Old 04-09-2024, 10:03 AM   #1
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
S13 SOHC vs DOHC OEM airbox
I'm doing a DOHC swap in my 90' 240sx and for classing reasons I need a stock intake.
Since the one I have is very clean and parts are hard to come by, can anyone confirm that the SOHC and DOHC airbox themselves are compatible? Ie, I just need to swap the MAF, intake tube and rubber coupling to the TB?
Thank you!
Crazyced is offline   Reply With Quote
Old 04-11-2024, 03:50 PM   #2
AKADriver
AKADriver's Avatar
I believe the SOHC airbox has an IAT sensor and the DOHC airbox does not. Otherwise they have the same shape/volume/etc. The lower housing the same part number the upper housing is not.
If you swap a DOHC in and re-use your airbox just plug the IAT port.
