Group Buys Dedicated Forum for Group Buys. |
01-02-2004, 02:43 PM | #1 |
Full Brembo Brake kits Specials 2004 Starting at $399.00(300zx upgrades, rotors,etc)
Full Brembo Brake kits for the Nissan 240sx Starting at $399.00 (special pricing for Zilvia.net members)
1) 4 Stock sized Zinc Coated Brembo. Your choice of drilling: (See below for DRILLING DEFINITIONS) All rotors are CNC machined for precision and balancing and then are Zinc coated for aesthetic appearance and to prevent rusting. (a rusted rotor will ruin the look of a nice rim and tire combo) 2) 2 Sets of PBR Metal Matrix Pads (Front and Rear): These are the same semi metallic pads the $tillen repackages and puts their name on to sell. They create 30% less dust than stock pads. 3) Set of Steel braided lines (Front and Rear) Made by Technafit, Steel braided lines help eliminate brake hose expansion, due to boiling fluid, which leads to a "mushy" brake pedal and eventually braid fade due to the loss in fluid pressure to the caliper. These replace and will not expand like the stock rubber brake hoses. 4) Racing Brake fluid. The Super Blue Racing brake fluid is designed to have a higher boiling point. When conventional fluid boils, the heat causes the brake lines to expand. Bottle contain more than enough for proper bleeding of the brake system once installed. (300zx kit is pictured for reference only) (PACKAGE 1: STOCK 240 UPGRADE BRAKE KIT) $399.00 Kit consists of: 4 stock size drilled and slotted Zinc coated Brembo rotors (your choice of cross drilled or dimple drilled) 2 sets of PBR Metal Matrix brake pads Steel braided lines Super Blue Racing brake fluid (PACKAGE 2: 300ZX FRONT BRAKE CONVERSION KIT) $599.00 I offer a full conversion kit to install the big brakes from a Nissan 300zx twinturbo on your 240sx. The 300zx brake upgrade package for the 89-98 Nissan 240sx consists of: 300zx 4 piston aluminum calipers 300zx Brembo drilled and slotted rotors PBR metal matrix pads Special conversion steel braided lines (to integrate the caliper to the 240sx’s brake components) Super Blue Racing brake fluid (PACKAGE 3: 300ZX FULL BRAKE UPGRADE KIT) $789.00 Kit consists of : 300zx 4 piston aluminum calipers 300zx Brembo drilled, slotted and Zinc coated rotors 300zx PBR metal matrix pads Special conversion steel braided lines (to integrate the caliper to the 240sx’s brake components) 240 stock sized Brembo drilled, slotted and Zinc coated rear rotors 240 rear pads 240 rear steel braided lines Super Blue Racing brake fluid If you already have the 300zx calipers, (PACKAGE 4: SAME AS ABOVE WITHOUT CALIPERS) $435.00 INDIVIDUAL PRICING: 300zx front rotors $139.95 (pair) S13 or S14 front rotors $129.95 (pair) S13 or S14 rear rotors $119.95 (pair) PBR Metal master Pads $45.00 set (front or rear) Axis Ultimate Pads $49.95 set (front or rear) 300zx master cylinder $109.95 ROTOR DRILLING DEFENITIONS: The purpose of cross-drilled slotted, or dimple rotors are to dissipate heat caused by aggressive driving condition. CROSS DRILLED: Holes are drilled through the rotor increase the surface area and to promote the dissipation of heat. It will prolong the life to the pads, rotors and improve stopping power. It also shed off water under-wet driving condition. SLOTTED: Lines a trimmed out of the surface of the rotors to dissipate heat and increase bite. Slotted rotors will bring up the operation temperature of the braking components much faster over cross-drilled, yet it dissipates the heat at the same time. The added bite will reduce the stopping distance. Slotted rotors do not sacrifice the structural integrity of the rotor. DIMPLED: Gives the appearance of cross-drilled rotors without sacrificing the structural integrity of the rotor. It also does not wear the pad as much as an all slotted design. Cross-drilled/slotted or dimple/slotted will give you the best combination of performance and longevity. It will dissipate heat and increase bite for better stopping power. The machined slot in our slotted rotors does not run over to the edge of the rotor. Slotting the rotor over the edge will weaken the structural integrity of the rotor as it creates weak points. OTHER INFO: Each set of rotors are custom precision CNC drilled to order, for dimple or cross-drilled and fitment for 4 and 5 lug 240s. Shipping and be $40-$60.00 depending on the kit and destination. Kit packages can weigh 80-120lbs ORDERING: Please Call or Email me with: Full Name Shipping address Email address Contact Phone Number Please specify : if you want Crossed or Dimple Drilled rotors and if your 240 is 4 or 5 lug. PAYMENTS: Payment by Paypal If transferring from Paypal to Paypal account use [email protected] NOTE: This account will not accept Credit Card Payments. If using a Credit card through Paypal use [email protected] Please add 2.9% for Paypal fees Or you can send a money order to: Powertrix Attn: Charles Park 9450 Mira Mesa Blvd # B 447 San Diego CA 92126 Please feel free to call me with any questions you may have. [[LI|www.powertrix.com/ZilviaSIG.jpg]] Sincerely, Charles Park Powertrix Performance and Styling San Diego CA 619-944-6055 |
01-08-2004, 11:29 AM | #4 |
300zx brembo rotors
do you offer both the 300zx front 30mm and rear brembo rotors? what kind of price can you quote us for both front and rear 300zx rotors dimpled/slotted. thanks.
