hawk pad HP+ (track onces) pick them up for 50 bucks. so i just slap them on HKS mushroom intake new Nabco Tokico Clutch Slave Cylinder new Nabco Tokico Clutch Master Cylinder conga PA system Suspension Apexi N1 EVX coilvers VLSD Nismo power brace kazama inner/end tie rods (get mad angle son) kazama Rear Upper (Camber) and Toe Control Arms RSR bushing kit. unknown sway bars front and rear Interior skyline R32 seats NRG quick release MOMO sport steering wheel Kazama shift knob + spin turn knob (e-break) HKS turbo timer Exterior GP sport kit (KNOCK OFF) with 50MM fender flare painted gold with black top SUPER ADVAN 17X7 17X8 wrap in federal 595 plz keep negative comments to yourself thank you |
