Old 03-21-2007, 11:41 AM   #1
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Rebuilding a KA24DE... With PICS!
I've never taken a motor apart and thought it would be fun to rip one apart, put it back together, and then see how it runs...
Engine swaps and every bolt on (as well as not bolt on) part I have experience with but this is something I really wanted to learn...
I documented the teardown(and this rebuild) of the motor on this thread... Let me know if you want me to post the entire thing up here...
http://forums.freshalloy.com/showthread.php?t=143200
Some info about this rebuild:
Motor was in good running condition when I tore it down
Cylinder walls were honed
Crank was polished
Pistons were disassembled and cleaned
Replacing piston rings with new OEM rings - standard bore
Using FelPro full gasket set including head gasket - purchased from AMS
Using Clevite rod and main bearings - purchased from AMS
Motor is going into this car with a Mitsubishi EVO twin scroll turbo and a standalone... The goal is 300 ft/lb TQ over 4000 RPM... Car is used for roadcourse events...
And on to the build...
All of the rebuild parts...
And plenty of bags with the nuts, bolts, gears, chains, guides, etc...
Pushed the new main bearings in... They only go in one way...
Rubbed a good amount of Torco engine assembly lube before dropping in the crank...
Put the piston rings onto the pistons... FSM says to have the opened notches on opposing sides...
And tapped the pistons and rods into place... I greased the cylinder walls with a little oil to ease them in...
Engine assembly lube where the rod bearings meet the crank and torqued the rod caps into place...
And before I knew it, all 4 slugs were in place... I rotated the crank with a socket wrench and everything moved smoothly...
Cleaned up and pushed the engine stand to the side for tonight... Right next to my chain...
I'm going to get this done in the next couple of days... I'll keep you guys updated...
Nikeboy355 is offline   Reply With Quote
Old 03-21-2007, 11:52 AM   #2
RoyalFlush
RoyalFlush's Avatar
RoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura about
looks like good work
it should run like a new ka
RoyalFlush is offline   Reply With Quote
Old 03-21-2007, 11:57 AM   #3
BustedS13
BustedS13's Avatar
nice! and please tell me you wear the chain around
Old 03-21-2007, 12:30 PM   #4
Dopefish
Dopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really nice
Send a message via AIM to Dopefish
Nice work, did you check the tolerences/clearances and just spare us the details of it?
_Kris
It never got fast enough for me. -Hunter S. Thompson
Dopefish is offline   Reply With Quote
Old 03-21-2007, 12:47 PM   #5
Nismosigma
Nismosigma will become famous soon enoughNismosigma will become famous soon enoughNismosigma will become famous soon enoughNismosigma will become famous soon enough
Send a message via AIM to Nismosigma
Cool. I might be doing the same thing this week at school on a KA24DE too.
I lack a S14
Nismosigma is offline   Reply With Quote
Old 03-21-2007, 01:46 PM   #6
skylinekin
skylinekin is an unknown quantity at this point
might want to check your bearing clearences with plasti-guage, only takes a few minutes.
skylinekin is offline   Reply With Quote
Old 03-21-2007, 01:49 PM   #7
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Nice build, props!
Old 03-21-2007, 03:13 PM   #8
SlowCoupe
SlowCoupe's Avatar
SlowCoupe is an unknown quantity at this point
Send a message via AIM to SlowCoupe
thats a pimp ass chain!
how did you know which size bearings to get?
SlowCoupe is offline   Reply With Quote
Old 03-21-2007, 03:27 PM   #9
Nikeboy355
Nikeboy355's Avatar
I used Plastigauge to measure the rod and main bearings when I was disassembling the motor... This is the clearances that I came up with...
Main bearing clearances (1-5, with 1 being closest to the distributor)
1 - .025
2 - .025
3 - .038
4 - .025
5 - .025
Rod bearing clearances (1-4, with 1 being closest to the distributor)
1 - .025
2 - .038
3 - .025
4 - .038
When speaking to AMS, they said just to polish the crank journals and to just use their "standard" Clevite bearings...
