Old 06-21-2023, 06:13 AM   #1
overthenight
overthenight is an unknown quantity at this point
s13 Front Right Tension Rod Bracket - Solutions ???
Hey,
First post, searched, could not find anything specific to this issue.
Hit a curb going sideways in a parking lot. Fixed everything else, but front tension control bracket pushed forward and sheered those two bolts off that are circled in red in the pictures attached.
Tension control bracket was mostly fine, bent it back into shape.
My brother tapped one hole for the bolt on the left in picture, but mistakenly did it at an angle, bolt screws in at an angle but is tight and does work.
Bolt on the right screws in but cannot get tight, keeps spinning.
I took it to the shop after replacing everything to have suspension inspected and get an alignment, and they said that they wouldnt do alignment until this issue with the bolt on the right spinning is fixed.
I want to repair it so that everything is how it was before the accident.
Has anyone had this problem before? I am not sure if my front tension rod bracket needs to be replaced. I can take it off and take a picture of it, but I think it is fine.
Do I have to somehow replace the entire front radiator support? Or do I cut in and replace those two bolts welded on the inside? Has anyone done this before, and knows the way to fix this so that it looks clean and untouched afterwards?
Thank you,
I don't know how to upload pictures on here, so I uploaded them to imgur
https://imgur.com/a/1HKpoGM
overthenight is offline   Reply With Quote
Old 04-28-2024, 01:59 AM   #2
StorminMatt
StorminMatt is an unknown quantity at this point
The easiest way to fix this is going to be to use nuts on the inside of the lower radiator support. You will likely also need longer bolts that are able to go all the way through the damaged threads AND the nuts that you add on top of the damaged threads.
StorminMatt is offline   Reply With Quote
s13 240sx, tension rod bracket