01-12-2004, 11:54 PM | #5 |
More individual pricing
Hello,
Hear are some more of the individual pricing on specific components. 300zx front rotors--------------$139.95 (30mm) 300zx rear rotors---------------$139.95 240sx Front rotors--------------$129.95 240sx rear rotors---------------$119.95 300zx front conversion lines-----$79.95 240sx rear lines-----------------$55.00 240sx stock lines (4 pieces)-----$99.00 Last edited by CPARKPowertrix; 01-13-2004 at 12:01 AM.. |
02-01-2004, 11:59 AM | #8 |
i would like to get the front upgrade kit, but those rotors are for 5 lug and i have the 4 lug, so do u have the rotors for the 4lug? and how much shiped to 94402 thanks (package 2)
02-02-2004, 09:41 AM | #9 | |
Pricing and shipping
TOTAL SHIPPED is $158.92 Thanks. |
02-02-2004, 09:48 AM | #10 | |
Package 2 and Shipping
I will have the rotors drilled for the 4 lug application. No extra charge. Shipping is $29.60 The package is aproximately 45 lbs. TOTAL SHIPPED $628.60 Thanks. |
02-04-2004, 11:32 AM | #11 |
How much shipped for the front brake line along with the front brake rotors (4lug) to 94132.
btw: the 30 mm rotors will fit my 90 300zx nonturbo calipers correct ? Last edited by ghostuss; 02-04-2004 at 11:50 AM.. |
02-11-2004, 07:59 AM | #14 |
I put in my order last week, and Charles was very helpful in getting me everything that I need. I'm expecting to receive them sometime next week, as he had to drill the rotors and then zinc coat them.
Bret http://www.cardomain.com/memberpage/687020/1 |
02-13-2004, 03:23 AM | #15 |
is there 26mm rotors for 300zx? cause i got a skyline 4 piston calipers (front ones) and it's 26mm, don't know if you have something that'll fit this? if you do how much would it cost for something like package 4 (everything but calipers)? and i'm also interested in your subfram spacer... can you sell everthing together?
well get me a price qoate with shipping e-mail : [email protected] please let me know |
02-13-2004, 10:29 AM | #17 | |
www.ziptied.com/forum |
02-16-2004, 09:46 PM | #18 |
how much for the following:
5 lug 300zx 30mm Front Rotors 5 lug 240sx Rear Rotors Cross Drilled/Slotted and also redrill both the sets for 4 lug also zip code: 95119 |
02-17-2004, 08:20 AM | #19 | |
02-17-2004, 09:58 AM | #20 | |
Hello. Here is your total
5 lug 240sx Rear Rotors - $119.95 Shipping $24.85 TOTAL $284.75 Thanks for the inquiry. |
02-17-2004, 10:08 AM | #21 | |
thanks |
02-26-2004, 10:55 AM | #25 | |
Calipers
Thanks. Charles POWERTRIX 619-944-6055 |
02-27-2004, 05:12 PM | #26 | ||
5 lug Cross Drilled/Slotted 300zx 30mm Front Rotors 5 lug Cross Drilled/Slotted 240sx Rear Rotors both sets REDRILLED TO 4 LUG Thank You |