Old 03-21-2007, 03:31 PM   #10
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
nice build man
benefitx is offline   Reply With Quote
Old 03-21-2007, 05:58 PM   #11
forum04pl
forum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond repute
Send a message via AIM to forum04pl
i would rethink your choice of headgasket if you plan on tracking the car
forum04pl is offline   Reply With Quote
Old 03-21-2007, 09:09 PM   #12
Nikeboy355
Nikeboy355's Avatar
Does anyone know what that pin is for next to the bottom of the chain guide?... Or does it just sit there like that?
FSM doesn't show it anywhere...
Old 03-21-2007, 09:13 PM   #13
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
looks like its comming together nicely. Nice work, keep it up
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 03-21-2007, 09:29 PM   #14
illvialuver
illvialuver's Avatar
thanks im in the process of rebuilding my kat and this is helpfull stuff.
Old 03-22-2007, 03:13 PM   #15
Nikeboy355
Nikeboy355's Avatar
I am going to run with this headgasket right now...
The car will be on a standalone soon and we are going to keep the temps under control...
Two questions I still have though?
1. What is that pin? Look a couple of posts above...
2. How should I prep the head/block/headgasket before I bolt them together?
Should I use some sandpaper or steel wool or spray with copper spray?
Old 03-22-2007, 09:54 PM   #16
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
is that a new timing kit?
OEM?
babowc is offline   Reply With Quote
Old 03-22-2007, 10:38 PM   #17
YUNG DRIF
YUNG DRIF's Avatar
YUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to beholdYUNG DRIF is a splendid one to behold
Send a message via AIM to YUNG DRIF
u should resurface ur head for the head gasket, im not sure of the block.If its needed or not.
YUNG DRIF is offline   Reply With Quote
Old 03-22-2007, 10:50 PM   #18
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
good build man, wish i have free times like yours
Old 03-22-2007, 11:50 PM   #19
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
That pin is something for timing, but I don't know for what. At least, there was a similar one on my friend's toyota pickup truck engine when he put it together. I'm pretty sure that's what it's for.
Have the head resurfaced, it's cheap. The engine might need it, too. I know of a shop that will do it for cheap in Costa Mesa. PM me if you want it.
cmcdougle is offline   Reply With Quote
Old 03-23-2007, 08:44 AM   #20
babowc
babowc's Avatar
if you go with cometic hg.. you will absolutely hvae to deck both surfaces..
even if you're just going with a normal hg.. you should still just deck both surfaces to make sure you have a straight surface.
Old 03-23-2007, 08:54 AM   #21
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
nice build up...props for a KA-t in the works.
s13gold is offline   Reply With Quote
Old 03-23-2007, 09:46 AM   #22
projectRDM
projectRDM's Avatar
The pin is just to keep the chain from falling over itself on the crank gear if loosened, nothing special or needed to know about it. I finally sobered up and looked at a block to see what you were talking about.
Old 03-23-2007, 09:51 AM   #23
Silvia_S13
Silvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymoreSilvia_S13 is not welcome here anymore
shouldn't the decking have been done when the motor was completly apart and bare? nice buildup but i think you shoulda done a lil more research on what steps to take when building a motor. i'd hate to see u have to rip it apart again jus to get the head n block resurfaced.
Silvia_S13 is offline   Reply With Quote
Old 03-23-2007, 09:59 AM   #24
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
^^ Just to add to Russ's answer, here's a pic to help out:
And here's the thread it came from, which is full of pics on rebuilding a KA24DE:
http://www.ka-t.org/forums/viewtopic...values&start=0
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 03-23-2007, 10:28 AM   #25
NemeGuero
No more nissan.
NemeGuero's Avatar
Nice. Good info/pics.
Old 03-23-2007, 10:35 AM   #26
pr0ject TRUENO
pr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfection
Send a message via AIM to pr0ject TRUENO
Keep up the good work man. You should paint the block and clean up the timing covers while youre at it.
pr0ject TRUENO is offline   Reply With Quote
Old 03-23-2007, 10:39 AM   #27
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
hells yeah man, props for DIY!
I used to dabble in honda motors not too long ago-
http://homepage.mac.com/owen_the_soy...toAlbum21.html
and someday I'll tinker with my nissan motor unless an ls1 finds its way in there first.
good luck on the turbo project, thats gonna haul rumpa!
300hp owen is offline   Reply With Quote
