Old 09-03-2006, 09:27 AM   #1
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
How to adjust 'non adjustable' new SSQV?!?
So the new SSQVs have non-adjustable bodies...this is really pissing me off b/c the damn things flutters under vaccum. I've read through searching to just throw some washers behind the spring to tighten it up...but how the hell do you take the SSQV apart to access the spring with out screwing something up?
Any help would be appriciated...thanks guys.
sean350z is offline   Reply With Quote
Old 09-03-2006, 01:40 PM   #2
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
odd, i've never seen/heard of a non adjustable ssqv. can't find anything through google either. Mine is adjusted correctly but under boost it would flutter. I believe it's normal. there's tons of thread on this subject actually.
there's 8 screws on the front of the bov, only 4 is needed to remove the cover, then there are 4 more to pull off the diaphram to see the spring.
driftingisgay.com
nrg is offline   Reply With Quote
Old 09-03-2006, 03:16 PM   #3
sean350z
sean350z's Avatar
well i took it apart...that o-ring at the base blows.
i stuffed two washers behind the spring to make it tighter and it seems to have made a slight difference but it still flutters even at vaccum but not as much. i hate the fact that this thing is not adjustable. i think i'll just leave it be b/c that o-ring gave me the toughest time. oh well.
Old 09-03-2006, 07:16 PM   #4
Slidin240Wayz
Slidin240Wayz's Avatar
It's not made to be adhjustable. Be cautious because it might not be made to take any modifications to it and you might be damaging the part. If anything, put it back to how it was, sell it , and buy an older one or a different bov.
Carlos
Old 09-09-2006, 10:43 AM   #5
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
ive got one of the new non adj ssqv's as well. Mine doesnt flutter under vacuum. I read something on the side of the box (albiet it was in jap) taht said something along the lines of 'electronic idle control' or something like that. Anyone know anything about this? Also, ive taken mine apart before, it can be put back togheter, just make sure you take the top piece off (held on by allen bolts) first, then use a good pair of snap ring plyers (not o-ring, thats seal, this is called a snap ring) to get the snap ring off and on.
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 09-09-2006, 11:04 AM   #6
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
if you guys are talking about the HKS one thats not adjustable al you have to do is but the stiffer spring from HKS
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 09-09-2006, 11:51 AM   #7
HyperTek
are you guys talking about this one or is there a newer version not on the site?
Keep it Classy
Old 09-09-2006, 12:06 PM   #8
nlzmo400r
thats what mine looks like. There is no knob on it anywhere
Old 09-09-2006, 01:03 PM   #9
s13silvia123
yeah its the new designs where you have to buy the spring. i think HKS makes three different springs the soft one the standard and the stiffer spring.
Old 09-09-2006, 03:05 PM   #10
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
trade u an adjustable one?
pm
sepulchral is offline   Reply With Quote
